Hi everyone
I have iLogic which export multiple sheets from idw to PDF's. This iLogic works excellent but problem is that it export all sheets from idw. Sometimes I need only 10 sheets from 30. Have anyone idea how to change iLogic to get possibility to choose few sheets from bulk, for example sheet 1, 3, 5 and 20 to 30? Thanks a lot for help in advance, Greg.
oPath = ThisDoc.Path oFileName = ThisDoc.FileName(False) 'without extension oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _ ("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oDocument = ThisApplication.ActiveDocument oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium 'Define the drawing Dim oDrawing As DrawingDocument oDrawing = ThisDoc.Document Dim oSheet As Sheet Dim lPos As Long Dim rPos As Long Dim sLen As Long Dim sSheetName As String Dim iSheetNumber As Integer 'step through each drawing sheet For Each oSheet In oDrawing.Sheets 'find the seperator in the sheet name:number lPos = InStr(oSheet.Name, ":") 'find the number of characters in the sheet name sLen = Len(oSheet.Name) 'find the sheet name sSheetName = Left(oSheet.Name, lPos -1) 'find the sheet number iSheetNumber = Right(oSheet.Name, sLen -lPos) oOptions.Value("All_Color_AS_Black") = 0 oOptions.Value("Remove_Line_Weights") = 0 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintCurrentSheet 'get PDF target folder path oFolder = Left(oPath, InStrRev(oPath, "\")) & "PDF" 'Check for the PDF folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If 'Set the PDF target file name oDataMedium.FileName = oFolder & "\" & sSheetName & " " & iSheetNumber & ".pdf" oSheet.Activate 'Publish document oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) Next
Solved by WCrihfield. Go to Solution.
You could exclude the sheets from printing, the option is aviable in the sheet properties.
Or create 30 True/False parameter and toggle the variable on and off according to it like so :
If Sheet1Param = True Then ThisDoc.Document.Sheets.Item("Sheet:1").ExcludeFromPrinting = True Else If Sheet1Param = False Then ThisDoc.Document.Sheets.Item("Sheet:1").ExcludeFromPrinting = False End If
You could then create an user form with the 30 parameters..
On your code could add on top of that a check to see if the ExcludeFromPrinting statement is true or not before printing.
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"Hi Laurent
Thank you very much for solution but excluding from printing doesn't exclude it in fact when you do it by iLogic. It only works when you print via standard printing option but then you have one file without these excluded sheets, not separate PDFs files as I need to have.
Second solution could be good, but if you have 50 sheets and you want to make pdfs only for 10 sheets, than clicking YES/NO 50 times is rather not nice and take some time. It is faster to print 50 sheets at once and to delete 40 that you don't need.
I rather thought about solution that could show some small window as in Word, when you can easily choose pages and ranges, e.g. 1-3, 10, 12, 37-42 etc.
Nevertheless thank you very much for help.
The translators options only allow for setting "Custom_Begin_Sheet" & "Custom_End_Sheet" when its "Sheet_Range" is set to "Inventor.PrintRangeEnum.KPrintSheetRange", so the options are somewhat limited for such a long complex listing of pages and page ranges. My advise would be to present the user with an InputBox with multiple lines of very specific instructions for the expected input (specified within the InputBox's Prompt string), so you can enter that complex comma and/or dash separated list of pages you want to publish. Then a block of code right after that which interprets the entered data from that InputBox. Once interpreted, you can assemble an ObjectCollection (or similar) of all the target sheets that you can use as the source of a loop, in which you publish the pages within. Does that make sense to you?
Wesley Crihfield
(Not an Autodesk Employee)
Well, I cannot relate to what you wrote because I don't know enough about iLogic. I feel that you are right but I cannot use it. But thank you very much for help.
I tried to use code below which has dialog box where you can choose sheets. Unfortunately you can choose sheets only using comma, not range what is a pity, because you cannot chose sheets with range 1-10 from 50 sheets in one idw, you must write each sheet separately 1,2,3,4 etc. Secondly it make only one PDF file, not separates PDS.
I tried to mix these two codes but I failed. Mayby you are right and and maybe this is not possible, I don't know.
Dim oDoc As DrawingDocument = ThisDoc.Document Dim oSheet As Sheet Dim i As Integer For i = 1 To oDoc.Sheets.Count oDoc.Sheets(i).ExcludeFromPrinting = True Next Dim NumSheets As Integer = oDoc.Sheets.Count oMessage = "Select the numbers of the sheets to export." & vbCrLf & " Use "","" separator between the range of 1 to " & NumSheets oPrints = InputBox(oMessage, "Export To pdf", "1,2") If oPrints = "" Then Exit Sub For Each wrd As Integer In oPrints.Split(",") oDoc.Sheets(wrd).ExcludeFromPrinting =False Next '-------------------Export pdf-------------------- oPath = ThisDoc.Path PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oOptions.Value("All_Color_AS_Black") = 0 oOptions.Value("Remove_Line_Weights") = 0 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets 'oOptions.Value("Custom_Begin_Sheet") = 1 'oOptions.Value("Custom_End_Sheet") = 1 oDataMedium = ThisApplication.TransientObjects.CreateDataMedium oDrawName = Left(oDoc.DisplayName, Len(oDoc.DisplayName) -4) oDataMedium.FileName = oPath & "\" & oDrawName & ".pdf" Call PDFAddIn.SaveCopyAs(oDoc, oContext, oOptions, oDataMedium) For i = 1 To oDoc.Sheets.Count oDoc.Sheets(i).ExcludeFromPrinting = False Next
Here's an example of what I was talking about with the InputBox and interpreting its returned data to get a usable list of drawing sheets you want to export. I haven't tested it yet, but you can give it a try if you want.
Anyways, this is just an example of an idea of how to specify a complex list of sheet numbers and sheet number ranges as input, similarly to how you would when using the print manager.
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
MsgBox("A Drawing Document must be active for this rule (" & iLogicVb.RuleName & ") to work. Exiting.",vbOKOnly+vbCritical, "WRONG DOCUMENT TYPE")
Exit Sub
End If
Dim oDrawing As DrawingDocument = ThisDrawing.Document
Dim oSheetsCount As Integer = oDrawing.Sheets.Count
Dim oInstructions As String = "Enter the sheet numbers you want to publish to PDF." & vbCrLf & _
"Use commas, to separate individual sheet numbers, and to separate sheet ranges." & vbCrLf & _
"Use a dash (-) between two numbers to specify a sheet range." & vbCrLf & _
"NO SPACES!"
Dim oInputSheets As String = InputBox(oInstructions, "Sheets To Publish", "1-" & oSheetsCount)
'split that string up into an array of individual strings so they can be more easily interpreted
Dim oSheetRanges() As String = Split(oInputSheets, ",")
Dim oSheetCol As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
Dim oRangeStart, oRangeEnd As Integer
For Each oSR As String In oSheetRanges
'check to see if the string includes the "-" character
If oSR.Contains("-") Then
'it is a sheet range, so get the two numbers
oRangeStart = Split(oSR,"-")(0) 'Left(oSR, (InStr(oSR, "-") -1))
oRangeEnd = Split(oSR, "-")(1)
For i = oRangeStart To oRangeEnd
oSheetCol.Add(oDrawing.Sheets.Item(i))
Next
Else
oSheetCol.Add(oDrawing.Sheets.Item(oSR))
End If
Next
Dim oPath As String = IO.Path.GetDirectoryName(oDrawing.FullFileName)
Dim oFileName As String = IO.Path.GetFileNameWithoutExtension(oDrawing.FullFileName)
Dim oFolder As String = Left(oPath, InStrRev(oPath, "\")) & "PDF"
End If
Dim oPDFAddIn As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById _
Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
Dim oSheet As Sheet
Dim lPos As Long
Dim rPos As Long
Dim sLen As Long
For Each oSheet In oSheetCol
oSheet.Activate
'Publish document
oPDFAddIn.SaveCopyAs(oDrawing, oContext, oOptions, oDataMedium)
Next
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click 'LIKE' 👍.
If you have time, please... Vote For My IDEAS :light_bulb:and Explore My CONTRIBUTIONS
Inventor 2021 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
In my defense :
You can create a simple user form like this (with true/false parameters ) :
As I explained you can then excude the sheet from printing by checking if it is excuded or not before printing :
Dim oDoc As DrawingDocument oDoc = ThisApplication.ActiveDocument Dim oSheet As Sheet For Each oSheet In oDoc.Sheets If oSheet.ExcludeFromPrinting = False Then 'Print End If Next
This looks like solid to me and easy to implement...
FINET L.
If this post helped out in any way to solve your question, please drop a "Like"Wow I'm in shock how fast you can write iLogic. Very impressive!
This work almost perfectly. I can choose e.g. 3-8, but cannot choose 3,5 or 3,5,7-10 that means single sheet cannot be printed using comma but, what is interesting, when I write 3-3,5-5 it works, single pages 3 and 5 are printed! Even with this malfuction your iLogic works great, thank you so much.
The message which shows when error occurs is below.
I tried to change sth in code but I made bigger mess than before, it's too high level for me 🙂
I think I've got it fixed right this time. Last time I forgot to convert the String version of the input numbers over to Integer type data before trying to use them as Integers. I created my own 10 page (empty) drawing document to test this code on, and after making these tweaks, I believe I have got the data entry interpretation working correctly now.
When I entered the following into the InputBox:
1,3,5-8,10
it published 7 sheets (Sheet1, Sheet3, Sheet5, Sheet6, Sheet7, Sheet8, & Sheet10), as expected.
Oh, and I added an additional line at the end that re-activates the first sheet in the drawing, because after the code activates each sheet as they are being processed, it was leaving the last sheet in the range active when done, which was annoying.
Se if this is working OK for you now too.
Exit Sub
End If
"NO SPACES!"
oRangeStart = CInt(Split(oSR, "-")(0))
oRangeEnd = CInt(Split(oSR, "-")(1))
For i As Integer = oRangeStart To oRangeEnd
Next
Else
oSheetCol.Add(oDrawing.Sheets.Item(CInt(oSR)))
End If
Next
End If
Dim oSheet As Sheet
Dim lPos As Long
Dim rPos As Long
Dim sLen As Long
oSheet.Activate
'Publish document
Next
'Activate the first sheet again
oDrawing.Sheets.Item(1).Activate
Wesley Crihfield
This rule work good. I do have one question. If you export for eg. 5 out of 10 sheets still in title block have 1 of 10, 2 of 10 etc.. So my question is if you guys can make to change also number of sheets in title block. That would be awesome.
Thank you guys
Dear friend, it works perfectly! Now it is possible to print separate sheets in range as well as single ones. That's great! I didn't expected that this problem can be solved so fast. Thank you very much for help, I think that you helped many people here with this code. Thank you again and best regards! Greg!
I think that you are right but but I need to try to implement your idea what needs many time because I'm not good in iLogic. I will try to follow your tip. I hope I will manage. Thank you for help.
The sheet numbers change sounds like a reasonable request. However, it's not going to be nearly as easy as it sounds.
In the past I believe I have seen others attempt to save each sheet of the drawing out as its own drawing document, just before exporting them to PDF, then delete the extra documents afterwards near the end of the code. That process may get the job done, but may take too much time and seem to be a heavy user of your system's resources.
The difficult thing about this request is that the Textbox within most TitleBlocks that contains the Sheet number and the total number of sheets in the drawing, contains 'live linked' Properties, that aren't readily available to access and modify through normal means. The current sheet number is a 'derived' property called "Sheet Number" and seems to be within a property set called "Sheet Properties". The total number of sheets is a 'derived' property called "Number of sheets", and seems to be within a property set called "Drawing Properties". These seem to be 'hidden' properties that I'm not sure how to access at this time. They aren't listed with all the other iProperties, of either the Drawing document, or the model document.
So, what I'm doing here is just searching within the TitleBlock's sketch for a TextBox that contains the text "SHEET" OR "Sheet" to find the right TextBox. Then I capture its current "FormattedText" value, to save it, so I can restore it later. Then I attempt to change it to something like "SHEET 1 OF 1", just long enough for the export process of that sheet. Then I attempt to restore the original value of that TextBox's FormattedText property, as if nothing has changed. However, after many tweaks and tests, I haven't got it working just right yet.
Here's what I've got so far.
(Beware: I have a couple of your settings commented out and my own settings in place so it will work in my environment. The changes are the oFolder variable and its folder check process, as well as the oDataMedium.FileName setting. You can just un-comment those if you need them, then comment out my version of the oDataMedium.FileName setting, before running it.)
Exit Sub
End If
"NO SPACES!"
Next
Else
End If
Next
''get PDF target folder path
'Dim oFolder As String = Left(oPath, InStrRev(oPath, "\")) & "PDF"
''Check for the PDF folder and create it if it does not exist
'If Not System.IO.Directory.Exists(oFolder) Then
' System.IO.Directory.CreateDirectory(oFolder)
'End If
Dim oSheet As Sheet
Dim lPos As Long
Dim rPos As Long
Dim sLen As Long
Dim oTBDef As TitleBlockDefinition
Dim oSketch As DrawingSketch
Dim oTBox As Inventor.TextBox
Dim oFText As String
oSheet.Activate
' oDataMedium.FileName = oFolder & "\" & sSheetName & " " & iSheetNumber & ".pdf"
oDataMedium.FileName = oPath & "\" & sSheetName & " " & iSheetNumber & ".pdf"
oTBDef = oSheet.TitleBlock.Definition
oTBDef.Edit(oSketch)
For Each oTBox In oSketch.TextBoxes
If oTBox.Text.Contains("SHEET") Or _
oTBox.Text.Contains("Sheet") Then
'save its current FormattedText so we can restore it later
oFText = oTBox.FormattedText
' oTBox.FormattedText = oTBox.FormattedText.Replace(oFText, "SHEET 1 OF 1")
oTBox.FormattedText = oTBox.FormattedText.Replace("<DerivedProperty DerivedID='29704'>Sheet Number</DerivedProperty>", "1")
oTBox.FormattedText = oTBox.FormattedText.Replace("<DerivedProperty DerivedID='29703'>Number of sheets</DerivedProperty>", "1")
'change its Text temporarily for this process
' oTBox.Text = "SHEET 1 OF 1"
'when we exit the For loop right now, we preserve the oTBox variable's value as this TextBox
Exit For
End If
Next
oTBDef.ExitEdit(True)
'Publish document
'now restore the Sheet textbox to original setting
'since I have to redefine oSketch here, I'm also redefining oTBox to be safe
oTBox.FormattedText = oFText
Exit For
End If
Next
Next
Wesley Crihfield
Great rule working great. I know it is difficult, but if you can try if is possible, those exported pdfs to be consolidated and have as i mention earlier 1 of 5, 2 of 5 etc...
Anyway i appreciated you time work and effort. Thank you very much
I believe if other great programmers gives input on this. Also for some people would be great time saver.
Thanks again
OK. I think I understand now. You would like a solution in which all the selected sheets are exported to one multi-page PDF document, right? And you want the title block of each drawing sheet in the new PDF document to show that the total number of sheets is equal to only the number of sheets you exported to the PDF, right? So if you choose sheets 1,3,5-8,10 of 10 possible sheets, you want the PDF document to have 7 pages, and the new Sheet 1 to say "SHEET 1 OF 7" and new last Sheet to say "SHEET 7 OF 7", and so on, right? This is likely doable, but will likely require creating a new drawing document (within the code), then copying those sheets to that new document, then publishing that new drawing document to a single PDF. Then, depending on if we saved the new drawing document or not, we can just delete it at the end, if needed. I don't think it will be as difficult as it sounds. I believe the sheet numbers will correct themselves automatically that way too, as long as the TitleBlock's TextBox for the is laid out the way most are (Sheet Number Of Number of Sheets). It may take a little while, depending on how everything else I'm working on goes. Or someone else may jump in with their own similar solutions too, since Exporting PDF's is a fairly common topic here this forum.
Wesley Crihfield
Yes that is what i mean. You understood very well. Well even with new drawings where sheet numbers will be self created would be good on close new sheet delete or perhaps with option yes or no.
Thanks again
Here's a rule that does the job for me, just as previously described, without having to save or delete the new drawing document it uses. The new drawing document is only loaded in memory during code execution, then is forgotten (instead of saved), so no need to delete it later. Although, I left that bit of code in there (commented out), just in case anyone wanted to keep it. See if it also works for you.
Keep in mind, in this rule, I'm using the same path and file name as the original drawing, but adding " (Selected Sheets)" just before the file extension. You can change that if you want. So it is saving the new PDF to the same directory as the original drawing was in. If that doesn't work for you, you can always edit the oNewName variable in my code, or completely make your own replacement for it. One other change you may notice, is I changed value of the oOption called "Sheet_Range" to ...kPrintAllSheets, so it will include all sheets that have been copied to the new drawing document. Then in the final line of code, I changed that target document from oDrawing to oNewDrawing, to reflect the new variable I created for it.
Here's the new code.
Edit: OH YEAH. I am also specifying a Drawing document template location (variable named oTemplate) on my system for use when creating the new Drawing Document. You will need to change that to point to your own drawing template file. If you don't specify a Template, the first sheet of the new drawing may not have a border or title block around it (unless you add it by code).
Exit Sub
End If
Dim oTemplate As String = ThisApplication.DesignProjectManager.ActiveDesignProject.TemplatesPath & "\A-Size Standard Drawing.idw"
Dim oNewDrawing As DrawingDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, oTemplate, False)
Dim oSheet As Inventor.Sheet
"NO SPACES!"
oDrawing.Sheets.Item(i).CopyTo(oNewDrawing)
Next
Else
oDrawing.Sheets.Item(CInt(oSR)).CopyTo(oNewDrawing)
End If
Next
Dim oNewName As String = oPath & "\" & oFileName & " (Selected Sheets)"
'Try
' oNewDrawing.SaveAs(oNewName & ".idw", False)
'Catch
' MsgBox("Failed to save new drawing as: " & oNewName & ".idw. Exiting.", vbOKOnly, " ")
' Exit Sub
'End Try
'oDataMedium.FileName = oPath & "\" & oFileName & " (Selected Sheets).pdf"
oDataMedium.FileName = oNewName & ".pdf"
Try
'Publish document
oPDFAddIn.SaveCopyAs(oNewDrawing, oContext, oOptions, oDataMedium)
Catch
MsgBox("Failed while trying to export the PDF as: " & oNewName & ".pdf. Exiting.", vbOKOnly, " ")
End Try
Wesley Crihfield
Hello
Where in the string do i change, if i only want the file name and no pagenumber.
Hi @jolantavoigt9563. Which message number above are you using the code from? I need to know that, in order to determine how to change the code for you? One of my favorite lines of code to use, when I just need the exact same path & file name, but need a different file extension, is the following one:
Dim oPDFFileName As String = System.IO.Path.ChangeExtension(oDrawing.FullFileName, ".pdf")
That does not actually change the input document's file name, is just returns a String matching that request. I like to use that line (iLogic/vb.net), instead of the shorter iLogic only shortcut snippet (ThisDoc.PathAndFileName(False)), because the term 'ThisDoc' can often be pointing to a completely different document than you are expecting, and I already have a reference to the exact document I want to use as input.
Wesley Crihfield
