Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Export selected as stp files
3 REPLIES 3
580 Views, 3 Replies
So i have been trying to fix a part of code from my larger ilogic script.
the script gives or should give the ability to select parts or assemblies in an assembly and export them to a desired location. the location etc is chosen via a dll vbform so that works. it detects all the selected parts and names them after completion.
except that when it exports them it exports the assembly multiple times under the file names of the selected items.
help would be greatly appreciated 🙂
Sub SelectedExport(PDFPath As String, oRev As String)
	'Make a ref to active doc
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
'selected components collection
Dim oSelected As ObjectCollection
oSelected = ThisApplication.TransientObjects.CreateObjectCollection
Dim oCount As Integer
oCount = oDoc.SelectSet.Count
'Check that at least 1 is selected
If oCount = 0 Then
	MessageBox.Show("Please select a component.", "iLogic")
	Exit Sub 'bail out
End If
'add to Object Collection
Dim i As Long
For i = 1 To oCount
	If oDoc.SelectSet.Item(i).Type = _
		ObjectTypeEnum.kComponentOccurrenceObject Then
		oSelected.Add (oDoc.SelectSet.Item(i))
	End If
Next
'get step translator
Dim oSTEPTranslator As TranslatorAddIn
oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then
    ' Set application protocol.
    ' 2 = AP 203 - Configuration Controlled Design
    ' 3 = AP 214 - Automotive Design
    oOptions.Value("ApplicationProtocolType") = 3
    ' Other options...
    'oOptions.Value("Author") = ""
    'oOptions.Value("Authorization") = ""
    'oOptions.Value("Description") = ""
    'oOptions.Value("Organization") = ""
    oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
Dim oData As DataMedium
oData = ThisApplication.TransientObjects.CreateDataMedium
'do stuff to the selected files here:
Dim x As Integer = 1
	For Each Item In oSelected
		Dim oCC As ComponentOccurrence = TryCast(oSelected.Item(x), ComponentOccurrence)
		Dim oSelectedDoc As Document
		oSelectedDoc = oCC.Definition.Document
		Dim CurFileName As String
		'get the path and file name of the selected item
		CurFileName = oSelectedDoc.FullFileName
		Dim FNamePos As Long
		FNamePos = InStrRev(CurFileName, "\", -1)
		Dim docFName As String
		docFName = Right(CurFileName, Len(CurFileName) - FNamePos)
		DocName = Left(docFName, Len(docFName) -4)
		'defines backslash as the subdirectory separator
'		Dim strCharSep As String = System.IO.Path.DirectorySeparatorChar
'		'find the postion of the last backslash in the path
'		FNamePos = InStrRev(CurFileName, "\", -1)
'		'get the file name with the file extension
'		Name = Right(CurFileName, Len(CurFileName) - FNamePos)
'		'get the path of the folder containing the file
'		Folder_Location = Left(CurFileName, Len(CurFileName) - Len(Name)-1)
		oData.FileName = PDFPath & "\" & DocName & "_Rev" & iProperties.Value(oSelectedDoc.DisplayName, "Project", "Revision Number") &".stp"
		oSTEPTranslator.SaveCopyAs(oDoc, oContext, oOptions, oData)
		x = x + 1
	Next
End If
'get names item name from collection
For Each oItem In oSelected
	oMsg = oMsg & vbLf & oItem.Name
Next
MessageBox.Show(oCount _
& " Component(s) selected." & vbLf & oMsg, "iLogic")
End Sub
3 REPLIES 3
JhoelForshav
Hi @Anonymous
Try changing the line:
To:
oSTEPTranslator.SaveCopyAs(oSelectedDoc, oContext, oOptions, oData)
oDoc = the main assembly in your code, so the original line just exports that one for each iteration of the loop.
oSelectedDoc represents the document of the selected occurrence, meaning it'll change to be each selected occurrences document throughout the iterations of your loop 🙂
in reply to: JhoelForshav
Thank you for this it helps a lot when picking out parts from massive assemblies. 😄
for anyone interested in the full code and dll you can contact me.
casey_vanwetteringXUMUZ
I would like the full code if it is still available please. Appreciate the help, thanks!
Technology Administrators
