export quantity of specific parts to excel
4 REPLIES 4
rp
303 Views, 4 Replies
We want to export the total quantity of specific parts used in an assembly to excel.
To check if we get the right quantity we first start to get a message with the quantity.
If this is ok we can upgrade the code and write to excel.
We have written a code, but the results of the quantitys is 0.
In the assembly there are parts with differtent quantitys (1 and 2 etc.)
Maybe the approach to the bomquantity is wrong or something.
Here a piece of the code.
Hopefully someone can help us, many thanks.
 If showBOM = vbYes Then
        ' Display BOM quantities in a message box
        For Each oPIDoc In oPIDocs
            Dim bomQuantity As Integer = GetBOMQuantity(oPIDoc)
            MsgBox("BOM Quantity for " & oPIDoc.DisplayName & ": " & bomQuantity)
        Next
    End If
Function GetBOMQuantity(oPIDoc As Document) As Integer
    Dim bomQuantity As Integer = 0
    ' Check if the document has a BOM
    If oPIDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
        Dim asmDoc As AssemblyDocument = oPIDoc
        ' Iterate through all BOM views
        For Each bomView As BOMView In asmDoc.ComponentDefinition.BOM.BOMViews
            ' Iterate through the BOM rows of each BOM view
            For Each bomRow As BOMRow In BOMView.BOMRows
                ' Check if the component is the specified document
                If BOMRow.ComponentDefinitions(1).Document.FullFileName = oPIDoc.FullFileName Then
                    ' Accumulate the total quantity for all occurrences
                    bomQuantity += BOMRow.ItemQuantity
                End If
            Next
        Next
    End If
    Return bomQuantity
End Function
4 REPLIES 4
m_baczewski
in reply to: rp
hi @Anonymous
Do you meet the conditions specified in the "if" statement? Check this using Logger.Info. The problem you described seems to suggest that upon entering the function, the function performs a "Return" operation.
Andrii_Humeniuk
in reply to: rp
Hi @rp . I don't know all the logic behind your program, but from what I can see you would be more comfortable using the AllReferencedOccurrences method to get the number of individual documents. Here is a simple sample iLogic code:
Dim oDoc As Document = ThisDoc.Document
If Not TypeOf oDoc Is AssemblyDocument Then Exit Sub
Dim oAsmDoc As AssemblyDocument = oDoc
Dim oOccs As ComponentOccurrences = oAsmDoc.ComponentDefinition.Occurrences
For Each oRefDoc As Document In oAsmDoc.AllReferencedDocuments
	Dim iQTY As Integer = oOccs.AllReferencedOccurrences(oRefDoc).Count
	If iQTY = 0 Then Continue For
	MsgBox("BOM Quantity for " & oRefDoc.DisplayName & ": " & iQTY)
Next
Andrii Humeniuk - Leading design engineer
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
rp
in reply to: Andrii_Humeniuk
Hi @Andrii_Humeniuk ,
Thanks for the answer,
I think it's better to share to complete code.
That makes it more easier to answer.
In this code everything works fine, the only thing is the quantity in excel document is 0. While i have some parts with multiple quantities.
Thank you very much
Andrii_Humeniuk
in reply to: rp
I commented out the GetBOMQuantityAndWriteToExcel() method (line 91) and added the AllReferencedOccurrences() method (lines 92-93). I hope the changes will help you.
Imports Excel = Microsoft.Office.Interop.Excel
'This ilogic is written to export specific .ipt files with a name (example -PI) to STP & JPG.
'Choose which documents should be exported.
'An Excel file must be created from the exported files in which various properties are created (Title / Subject / Number, etc.)
Sub Main
    If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
        MsgBox("An Assembly Document must be active for this rule to work. Exiting.", vbCritical, "iLogic")
        Exit Sub
    End If
    ' Set the filenames to export
    Dim oMyParamFileName = InputBox("Welke Parts moeten worden geexporteerd, geef een gedeelte van de Filenaam op, bijvoorbeeld:", "Filename", "-PI-")
    ' Set Date
    Dim oMyDate = DateTime.Now.ToString("yyyyMMdd")
    Dim oADoc As Inventor.AssemblyDocument = ThisDoc.Document
	Dim oOccs As ComponentOccurrences = oADoc.ComponentDefinition.Occurrences
    Dim oPath As String = ThisDoc.Path
    Dim oAsmName As String = ThisDoc.FileName(False) 'without extension
    Dim oPIDocs As List(Of Inventor.Document) 'not initiated yet
    Dim oContinue = MsgBox("Do you want to process this whole assembly now?" & vbCrLf & _
        "Yes = PROCESS ALL LEVELS" & vbCrLf & _
        "No = Process Top Level Only" & vbCrLf & _
        "Cancel = Exit Rule Without Proceeding", vbYesNoCancel + vbQuestion, "Export files to .step & .jpg by name?")
    If oContinue = vbCancel Then Exit Sub
    If oContinue = vbYes Then 'process all level
        oPIDocs = oADoc.AllReferencedDocuments.Cast(Of Inventor.Document).Where(Function(Doc) Doc.DisplayName.Contains(oMyParamFileName)).ToList
    ElseIf oContinue = vbNo Then 'process top levels only
        oPIDocs = oADoc.ReferencedDocuments.Cast(Of Inventor.Document).Where(Function(Doc) Doc.DisplayName.Contains(oMyParamFileName)).ToList
    End If
    If IsNothing(oPIDocs) OrElse oPIDocs.Count = 0 Then
        MsgBox("No documents found for the specified criteria. Exiting.", vbInformation, "iLogic")
        Exit Sub
    End If
    ' Set folder name
    Dim oMyParamFilePath = InputBox("Vul hier de mapnaam in waar de files in komen, bijvoorbeeld:", "Mapnaam = Assembly Nr. + opgegeven naam", "Piping")
    ' Set folder
    Dim oFolder As String = oPath & "\" & oAsmName & " " & oMyParamFilePath & " " & oMyDate & "\"
    If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder)
    ' Set the path for the Excel template file
    Dim excelTemplatePath As String = "C:\VaultWerkmap\Templates en settings\Templates\PipingTemplate r00.xltx"
    ' Create a new Excel application
    Dim excelApp As Object = CreateObject("Excel.Application")
    ' Make Excel visible for debugging purposes
    excelApp.Visible = True
    ' Open the Excel template
    Dim workbookTemplate As Object = excelApp.Workbooks.Open(excelTemplatePath)
    ' Select the first worksheet
    Dim worksheet As Object = workbookTemplate.Sheets(1)
    ' Write the header to the Excel sheet
    worksheet.Cells(1, 1).Value = "File Name"
    worksheet.Cells(1, 2).Value = "Title"
    worksheet.Cells(1, 3).Value = "Subject"
    worksheet.Cells(1, 4).Value = "Revision Number"
    worksheet.Cells(1, 5).Value = "Material"
	worksheet.Cells(1, 8).Value = "BOM Quantity" ' New column for BOM Quantity
	' Declare userParamsToFind at the beginning of Sub Main
	Dim userParamsToFind As List(Of String) = New List(Of String) From {"Bendradius", "FormType"}
	  ' Specify user parameters to find and write to Excel sheet
    Dim rowNum As Integer = 2 ' Initialize rowNum before the loop
    For i = 0 To userParamsToFind.Count - 1
        ' Write user parameter details to Excel sheet
        WriteUserParamToExcel(oPIDocs, userParamsToFind(i), worksheet, 1, rowNum, i + 6)
    Next
        ' Setting the file NameProperties
        Dim oTitleProp = oPIDoc.PropertySets("Summary Information").Item("Title").Value
        Dim oSubjectProp = oPIDoc.PropertySets("Summary Information").Item("Subject").Value
        Dim oRevProp = oPIDoc.PropertySets("Summary Information").Item("Revision Number").Value
        Dim oRevnr = "r"
        Dim oFileName As String = System.IO.Path.GetFileNameWithoutExtension(oPIDoc.FullFileName)
        ' Call the Subroutine to get BOM quantity and write to Excel
'        GetBOMQuantityAndWriteToExcel(oPIDoc, worksheet, rowNum, 😎 ' Assuming the next available column is 8
		Dim iQTY As Integer = oOccs.AllReferencedOccurrences(oPIDoc).Count
		worksheet.Cells(rowNum, 8).Value = iQTY
        ' Extract iProperties
        Dim fileName As String = oFileName
        Dim title As String = oTitleProp
        Dim subject As String = oSubjectProp
        Dim revisionNumber As String = oRevnr & oRevProp
		Dim oMatName As String = oPIDoc.ComponentDefinition.Material.Name
        ' Write data to the Excel sheet
        worksheet.Cells(rowNum, 1).Value = fileName
        worksheet.Cells(rowNum, 2).Value = title
        worksheet.Cells(rowNum, 3).Value = subject
        worksheet.Cells(rowNum, 4).Value = revisionNumber
		worksheet.Cells(rowNum, 5).Value = oMatName
 		' Increment rowNum for the next iteration
        rowNum += 1
        Dim oFilePropsName As String = oFolder & oFileName & " " & oTitleProp & " " &  oSubjectProp & " " & oRevnr & oRevProp & " " & oMyDate
        Dim oSTEPFile As String = oFilePropsName & ".stp"
        Dim oJPGFile As String = oFilePropsName & ".jpg"
        'oPIDoc.SaveAs(oSTEPFile, False) 'or use alternative below
        ExportToSTEP(oPIDoc, oSTEPFile)
        oPIDoc.SaveAs(oJPGFile, True)
    Next
    ' Save the modified Excel template
    Dim excelResultPath As String = oFolder & oAsmName & " Piping " & oMyDate & ".xlsx"
    workbookTemplate.SaveAs(excelResultPath)
    workbookTemplate.Close()
    ' Ask the user if they want to open the export folder
    Dim OpenFolder = MessageBox.Show("Export successful! " & _
        "- open containing folder now?", "Open Folder", _
        MessageBoxButtons.YesNo, _
        MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
    If OpenFolder = vbYes Then
        Process.Start("explorer.exe", oFolder)
    End If
End Sub
Sub WriteUserParamToExcel(oPIDocs As List(Of Inventor.Document), userParamNameToFind As String, worksheet As Object, headerRow As Integer, startRow As Integer, colIndex As Integer)
    ' Write header for user parameter to Excel sheet
    worksheet.Cells(headerRow, colIndex).Value = userParamNameToFind
    Dim rowNum As Integer = startRow ' Start from the specified row for data
    For Each oPiDoc In oPIDocs
        ' Find the user parameter in oPiDoc
        Dim userParamToFind As Parameter = Nothing
        For Each param As Parameter In oPiDoc.ComponentDefinition.Parameters
            If param.Name = userParamNameToFind Then
                userParamToFind = param
                Exit For
            End If
        Next
        ' Check if the user parameter was found in oPiDoc
        If Not userParamToFind Is Nothing Then
            ' Retrieve the value of the user parameter
            Dim userParamValueToFind As Object = userParamToFind.Value
            worksheet.Cells(rowNum, colIndex).Value = userParamValueToFind.ToString()
        Else
            ' User parameter not found in oPiDoc
            MsgBox("User Parameter '" & userParamNameToFind & "' not found in the current document.", MsgBoxStyle.Information, "iLogic")
        End If
        rowNum += 1
    Next
End Sub
Sub ExportToSTEP(oDoc As Document, oNewFileName As String)
    Dim oSTEP As TranslatorAddIn
    oSTEP = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
    If IsNothing(oSTEP) Then
        Logger.Debug("STEP Translator Add-in not found.")
        Exit Sub
    End If
    Dim oTO As TransientObjects = ThisApplication.TransientObjects
    Dim oContext As TranslationContext = oTO.CreateTranslationContext
    oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
    Dim oOptions As NameValueMap = oTO.CreateNameValueMap
    Dim oDataMedium As DataMedium = oTO.CreateDataMedium
    If System.IO.File.Exists(oNewFileName) Then
        Dim oAns = MsgBox("A STEP file with this name already exists." & vbCrLf &
        oNewFileName & vbCrLf & _
        "Do you want to overwrite it with this new one?", vbYesNo + vbQuestion + vbDefaultButton2, "STEP FILE EXISTS")
        If oAns = vbNo Then Exit Sub
    End If
    oDataMedium.FileName = oNewFileName
    If oSTEP.HasSaveCopyAsOptions(oDoc, oContext, oOptions) Then
        ' Set application protocol.
        ' 2 = AP 203 - Configuration Controlled Design
        ' 3 = AP 214 - Automotive Design
        oOptions.Value("ApplicationProtocolType") = 3
        oOptions.Value("IncludeSketches") = True
        oOptions.Value("export_fit_tolerance") = 0.000393701 'minimum
        oOptions.Value("Author") = ThisApplication.GeneralOptions.UserName
        'oOptions.Value("Authorization") = ""
        'oOptions.Value("Description") = oDoc.PropertySets.Item(3).Item("Description").Value
        'oOptions.Value("Organization") = oDoc.PropertySets.Item(2).Item("Company").Value
        Try
            oSTEP.SaveCopyAs(oDoc, oContext, oOptions, oDataMedium)
        Catch ex As Exception
            Logger.Error("Error exporting following document to STEP:" & vbCrLf & oDoc.FullDocumentName & vbCrLf & ex.Message)
        End Try
    End If
End Sub
Sub GetBOMQuantityAndWriteToExcel(oPIDoc As Document, worksheet As Object, rowNum As Integer, colIndex As Integer)
        Dim oBOMViews As BOMViews = asmDoc.ComponentDefinition.BOM.BOMViews
        For Each bomView As BOMView In oBOMViews
                    worksheet.Cells(rowNum, colIndex).Value = BOMRow.ItemQuantity
                    Exit Sub ' Exit the loop once the quantity is found
                End If
            Next
        Next
    End If
    ' If no BOM quantity is found, set it to 0
    worksheet.Cells(rowNum, colIndex).Value = 0
End Sub
Technology Administrators
