Dear Inventor Users,
Do you have any idea how can I export an Inventor Part (.ipt) to AutoCAD 3D DWG or DXF using iLogic Rule?
Thank you in advance!
Solved by Michael.Navara. Go to Solution.
The easiest way is just SaveAs DWG
Dim doc As Document = ThisDoc.Document
Dim dwgFileName = System.IO.Path.ChangeExtension(doc.FullFileName,".dwg")
ThisDoc.Document.SaveAs(dwgFileName, True)
Dear Michael,
Thank you very much for your answer.
I tried the rule, and it works very well.
Solved from my point of view.
