Hi everyone,
I create a rule in ilogic that add assembly in another assembly. It works correctly with other assebly but when I insert that assembly and I start to configure it, inventor show me this error:
What kind of problem is this?
Google translator says:
Error in the rule: OM_Generazione_elementi_R_21, document: TK220106_Assieme_gene ... X Error message Other information
Rule error: OM_Generazlone_elementi_R_21, document: TK220106_Assieme_generazlone.iam
An item with the same key has already been added.
Can you share your code?
The similar message was returned when you use Dictionary and try to add new item with the same key.
Hi, I have probably solved it and it is a typo in the code. i will update you on the development.
