Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Exporting all parts to DXF
8 REPLIES 8
Message 1 of 9
negutorthik
434 Views, 8 Replies
Hi guys! Help solve the issue. I have a ready - made solution . I need it to be recorded when exporting to a DXF file ( " Name - thickness - Material ) as in the picture (the material is preferably abbreviated) . And it would be better to sort by folders as in Figure 2. I met an approximate solution on the forum somewhere, but not quite correct. Can someone help solve this problem? Or it will give a link to a ready-made working solution.
my text
'define the active document as an assembly file
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
oRevNum = iProperties.Value("Project", "Revision Number")
'make sure that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MessageBox.Show("Please run this rule from the build file.", "iLogic")
Exit Sub
'Getting User input
RUsure = MessageBox.Show ( _
"This will create a DXF file for all the components of the assembly made of sheet metal." _
& vbLf & "This rule assumes that the part file will be saved." _
& vbLf & "Only sheet metal parts for which the specification structure is set to the normal value will be exported" _
& vbLf & " " _
& vbLf & "Are you sure you want to create a DXF for all the components of a sheet metal assembly?" _
& vbLf & " " _
& vbLf & "This may take some time.", "iLogic - Batch Output DXFs ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
Return
Else
'- - - - - - - - - - - - -Component - - - - - - - - - - - -
'look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'process the drawing files for the referenced models
'at the same time, it is expected that the model has been saved
For Each oRefDoc In oRefDocs
'check if the document is a sheet metal part
If oRefDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Continue For
'check if the normal structure of the specification is set
If oRefDoc.ComponentDefinition.BOMStructure <> BOMStructureEnum.kNormalBOMStructure Then Continue For
iptPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "ipt"
'make sure that the model is saved
If(System.IO.File.Exists(iptPathName)) Then
Dim oDrawDoc As PartDocument
oDrawDoc = ThisApplication.Documents.Open(iptPathName, True)
oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName)- 3)
On Error Resume Next
oStyle=oRefDoc.ComponentDefinition.ActiveSheetMetalStyle.Name
oPath = ThisDoc.Path
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'get the path to the target folder DXF
oFolder = oPath & "\" & oAsmName & "-DXP" & "\" & oStyle
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
			Dim activepart As PartDocument = ThisApplication.ActiveDocument
			Dim Sheetmetal As SheetMetalComponentDefinition = activepart.ComponentDefinition
			Dim ThicknessSM As Parameter = Sheetmetal.Thickness
			Dim Thickness As String=ThicknessSM.Value *10 & "mm"
oDataMedium.FileName = oFolder & "\" & oFileName & "  " & "-" & Thickness & "-" & ".dxf"
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oDrawDoc.ComponentDefinition
If oCompDef.HasFlatPattern = False Then
oCompDef.Unfold
Else
oCompDef.FlatPattern.Edit
Dim sOut As String
'sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PR?OFILE"
'sOut = "FLAT PATTERN DXF?AcadVersion=2004&RebaseGeometry=True&OuterProfileLayer=0&OuterProfileLayerColor=0;0;0&InteriorProfilesLayer=0&InteriorProfilesLayerColor=0;0;0&BendDownLayerColor=255;0;0&BendUpLayerColor=255;0;0&BendDownLayerLineType=37641&BendUpLayerLineType=37639IV_BEND;IV_BEND_DOWN;IV_OUTER_PROFILE;IV_INTERIOR_PROFILES;IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_DOWN;IV_ALTREP_FRONT;IV_ALTREP_BACK;IV_ROLL_TANGENT;IV_ROLL&InvisibleLayers=IV_TANGENT;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_UNCONSUMED_SKETCHES"
sOut = "FLAT PATTERN DXF?AcadVersion=2018&MergeOuterContour=True&MergeProfilesIntoPolyline=True&RebaseGeometry=True&Feature" _
           + "&FeatureProfilesLayer=IV_FEATURE_PROFILES&FeatureProfilesLayerColor=0;255;255&FeatureProfilesDownLayer=IV_FEATURE_PROFILES_DOWN&FeatureProfilesDownLayerColor=0;255;255" _
		   + "&InvisibleLayers=IV_TANGENT;IV_BEND;IV_BEND_DOWN;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_ALTREP_FRONT;IV_ALTREP_BACK;IV_UNCONSUMED_SKETCHES;IV_ROLL_TANGENT;IV_ROLL"
oCompDef.DataIO.WriteDataToFile( sOut, oDataMedium.FileName)
oCompDef.FlatPattern.ExitEdit
oDrawDoc.Close
Next
MessageBox.Show("New Files Created in: " & vbLf & oFolder, "iLogic")
'open the folder where the new ffiles are saved
Shell("explorer.exe " & oFolder,vbNormalFocus)
8 REPLIES 8
Message 2 of 9
Hi @negutorthik . Please try this code:
Dim oInvApp As Inventor.Application = ThisApplication
If oInvApp.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
	Exit Sub
Dim oAsmDoc As AssemblyDocument = oInvApp.ActiveDocument
'Getting User input
& vbLf & " " _
& vbLf & " " _
Return
Else
Dim oRefDocs As DocumentsEnumerator = oAsmDoc.AllReferencedDocuments
For Each oRefDoc As Document In oRefDocs
	If Not System.IO.File.Exists(oRefDoc.FullFileName) Then Continue For
	Dim oPDoc As PartDocument = oInvApp.Documents.Open(oRefDoc.FullFileName, True)
	Dim oSheetDef As SheetMetalComponentDefinition = oPDoc.ComponentDefinition
	Dim ThicknessSM As Inventor.Parameter = oSheetDef.Thickness
	oStyle = oSheetDef.ActiveSheetMetalStyle.Name
	Dim oTO As TransientObjects = oInvApp.TransientObjects
	oDataMedium = oTO.CreateDataMedium
	oContext = oTO.CreateTranslationContext
	oOptions = oTO.CreateNameValueMap
	oFolder = oPath & "\" & oAsmName & "-DXP" & "\" & oStyle & "\" & oPDoc.ActiveMaterial.Name & " - " & Thickness
	If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder)
	oDataMedium.FileName = oFolder & "\" & oFileName & ".dxf"
'	oDataMedium.FileName = oFolder & "\" & oFileName & "  " & "-" & Thickness & "- " & activepart.ActiveMaterial.Name & ".dxf"
	If oSheetDef.HasFlatPattern = False Then
		oSheetDef.Unfold
	Else
		oSheetDef.FlatPattern.Edit
	Dim sOut As String
	oSheetDef.DataIO.WriteDataToFile( sOut, oDataMedium.FileName)
	oSheetDef.FlatPattern.ExitEdit
	oPDoc.Close()
Next
Andrii Humeniuk - Leading design engineer
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Message 3 of 9
It doesn 't work a bit . The folder is not being created. Not saved
Message 4 of 9
I made a mistake, fix in line 53: oPDoc.ActiveMaterial.Name to oPDoc.ActiveMaterial.DisplayName
Theoretically, the name of the material may contain characters that are not valid for creating a folder. It needs to be controlled.
Message 5 of 9
What I need! Works well👍
It would be ideal to save to one folder as in Figure 1. Do not create a folder Figure 2
Message 6 of 9
That is, you want the following structure: Folder (Thickness) \ File (Name and Material)?
	Exit Sub
'Getting User input
& vbLf & " " _
& vbLf & " " _
Return
Else
	Dim Thickness As String=ThicknessSM.Value * 10
	oFolder = oPath & "\" & oAsmName & "-DXP" & "\" & oStyle & "\" & Thickness
	oDataMedium.FileName = oFolder & "\" & oFileName & " - " & oPDoc.ActiveMaterial.DisplayName & ".dxf"
		oSheetDef.Unfold
	Else
	Dim sOut As String
	oPDoc.Close()
Next
If I'm wrong, describe how exactly you want to form folders?
Message 7 of 9
No. Everything is as in the first version. Only without the folder, the thickness of the material is my fault. I specified the drawing incorrectly. This is necessary, as shown in Figure 2. Forgive me
Message 8 of 9
I hope this is exactly what you need, because right now I'm just trying to guess what structure you need.
	Exit Sub
'Getting User input
& vbLf & " " _
& vbLf & " " _
Return
Else
	Dim Thickness As String = ThicknessSM.Value * 10 & "mm"
'	oDataMedium.FileName = oFolder & "\" & oFileName & " - " & oPDoc.ActiveMaterial.DisplayName & ".dxf"
	oDataMedium.FileName = oFolder & "\" & oFileName & "  " & " - " & oPDoc.ActiveMaterial.DisplayName & " - " & Thickness & ".dxf"
		oSheetDef.Unfold
	Else
	Dim sOut As String
	oPDoc.Close()
Next
Message 9 of 9
Thank you for your time. Thank you for the resolved issue. The first option is the most correct. I will use it. Thank you very much again
Technology Administrators
