I'm at a client's and one of the users gets an error when they run iLogic, but no one else gets that error. I Suspect that something is installed incorrectly but I'm not sure what it could be since we've tried Uninstalling
The error is
System.Runtime.InteropServices.COMException (0x80020003): Member not found. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))
at Microsoft.VisualBasic.CompilerServices.LateBinding.LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack)
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Hi! This one does look like install related. What release of Inventor are you on? Inventor 2019 requires .Net 4.7 and Inventor 2018 requires .Net 4.6. Please make sure the proper .Net is installed. Also, all critical Windows updates are installed.
Many thanks!
Hi! Have you installed 2019.3 update?
Many thanks!
