Export flat pattern in dxf
r_pruellage
Message 1 of 1
r_pruellage
Hello, i found this code below to export a flat pattern of a sheet ipt in this community.
https://forums.autodesk.com/t5/inventor-programming-ilogic/sheet-metal-dxf-sorting-and-adding-text/t...
This code works good but i have some questions about it:
-is it possible to change the color of the text in the dxf in yellow and change the style of the  text?
-is it possible to add bendnotes on the bendlines in the dxf? In case yes they can be added
 without ° in Angle and without R & Bendradius?
Thanks a lot for you work.
Sub Main
'Trigger = iTrigger0
'Exit Sub
'Get the pathway to the active document
oPath = ThisDoc.Path
FileNameNoExt = ThisDoc.FileName(False) 'without extension
Dim Props As String = AddDXFProperties( True)
Dim aryProps() As String = Split(Props,"\P")
Dim PropVal(3) As String
For i = 0 To UBound(aryProps)
	Dim PropSplitVal() As String = Split(aryProps(i),":")
	PropVal(i) = Trim(PropSplitVal(1))
	PropResults = PropResults & vbNewLine & aryProps(i)
Next
'Vraagt of je de gegevens wil aanpassen (Dit wil ik niet dus daarom uit)
'Answer = MessageBox.Show(PropResults & vbNewLine & vbNewLine & "Would you like edit any of these flat patterns properties?", "Flat Pattern Properties",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
'If Answer = vbYes Then
'	iProperties.Value("Project", "Part Number") = InputBox("Enter the Part Number.", "Part Number", PropVal(0))
'	If Trim(iProperties.Value("Project", "Part Number")) = "" Then Exit Sub
'	iProperties.Value("Summary", "Keywords") = InputBox("Enter the quantity.", "Quantity", PropVal(1))
'	If Trim(iProperties.Value("Summary", "Keywords")) = ""  Then Exit Sub
'	iProperties.Material = InputBox("Enter the Material.", "Material", PropVal(2))
'	If Trim(iProperties.Material) = "" Then Exit Sub
'	'SheetMetal.SetActiveStyle(Matl)
'	iProperties.Value("Project", "Stock Number") = InputBox("Enter the Designer.", "Stock Number", PropVal(3))
'End If
Answer = MessageBox.Show("Would you like to create flat patterns for all parts in the active folder?", "Create Flat Patterns",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
'set condition based on answer
	'See if user wants the files saved upon closing
	SaveDoc = CBool(MessageBox.Show("Do you wish to have the files saved upon closing?", "Save Files?",MessageBoxButtons.YesNo,MessageBoxIcon.Question))
	'Create the DXF for the active document first
	'Call CreateDXF(oPath)
	invApp = GetObject(, "Inventor.Application")
	'Get all File names in the active document's directory
	Dim FileEntries As String() = System.IO.Directory.GetFiles(oPath)
	'Loop through all the files in the active document's directory
	For i = 0 To UBound(FileEntries)
		'MsgBox(FileEntries(i))
		'Make sure the file is a part file.
		Extension = System.IO.Path.GetExtension(FileEntries(i))
		FileName = System.IO.Path.GetFileNameWithoutExtension(FileEntries(i))
		'MsgBox(Extension)
		If Extension = ".ipt" Then
			'Open the current file in the loop
			DwgToOpen = invApp.Documents
			'MsgBox ("Hello " & FileEntries(i))
			DwgToOpen.Open(FileEntries(i))
			ThisApplication.SilentOperation = True
			'See if the part is an iPart
			Dim oiPartDoc As PartDocument
    		oiPartDoc = invApp.ActiveDocument
			If oiPartDoc.ComponentDefinition.IsiPartFactory  Then
				'Create a flat pattern for each iPart Member
				Call LoopThruiParts(oPath)
			Else
				'Create Flat Pattern for the active document
				Call CreateDXF(oPath, FileName)
				Call AddDXFProperties()
				'Do not close the initial file
				If FileNameNoExt <> FileName Then
					Dim DocToClose As Inventor.Document
					DocToClose = invApp.ActiveDocument
					'MsgBox(SaveDoc)
					DocToClose.Close(Not SaveDoc)
	Next
ElseIf Answer = vbNo Then
	Dim iPartDoc As PartDocument
	iPartDoc = ThisDoc.Document
	If iPartDoc.ComponentDefinition.IsiPartFactory  Then
	Else
		Call CreateDXF(oPath, ThisDoc.FileName(False))
ThisApplication.SilentOperation = False
'iLogicVb.UpdateWhenDone = True
End Sub
Dim SaveDoc As Boolean
Dim ShowMsg As Boolean = True
Dim OverwriteFile As Boolean
'Maakt de DXF.
'Vraagt: Overschrijven, Maakt van Part een SheetMetal part, Unfold, Fold en set de DXF properties
Public Sub CreateDXF(oPath As String, sFname As String)
'MsgBox ("Hello CreateDXF")
'The file format will depend on the extension'Set file name extension to ".DXF"
'Create the full path and file name
sFname = oPath & "\" & sFname & ".dxf"
'MsgBox ("Hello Pathway")
'Check to see if the file exists
If System.IO.File.Exists(sFname) Then
	If ShowMsg = True Then
		OverwriteFile = CBool(MessageBox.Show("File " & sFname & " already exists." & vbNewLine & "Would you like to overwrite it ?" & vbNewLine & "This will not be asked again this session." , "Overwrite File",MessageBoxButtons.YesNo,MessageBoxIcon.Question))
	If OverwriteFile = False Then Exit Sub
'Kijkt of het part geschikt is om een sheetmetal bestand van te maken.
'Kan volgens mij uit samen met de stukje 2 kopjes hier onder.
'MsgBox("About to test for file type")
Dim objDoc As Document = ThisApplication.ActiveEditDocument
'Make sure the open document is suitable for sheet metal (Must be a part file)
If objDoc.DocumentType <> kPartDocumentObject Then
	MessageBox.Show("A sheet metal part file must be active to generate the flat pattern.", "Invalid Part File!")
	Exit Sub
'MsgBox("File type confirmed")
'get DXF target folder path
oFolder = oPath
Dim oDoc As PartDocument
'MsgBox("About to Set to Sheet Metal")
oDoc = ThisApplication.ActiveDocument
Dim oCompDef As SheetMetalComponentDefinition
'Try setting the part file to sheet metal
'Kan volgens mij van standaard parts een sheetmetal part maken, de vraag is of dit gewenst is! Zo, niet uitschakelen!
Try
	oCompDef = oDoc.ComponentDefinition
Catch
	Exit Sub
End Try
'MsgBox("Sheet Metal Confirmed")
'Unfold the part file if it is not already unfolded
If oCompDef.HasFlatPattern = False Then
'	MsgBox("ABout to unfold")
	oCompDef.Unfold
'	MsgBox("Unfolded")
Else
'	MsgBox("About to edit flat pattern")
	oCompDef.FlatPattern.Edit
'	MsgBox("Flat pattern confirmed")
'Set properties of the output file. Version of AutoCAD, Bendlines to Cyan, Remove the tangent lines
sOut =        "FLAT PATTERN DXF?AcadVersion=2018" _
			+ "&InteriorProfileLayer=IV_INTERIOR_PROFILES" _
			+ "&InteriorProfilesLayerColor=255;255;0" _
			+ "&OuterProfileLayer=IV_EXTERIOR_PROFILES" _
			+ "&InvisibleLayers=IV_TANGENT" _
			+ "&SimplifySplines=True" _
			+ "&BendLayerLineType=37634" _
			+ "&BendLayerColor=255;255;0" _
			+ "&BendUpLayerLineType=37634" _
			+ "&BendUpLayerColor=255;0;0" _
			+ "&BendDownLayerLineType=37634" _
			+ "&BendDownLayerColor=0;255;0" _
			+ "&FeatureProfilesLayerLineType=37634" _
			+ "&FeatureProfilesLayerColor=255;255;0" _
			+ "&FeatureProfilesUpLayerLineType=37634" _
			+ "&FeatureProfilesUpLayerColor=255;255;0" _
			+ "&FeatureProfilesDownLayerLineType=37634" _
			+ "&FeatureProfilesDownLayerColor=255;255;0"
'Check for the DXF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
	System.IO.Directory.CreateDirectory(oFolder)
'put the flat pattern to a file
'MsgBox("About to create dxf")
oCompDef.DataIO.WriteDataToFile (sOut, sFname)
'MsgBox("dxf created")
'Try switching back to the folded part
Try
    oCompDef.FlatPattern.ExitEdit
Catch
    'MsgBox("Error Exitting Flat Pattern!")
End Try
'MsgBox("switched to folded part")
End Sub
'Haalt de gegevens op zoals PartNummer, Materiaal en Aantal
'Bepaald ook de plaatsing van deze gegevens in de DXF
Public Function AddDXFProperties(Optional JustReturnText As Boolean = False) As String
'Volgende 4 regels uitgeschakeld, de waardes worden verderop bepaald.
'Dim RevisionNo As String = ThisApplication.ActiveDocument.PropertySets.Item("Inventor Summary Information").Item("Revision Number").Value
'Dim Designer As String = ThisApplication.ActiveDocument.PropertySets.Item("Design Tracking Properties").Item("Designer").Value
'Dim sMaterial As String = SheetMetal.GetActiveStyle()
'Dim FileName As String = ThisDoc.FileName(False) 'without extension
'Generate the dxf properties to place in the dxf file as text.
Dim PartNummer As String = "Part Nummer: " & UCase (ThisDoc.FileName(False)) 'false = without extension '(iProperties.Value("Project", "Part Number")) 'without extension
Dim Aantal As String = "Aantal: " & UCase(iProperties.Value("Summary", "Keywords"))
Dim Materiaal As String = "Materiaal: " & UCase(iProperties.Material)
Dim Dikte As String = "Dikte: " & UCase(Thickness)
Dim sText As String = PartNummer & "\P" & Aantal & "\P" & Materiaal & "\P" & Dikte
'Plaatsing tekst
If JustReturnText = False Then
	extents_length = SheetMetal.FlatExtentsLength
	extents_width = SheetMetal.FlatExtentsWidth
	PosX = extents_length/2
	PosY = extents_width/-2
	'Part Nummer
	Call EditDXFFile(PartNummer, PosX, PosY, FileName, "1D5")
	'Aantal
	Call EditDXFFile(Aantal, PosX, PosY - 5, FileName, "1D6")
	'Materiaal
	Call EditDXFFile(Materiaal, PosX, PosY - 10, FileName, "1D7")
	'Dikte
	Call EditDXFFile(Dikte, PosX, PosY - 15, FileName, "1D8")
AddDXFProperties = sText
End Function
'Voegt de tekst toe aan de DXF? Tekstgrote is hier te wijzigen
'Wordt opgeroepen door Public Function AddDXFProperties
Public Sub EditDXFFile(TextToAdd As String, PosX As Double, PosY As Double, FileName As String, IDnumber As String)
	'FileName has No pathway and No Extension
	'Add required text to edit the dxf file (3,55 is de tekstgrote om te wijzigen op het moment)
	Dim RequiredText As String = "TEXT" & vbNewLine & "  5" & vbNewLine & IDnumber & vbNewLine & "330" & vbNewLine & "71"  & vbNewLine & "100"  & vbNewLine & "AcDbEntity" & vbNewLine & "  8" & vbNewLine  & "0" & vbNewLine & "100" & vbNewLine & "AcDbText"  & vbNewLine & " 10" & vbNewLine & PosX  & vbNewLine & " 20"  & vbNewLine & PosY  & vbNewLine & " 30" & vbNewLine & "0.0" & vbNewLine &" 40" & vbNewLine & "3.55" & vbNewLine & "  1" & vbNewLine
	Dim realTextToAdd As String = RequiredText & TextToAdd & vbNewLine & "100" & vbNewLine & "AcDbText" & vbNewLine & "0" & vbNewLine
	Dim textLen As Integer = realTextToAdd.Length()
	FileName = ThisDoc.FileName(False)
	sFname = oPath & "\" & FileName & ".dxf"
	Dim readText As String = System.IO.File.ReadAllText(sFname)
	Dim re As New System.Text.RegularExpressions.Regex("(?<=ENTITIES((?!ENDSEC).)*)ENDSEC", System.Text.RegularExpressions.RegexOptions.Singleline)
	Dim i As Integer = 0
	For Each match In re.Matches(readText)
		readText = readText.Insert(match.Index + textLen * i, realTextToAdd)
		i = i + 1
	Next
	System.IO.File.WriteAllText(sFname, readText)
End Sub
'Plaatsing tekst en waardes ophalen iParts (zou in principe uitgeschakeld kunnen worden)
Public Sub LoopThruiParts(oPath As String)
	'This sub iterates thru all of the Part of an iPart Factory
	'An iPart must be the active document
	'Set Connection to active document
	oiPartDoc = ThisDoc.Document
	'Check to see it it's an iPart
		'Set a reference to the iPart Factory
		Dim oiPartFactory As iPartFactory
		oiPartFactory = oiPartDoc.ComponentDefinition.iPartFactory
		'Loop through all the rows in the iPart table and set that row to the active iPart
		For i = 1 To oiPartFactory.TableRows.Count
			Dim IPF As iPartFactory
			IPF = oiPartDoc.ComponentDefinition.iPartFactory
			Dim oRow As iPartTableRow
			oRow = IPF.TableRows.Item(i)
			IPF.DefaultRow = oRow
			FileName = iProperties.Value("Project", "Part Number")
'			Dim RevNo As String
'			If Val(iProperties.Value("Project", "Revision Number")) <= 0 Then
'				RevNo = "RV:1"
'			Else
'				RevNo = "RV:" & iProperties.Value("Project", "Revision Number")
'			End If
			Dim Materiaal As String = "Materiaal:" & iProperties.Material
			Dim Dikte As String = "Dikte: " & iProperties.Value("Summary", "Keywords")
			Dim Aantal As String = "Aantal: " & iProperties.Value("Summary", "Keywords")
			'Dim Routing As String = "ROUTING: " & RoutingNo
			'Call EditDXFFile(sText, PosX, PosY, FileName, IDnumber)
			'Part Nummer
			'Aantal
			'Materiaal
			'Dikte
		Next
End Sub
Replies (0)
