The .752 x 1.022 x .375 and the .752 x 1.022 x .75 do not work. Everything above
and below work perfectly. I have a form set up. I pick ID, OD, and LENGTH. When I hit
apply, the correct part number and description show up on the form. The dimensions of the part change
for every option except for those 2. When I select either of those 2, the dimensions update,
the part number updates, and the description is blank. The other 38 bushings work perfectly
with the description updating. Any ideas?
'====================================================================== If ID = .752 And OD = .877 And LENGTH = 1.25 Then PART_NUMBER1 = "McMASTER 6391K208" SHAFT_DIA = "3/4" HOUSING_OD = "7/8" DESCRIPTION1 = "OIL EMBEDDED BRONZE BUSHING 3/4 ID X 7/8 OD X 1 1/4 LONG" End If '====================================================================== If ID = .752 And OD = .877 And LENGTH = 1.5 Then PART_NUMBER1 = "McMASTER 6391K207" SHAFT_DIA = "3/4" HOUSING_OD = "7/8" DESCRIPTION1 = "OIL EMBEDDED BRONZE BUSHING 3/4 ID X 7/8 OD X 1 1/2 LONG" End If '======================================================================= If ID = .752 And OD = .877 And LENGTH = 1.625 Then PART_NUMBER1 = "McMASTER 6391K372" SHAFT_DIA = "3/4" HOUSING_OD = "7/8" DESCRIPTION1 = "OIL EMBEDDED BRONZE BUSHING 3/4 ID X 7/8 OD X 1 5/8 LONG" End If '============================================================================================================================================= If ID = .752 And OD = 1.002 And LENGTH = .375 Then PART_NUMBER1 = "McMASTER 6391K261" SHAFT_DIA = "3/4" HOUSING_OD = "1" DESCRIPTION1 = "OIL EMBEDDED BRONZE BUSHING 3/4 ID X 1 OD X 3/8 LONG" End If '======================================================================== If ID = .752 And OD = 1.002 And LENGTH = .75 Then PART_NUMBER1 = "McMASTER 6391K263" SHAFT_DIA = "3/4" HOUSING_OD = "1" DESCRIPTION1 = "OIL EMBEDDED BRONZE BUSHING 3/4 ID X 1 OD X 3/4 LONG" End If '============================================================================================================================================== If ID = .752 And OD = 1.002 And LENGTH = 1 Then PART_NUMBER1 = "McMASTER 6391K265" SHAFT_DIA = "3/4" HOUSING_OD = "1" DESCRIPTION1 = "OIL EMBEDDED BRONZE BUSHING 3/4 ID X 1 OD X 1 LONG" End If '========================================================================== If ID = .752 And OD = 1.002 And LENGTH = 1.5 Then PART_NUMBER1 = "McMASTER 6391K268" SHAFT_DIA = "3/4" HOUSING_OD = "1" DESCRIPTION1 = "OIL EMBEDDED BRONZE BUSHING 3/4 ID X 1 OD X 1 1/2 LONG" End If '========================================================================== If ID = .752 And OD = 1.002 And LENGTH = 2 Then PART_NUMBER1 = "McMASTER 6391K269" SHAFT_DIA = "3/4" HOUSING_OD = "1" DESCRIPTION1 = "OIL EMBEDDED BRONZE BUSHING 3/4 ID X 1 OD X 2 LONG" End If '=====================================================================================
