I'm trying to cycle through bend lines on a flat pattern in an idw to find the feature that created them. I have been able to loop through all drawing curves to find the bend lines, but have been unable to get the name of the feature that created them. I have posted the code I have below, with some pusedo code in the middle:
Function GetBendFeature(oView As DrawingView, BendName As String) As DrawingCurve Dim oReturnCurve As DrawingCurve Dim oPDoc As PartDocument = oView.ReferencedDocumentDescriptor.ReferencedDocument Dim oPDef As SheetMetalComponentDefinition = oPDoc.ComponentDefinition For Each oCurve In oView.DrawingCurves If oCurve.EdgeType = Inventor.DrawingEdgeTypeEnum.kBendDownEdge Or oCurve.EdgeType = Inventor.DrawingEdgeTypeEnum.kBendUpEdge Then 'start pusedo code If oCurve.parentfeature.name = FeatureName Then oReturnCurve = ocurve End If 'end pusedo code End If Next oCurve 'exit if not found If oReturnCurve Is Nothing Then MessageBox.Show("Cannot find a flange called '" & BendName & "' in '" & oPDoc.DisplayName & "'.", "Error") Exit Function End If Return oReturnCurve End Function
How can I get the reference of the feature that created these drawing curves?
Hi @mitchELAHB . This is a simple example of getting Featere from Curve:
Sub main
Dim oDDoc As DrawingDocument = ThisDoc.Document
For Each oSheet As Sheet In oDDoc.Sheets
For Each oView As DrawingView In oSheet.DrawingViews
For Each oCurve As DrawingCurve In oView.DrawingCurves
Dim oBody As SurfaceBody = oCurve.ModelGeometry.Parent
MessageBox.Show(oBody.CreatedByFeature.Type.ToString(), oBody.CreatedByFeature.Name)
Exit Sub
Next
Next
Next
End Sub
Here I made changes to your code, please check if everything works:
'start pusedo code
If oBody.CreatedByFeature.Name = FeatureName Then
oReturnCurve = oCurve
End If
'end pusedo code
End If
Next oCurve
'exit if not found
Exit Function
End If
Return oReturnCurve
End Function
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Sub main
Exit Sub
Next
Next
Next
End Sub
'start pusedo code
End If
'end pusedo code
End If
Next oCurve
'exit if not found
Exit Function
End If
Return oReturnCurve
End Function
Hi, thanks for the reply.
I get an "Object reference not set to an instance of an object." error when the code gets to the line:
If oBody.CreatedByFeature.Name = BendName Then
I tried running an edited version of the the sample code supplied:
Sub main Dim oDDoc As DrawingDocument = ThisDoc.Document For Each oSheet As Sheet In oDDoc.Sheets For Each oView As DrawingView In oSheet.DrawingViews For Each oCurve As DrawingCurve In oView.DrawingCurves Dim oBody As SurfaceBody = oCurve.ModelGeometry.Parent logger.trace(oBody.CreatedByFeature.Name & " " & oBody.CreatedByFeature.Type.ToString()) Next Next Next End Sub
but eventually would run into the error "No such interface supported" on the line:
I believe the issue stems from the fact that the view is a flat pattern, but the feature that created that bend line is part of the folded model. What should I try next?
