Export multiple sheets to separate PDF's with choosing sheets
25 REPLIES 25
Message 1 of 26
3490 Views, 25 Replies
Hi everyone
I have iLogic which export multiple sheets from idw to PDF's. This iLogic works excellent but problem is that it export all sheets from idw. Sometimes I need only 10 sheets from 30. Have anyone idea how to change iLogic to get possibility to choose few sheets from bulk, for example sheet 1, 3, 5 and 20 to 30? Thanks a lot for help in advance, Greg.
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
'Define the drawing
Dim oDrawing As DrawingDocument
oDrawing = ThisDoc.Document
Dim oSheet As Sheet
Dim lPos As Long
Dim rPos As Long
Dim sLen As Long
Dim sSheetName As String
Dim iSheetNumber As Integer
'step through each drawing sheet
For Each oSheet In oDrawing.Sheets
	'find the seperator in the sheet name:number
	lPos = InStr(oSheet.Name, ":")
	'find the number of characters in the sheet name
	sLen = Len(oSheet.Name)
	'find the sheet name
	sSheetName = Left(oSheet.Name, lPos -1)
	'find the sheet number
	iSheetNumber = Right(oSheet.Name, sLen -lPos)
	oOptions.Value("All_Color_AS_Black") = 0
	oOptions.Value("Remove_Line_Weights") = 0
	oOptions.Value("Vector_Resolution") = 400
	oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintCurrentSheet
	'get PDF target folder path
	oFolder = Left(oPath, InStrRev(oPath, "\")) & "PDF"
	'Check for the PDF folder and create it if it does not exist
	If Not System.IO.Directory.Exists(oFolder) Then
	    System.IO.Directory.CreateDirectory(oFolder)
	End If
	'Set the PDF target file name
	oDataMedium.FileName = oFolder & "\" & sSheetName & " " & iSheetNumber  & ".pdf"
	oSheet.Activate
	'Publish document
	oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Next
Labels (3)
25 REPLIES 25
Message 21 of 26
jolantavoigt9563
This one
Message 22 of 26
@jolantavoigt9563 OK.  That appears to be the original code that @Anonymous first posted at the start of this topic.  That version of the code did not yet include specific sheet selection yet, so I assume that you simply want every sheet exported as a separate PDF, to the same location as the drawing file, and want to keep the sheet name & number as the name of each PDF.  Are you sure you do not want the drawing's original file name included in the PDF file's name, before the sheet name & number?  I will include a line that will include the drawing file's name in there, but keep that line commented out, just in case you may want to use that line instead of the line without it later.  I hope this is what you were looking for.
Dim oDrawing As DrawingDocument = ThisDoc.Document
Dim sPath As String = ThisDoc.Path
Dim sName As String = ThisDoc.FileName(False)
Dim oPDFAddIn As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById _
Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
'these can be set once, before the loop, instead of each time within the loop
Dim OriginalActiveSheet As Sheet = oDrawing.ActiveSheet
For Each oSheet As Sheet In oDrawing.Sheets
	oSheet.Activate
	sSheetName = oSheet.Name.Split(":")(0)
	iSheetNumber = oSheet.Name.Split(":")(1)
	oDataMedium.FileName = sPath & "\" & sSheetName & " " & iSheetNumber & ".pdf"
	'oDataMedium.FileName = sPath & "\" & sName & " " & sSheetName & " " & iSheetNumber  & ".pdf"
	'Publish document
	oPDFAddIn.SaveCopyAs(oDrawing, oContext, oOptions, oDataMedium)
Next
OriginalActiveSheet.Activate
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
Message 23 of 26
Yes, I wanted to export all sheets, thank you for your assistance.
Tags (1)
Message 24 of 26
I'm very new to interacting in this forum, in any forum for that matter, I have always read thru many but never interacted. I have read your profile and we have a lot in common as far as CNC programming and Design engineering, I definitely would appreciate a mentor with your knowledge, is there such a thing in the Autodesk forum as adding someone to follow or add as favorites? Or maybe connect on LinkedIn?
Message 25 of 26
Hi Guys,
I am sorry to ask, but I would like the exported pdf's to be named: filename-sheetname-sheetnumber.dpf
Right now the nameoutput is sheetname-sheetnumber.pdf
Is it possible?
Best regards Morten
Message 26 of 26
Hi @thy_inventorAL62J.  Yes, that is possible.  In fact, that capability was already built into that last code I posted above, but that specific line of code, near the end of the code, was commented out (the line of code started with an apostrophe character).  If you remove the apostrophe (') from the start of that line, and add an apostrophe to the start of the line of code just before that one (or just delete the line of code just before that one), that should make the code work the way you want it to.  However, I slightly modified the code above to meet your needs and have posted the result within the attached text file.
Wesley Crihfield
Technology Administrators
