I see that 'Where used' works very good when used from the Inventor application.
But I have problems when using it from code. The FindWhereUsed method can be used from a document and searches only within that document. Instead the 'Where used' functionality from Inventor searches through a path. And of course from inventor I get the dwg and idw files, from code I do not. How can I get to the same function?
Thank you
Thank you
