Format Text (Style selection) in a idw drawing VB.NET
Hi to all, is there a way to select the Style listed in the Style box, when inserting some text in a idw drawing, using VB.Net?
I would like to add text (Notes and Title) at specific place in the drawing.
Any help will be appreciated, thank's!
Owner2229
Hi, here is an example of how to format your text in a new drawing note via VB.Net.
Red highlighted is to be changed.
Dim oDoc As Inventor.Document = InventorApplication.ActiveDocument
Dim stext As String
stext = "<StyleOverride Font='ARIAL' FontSize = '0.1524' >PRINTED: " & Now() & "<Br/>BY: " & InventorApplication.GeneralOptions.UserName & "</StyleOverride>"
' Set a reference to the GeneralNotes object
Dim oGeneralNotes As Inventor.GeneralNotes = oDoc.ActiveSheet.DrawingNotes.GeneralNotes
Dim oTG As Inventor.TransientGeometry = InventorApplication.TransientGeometry
Dim oGeneralNote As Inventor.GeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(0.3, 1.5), stext)
' Set the color of the note Dim oColor As Inventor.Color = InventorApplication.TransientObjects.CreateColor(128, 128, 128)oGeneralNote.Color = oColor ' Set the rotation of the note in Radians (1.5 ~ 90°) oGeneralNote.Rotation = 1.5
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Thank's Mike, I already tried this one.  What i am looking for, is to select from the Styles Editor Standard Text already estabish.
smilinger
You can just provide the style name when you add the text.
Dim oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(0.3, 1.5), stext, "Your Text Style Name")
That's perfect for me!
Thank's smilinger
