Good afternoon,
I'm looking for some help with accessing the active session of inventor and running external iLogic rules from a winForm. Any assistance with this would be tremendously appreciated. I'm tired of utilized built in forms. They've become to limited for my use cases.
Thank you for your time!
Issue (Unable to call external rules):
Public iLogicVb As Autodesk.iLogic.Interfaces.ILowLevelSupport
iLogicVb.RunExternalRule("Spec Reference List")
Complete Code:
AddReference "System.Drawing" 'Imports System.ComponentModel Imports System.Drawing Imports System.Windows.Forms Imports Autodesk.iLogic.Interfaces
Public Class WinForm Inherits System.Windows.Forms.Form ' Declare any thing here that you want to use/access throughout all Subs & Functions Public iLogicVb As Autodesk.iLogic.Interfaces.ILowLevelSupport Public oLargerFont As System.Drawing.Font = New Font("Arial", 10) Public Sub New() ' Creates the new instance oForm = Me With oForm .FormBorderStyle = FormBorderStyle.FixedToolWindow .StartPosition = FormStartPosition.CenterScreen .Width = 500 .Height = 750 .TopMost = True .Font = oLargerFont .Text = "Template" .Name = "Template" .ShowInTaskbar = False End With Dim oButton1 As New Button() With oButton1 .Text = "Buttom 1 Test" .Top = 25 .Left = 75 .Enabled = True .AutoSize = True End With oForm.Controls.Add(oButton1) AddHandler oButton1.Click, AddressOf oButton1_Click Dim oButton2 As New Button() With oButton2 .Text = "Buttom 2 Test" .Top = 125 .Left = 75 .Enabled = True .AutoSize = True End With oForm.Controls.Add(oButton2) AddHandler oButton2.Click, AddressOf oButton2_Click ' Dim oTextBox1 As New TextBox() ' With oTextBox1 ' .Text = "I am a Text Box" ' .Top = 225 ' .Left = 75 ' .Font = oLargerFont ' .Enabled = True ' .Width = 250 ' .Height = 50 ' End With ' oForm.Controls.Add(oTextBox1) ' AddHandler oTextBox1.Leave, AddressOf oTextBox1_Leave Dim oCheckBox1 As New CheckBox() With oCheckBox1 .Text = "Check Box" .Top = 325 .Left = 75 .Enabled = True .AutoSize = True End With oForm.Controls.Add(oCheckBox1) AddHandler oCheckBox1.CheckedChanged, AddressOf oCheckBox1_CheckedChanged Dim oComboBox1 As New ComboBox() With oComboBox1 .DataSource = {"A", "B", "C", "NA"} .Top = 425 .Left = 75 .Enabled = True .AutoSize = True End With oForm.Controls.Add(oComboBox1) AddHandler oComboBox1.SelectedIndexChanged, AddressOf oComboBox1_SelectedIndexChanged Dim oRadioButton1 As New RadioButton() With oRadioButton1 .Text = "Radio Button 1" .Top = 525 .Left = 75 .Enabled = True .AutoSize = True End With oForm.Controls.Add(oRadioButton1) AddHandler oRadioButton1.CheckedChanged, AddressOf oRadioButton1_CheckedChanged Dim oRadioButton2 As New RadioButton() With oRadioButton2 .Text = "Radio Button 2" .Top = 575 .Left = 75 .Enabled = True .AutoSize = True End With oForm.Controls.Add(oRadioButton2) AddHandler oRadioButton2.CheckedChanged, AddressOf oRadioButton2_CheckedChanged ' This is the end of the main Sub that defines the Form .SelectionChangeCommitted End Sub Private Sub WinForm_FormClosing(ByVal oSender As Object, ByVal oFormCloseEvents As FormClosingEventArgs) Handles Me.FormClosing ' If MsgBox("Are you sure you want to close this Form?",vbYesNo+vbQuestion, "CLOSE") = vbYes Then ' Else ' oFormCloseEvents.Cancel = True ' End If End Sub Private Sub oButton1_Click(ByVal oSender As System.Object, ByVal oEventArgs As System.EventArgs) ' oSender is a Button ' MsgBox("You just clicked the [" & oSender.Text & "] button.", vbOKOnly + vbInformation, "EVENT FEEDBACK") ' ThisApplication.ActiveDocument.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject iLogicVb.RunExternalRule("Spec Reference List") End Sub Private Sub oButton2_Click(ByVal oSender As System.Object, ByVal oEventArgs As System.EventArgs) ' oSender is a Button ' MsgBox("You just clicked the [" & oSender.Text & "] button.",vbOKOnly+vbInformation,"EVENT FEEDBACK") ' iLogicVb.RunExternalRule("Spec Reference List") End Sub Private Sub oTextBox1_Leave(ByVal oSender As System.Object, ByVal oEventArgs As System.EventArgs) If oSender.Text <> oOriginalText Then 'oSender is a TextBox MsgBox("The contents of the TextBox have changed.", vbOKOnly + vbInformation, "EVENT FEEDBACK") End If End Sub Private Sub oCheckBox1_CheckedChanged(ByVal oSender As System.Object, ByVal oEventArgs As System.EventArgs) If oSender.Checked = True Then 'Sender is a CheckBox MsgBox("You just Checked the [" & oSender.Text & "] checkbox.", vbOKOnly + vbInformation, "EVENT FEEDBACK") Else MsgBox("You just UnChecked the [" & oSender.Text & "] checkbox.", vbOKOnly + vbInformation, "EVENT FEEDBACK") End If End Sub Private Sub oComboBox1_SelectedIndexChanged(ByVal oSender As System.Object, ByVal oEventArgs As System.EventArgs) ' oSender is a ComboBox MsgBox("You just chose " & oSender.Text & " from the ComboBox.",vbOKOnly+vbInformation,"EVENT FEEDBACK") End Sub Private Sub oRadioButton1_CheckedChanged(ByVal oSender As System.Object, ByVal oEventArgs As System.EventArgs) If oSender.Checked Then 'oSender is a RadioButton MsgBox("You just changed the Radio Button option to '" & oSender.Text & "'.", vbOKOnly + vbInformation, "EVENT FEEDBACK") Else ' MsgBox("You just changed the Radio Button option to 'Choice 2'.", vbOKOnly + vbInformation, "EVENT FEEDBACK") End If End Sub Private Sub oRadioButton2_CheckedChanged(ByVal oSender As System.Object, ByVal oEventArgs As System.EventArgs) If oSender.Checked Then 'oSender is a RadioButton MsgBox("You just changed the Radio Button option to '" & oSender.Text & "'.", vbOKOnly + vbInformation, "EVENT FEEDBACK") Else ' MsgBox("You just changed the Radio Button option to 'Choice 2'.", vbOKOnly + vbInformation, "EVENT FEEDBACK") End If End Sub End Class
Public Class RunMyForm Private Sub Main Dim oMyForm As New WinForm oMyForm.Show End Sub End Class
Solved by WCrihfield. Go to Solution.
Hi @ndillner343SKL. One important detail here is, how are you launching your Windows Form(s)? Are they originating from an Inventor add-in, or from an iLogic rule, or other? If originating from an iLogic rule, you can pass the iLogic object to your external resource, when you initiate it, or call it to run, one way or another. Such as using Public Read/Write Property(s) that you can set the value to from a rule, or 'input' parameters when calling Public Methods of the Class, which are then used to set the values of Private 'internal use only' variables. The is likely the most common way, if you are wanting to use tools/objects that are unique to the iLogic add-in within other stuff. If it is originating from an add-in, then you may need 2 different things (get the Application object from a higher level shared variable, then use another path for incorporating iLogic stuff).
Edit: There are also a few things you can get directly from the iLogic ApplicationAddIn object itself.
Wesley Crihfield
(Not an Autodesk Employee)
Hi @WCrihfield,
Thank you for the reply. I'm launching it from an iLogic rule and accessing the "ApplicationAddIns" did the trick!
Imports System.Runtime.InteropServices Imports Inventor
Dim ThisApplication As Inventor.Application
ThisApplication = Marshal.GetActiveObject("Inventor.Application")
addin = ThisApplication.ApplicationAddIns.ItemById("{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}") _iLogicVbAutomation = addin.Automation _iLogicVbAutomation.RunExternalRule(ThisApplication.ActiveDocument, "Spec Reference List")
