Export flat pattern dxf for all ipart members
2 REPLIES 2
aurel_e
732 Views, 2 Replies
Hi all
is there any way to export all dxfs from Ipart?
The way I have done it so far is: generate files, insert all them in an assembly, export from assembly using ilogic rule.
I wonder if there is a better way. Another reason to look for it is that Ipart often has got a custom Iproperty called Qty. I fill it from the excel table and would like to have that number in the file name.
Thanks.
2 REPLIES 2
bhavik4244
in reply to: aurel_e
@aurel_e
Here below rule will save all the dxf of the iPart member in the folder where iPart is being saved. Technically if there is a sheet metal component then only a flat pattern or dxf can be developed. So you may iterate this rule as per your need in any occurrences of sheet metal in an assembly.
In order to assign custom properties, you may visit this link: https://forums.autodesk.com/t5/inventor-customization/ilogic-rule-to-update-custom-iproperties-with-...
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
Dim oDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition
Dim oPartMember As iPartMember
For Each oTab As iPartTableRow In oDef.iPartFactory.TableRows
MessageBox.Show(oTab.MemberName, "Name of the Memeber")
iPart.ChangeRow("", oTab.MemberName)
Dim oFeat As PartFeature
For Each oFeat In oDef.Features
	If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
	If oDef.HasFlatPattern = False Then
		oDef.Unfold
	Else
		oDef.FlatPattern.Edit
	End If
	Dim odxf As String
	Dim oPath As String
	oPath = ThisDoc.Path & "\DXF"
	If Not System.IO.Directory.Exists(oPath) Then
		System.IO.Directory.CreateDirectory(oPath)
	End If
	Dim odxfname As String
	odxf = "FLAT PATTERN DXF?OuterProfileLayer=0&OuterProfileLayerColor=0;0;0&InteriorProfilesLayer=0&InteriorProfilesLayerColor=0;0;0&BendDownLayerLineType=37633&BendDownLayerColor=0;0;255&BendUpLayerLineType=37633&BendUpLayerColor=0;0;255IV_BEND;IV_BEND_DOWN;IV_OUTER_PROFILE;IV_INTERIOR_PROFILES;IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_DOWN;IV_ALTREP_FRONT;IV_ALTREP_BACK;IV_ROLL_TANGENT;IV_ROLL&InvisibleLayers=IV_TANGENT;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_UNCONSUMED_SKETCHES" _
		+ "&RebaseGeometry=True" _
		+ "&SimplifySplines=True" _
		+ "&SplineTolerance=0.01" _
	odxfname = oPath & "\"& oTab.MemberName & ".dxf"
	oDef.DataIO.WriteDataToFile(odxf, odxfname)
	oDef.FlatPattern.ExitEdit
	MessageBox.Show("DXF has been saved in this location: " + odxfname)
	Else
	MessageBox.Show("There must be a sheetmetal component to get the dxf file!")
	End If
Next
Next
Bhavik Suthar
dbanksUHFZ7
in reply to: bhavik4244
@bhavik4244
Thanks so much for this post! It was very useful. I am curious, is it possible to run this rule without needing to click ok after each I-part instance has been saved?
Dylan
INV PRO 23
