Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Error while running code
1 REPLY 1
GSK2019
102 Views, 1 Reply
When i run this code I get a error at msgbox ("6")
It runs the code but I get the error
Export failed, contact cad admin
	Try
		excelApp = CreateObject("Excel.Application")
		excelApp.Visible = False
		excelApp.DisplayAlerts = False
MsgBox("1")
		If IO.File.Exists(oExportName) Then IO.File.Delete(oExportName)
		If Dir(oExportName) <> "" Then
			Kill (oExportName)
MsgBox("2")
		Dim strTemplate As String = ThisApplication.DesignProjectManager.ActiveDesignProject.DesignDataPath & "\XLS\en-US\DrawingList Template.xlsx"
		System.IO.File.Copy(strTemplate, oExportName, True)
MsgBox("3")
		'set readonly to false
		Dim fInfo As New FileInfo(oExportName)
		fInfo.IsReadOnly = False
MsgBox("4")
		wb1 = excelApp.Workbooks.Open(oExportName)
		ws1 = wb1.Worksheets(1)
MsgBox("5")
		'Start Traverse
		MainDoc()
		Dim oAsmDoc As AssemblyDocument = ThisDoc.Document
MsgBox("6")
		TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1)
MsgBox("7")
		Dim Rowcounter As Integer = startrow
		Dim strFilename As String = ""
		Dim oProp As Inventor.Property
MsgBox("8")
		'DrawingList Properties
		'Client
		ws1.Cells(2, 6).value = strClient
MsgBox("9")
		'Project Number
		ws1.Cells(3, 6).value =  GetiPropertyValue(oAsmDoc, "Inventor User Defined Properties", "Drawing Number")
MsgBox("10")
		'Author
		ws1.Cells(4, 6).value = ThisApplication.GeneralOptions.UserName
MsgBox("11")
		'Creation Date
		Dim CreationDate As DateTime = DateTime.Now
		Dim CreationDateFormat As String = "dd/MM/yyyy"
		Dim intMinute As String = Now.Minute
		If Now.Minute < 10 Then intMinute = "0" & intMinute
		CreationTime = (Now.Hour) & ":" & intMinute
		ws1.Cells(5, 6).value = CreationDate.ToString(CreationDateFormat + " - " + CreationTime)
MsgBox("12")
		'Row Properties
		Dim Drawdoc As DrawingDocument
		Dim Modeldoc As Document
		Dim HasDrawing As Boolean
		Dim DocType As DocumentTypeEnum
MsgBox("13")
		Dim oProgressbar As Inventor.ProgressBar
		oProgressStep = 1
		oProgressSteps = ModelList.Count - 1
		oProgressStaticText = "Creating excel, please wait"
		oProgressbar = ThisApplication.CreateProgressBar(False, oProgressSteps, "Creating EXCEL")
MsgBox("14")
		For i = 0 To ModelList.Count - 1
			'Document
			If DrawList.Item(i) = "" Then : HasDrawing = False: Else : HasDrawing = True: End If
			If HasDrawing = True Then Drawdoc = ThisApplication.Documents.Open(DrawList.Item(i), False)
			Modeldoc = ThisApplication.Documents.Open(ModelList.Item(i), False)
			DocType = Modeldoc.DocumentType
MsgBox("15")
			If Not (DocType = DocumentTypeEnum.kPartDocumentObject And HasDrawing = False) Then
				'Article Number
				ws1.Cells(Rowcounter, 2).value = GetiPropertyValue(Modeldoc, "Inventor User Defined Properties", "article_number")
MsgBox("16")
				'Drawing Number
				ws1.Cells(Rowcounter, 3).value = GetiPropertyValue(Modeldoc, "Inventor User Defined Properties", "Drawing Number")
MsgBox("17")
				'Rev
				If HasDrawing = True Then ws1.Cells(Rowcounter, 4).value = GetiPropertyValue(Drawdoc, "Inventor Summary Information", "Revision Number")
MsgBox("18")
				'Description
				ws1.Cells(Rowcounter, 5).value = GetiPropertyValue(Modeldoc, "Design Tracking Properties", "Description")
MsgBox("19")
				'IDW
				If HasDrawing = True Then ws1.Cells(Rowcounter, 6).value = ""
				If HasDrawing = False Then ws1.Cells(Rowcounter, 6).value = "X"
MsgBox("20")
				'Document Type
				If DocType = DocumentTypeEnum.kAssemblyDocumentObject Then ws1.Cells(Rowcounter, 7).value = "Assembly"
				If DocType = DocumentTypeEnum.kPartDocumentObject Then ws1.Cells(Rowcounter, 7).value = "Part"
MsgBox("21")
				'Regel opschonen en afsluiten voor volgende regel
				Rowcounter = Rowcounter + 1
				If Not Modeldoc Is oAsmDoc Then Modeldoc.Close(True)
				If HasDrawing = True Then Drawdoc.Close(True)
				Modeldoc = Nothing
				Drawdoc = Nothing
			oProgressStep += 1
			oProgressbar.UpdateProgress
		Next
MsgBox("22")
		'excel schoonmaken
		wb1.Save
		wb1.Close
		'Open Drawlist
		excelApp.Visible = True
		excelApp = Nothing
	Catch
		MsgBox("Export failed, contact cad admin")
		If not wb1 is nothing then wb1.Close
		System.Runtime.InteropServices.Marshal.ReleaseComObject(excelApp)
	End Try
End Sub
Function GetiPropertyValue(doc As Inventor.Document, Propset As String, iProp As String) As String
    Try
        Dim oPropSet As Inventor.PropertySet = doc.PropertySets.Item(Propset)
        Dim oProp As Inventor.Property = oPropSet.Item(iProp)
        GetiPropertyValue = oProp.Value
    Catch
        'MsgBox("Failed to GET iprop:" & vbLf & Propset & vbLf & iProp)
        GetiPropertyValue = "iprop not found"
    End Try
End Function
And I cant figure out how I can fix this, can someone help me?
1 REPLY 1
A.Acheson
in reply to: GSK2019
The document your working with where is that object coming from? What documents are you looking to process and where are you launching the rule?
TraverseAssembly sub routine is missing. The call is here but the code isn't shown. MainDoc is not declared as an object in the code.
Start Traverse
		MainDoc()
MsgBox("6")
Regards
Alan
Technology Administrators
