Find overlapping sketched symbols with drawing views
2 REPLIES 2
Kay_Rethmeier
122 Views, 2 Replies
Hey there,
I'm looking for some iLogic code which could detect, if a sketched symbol is overlapping with:
a) an other sketched symbol    or
b) with a drawing view
Are there any ideas to do this? I have no idea so far?
Thank in advance!
Bye
Kay
Cheers
Kay (Principal CAD-Consultant)
2 REPLIES 2
WCrihfield
in reply to: Kay_Rethmeier
Hi @Kay_Rethmeier.  You are likely not getting many responses because what you are asking for would not only require a lot of relatively complex code, and a lot of time to design & test, but also the resulting solution would most likely not be very accurate anyways.  This is because it would likely have to use rectangular bounding boxes, even if the contents of the SketchedSymbol and/or view may be round, or some other odd shape.  So it could be common to get a lot of false positives (at least visually).  Plus it is likely that no one else would have any use for a code based tool like that.
If you had some existing code for this task that you were having trouble with, and wanted some advice on how to fix it,  improve it, or make it more efficient, then you might get more responses (less work for us 😉).
Wesley Crihfield
(Not an Autodesk Employee)
Kay_Rethmeier
in reply to: WCrihfield
Hi Wesley,
thanks for your response. I forgot this post... But anyway, we think about adding some next stamps onto our drawings and I wanted to get some first ideas, if somebody was doing something similar. - So if not, than we will do this whithout these checkings..... and check this by hand.
Regards
Kay
Cheers
Technology Administrators
