I need to enable or disable one or more rules having checkboxes in an inventor form; true or false
Solved by Curtis_Waguespack. Go to Solution.
Create a True/False parameter to use as a checkbox, then create a rule (let's call that Rule2) and use something like this:
iLogicVb.Automation.GetRule(ThisDoc.Document, "Rule1").IsActive = Rule1_Enabled
Rule1_Enabled is my true/false parameter
I hope this helps.
Curtis
