Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Embedded Spreadsheets and iLogic
15 REPLIES 15
Message 1 of 16
meck
4862 Views, 15 Replies
I have an Embedded spreadsheet in a .ipt file. I want to access the data in it using iLogic, but i keep getting this error...
GoExcel: 3rd Party worksheet not found: "3rd Party:Embedding 1", Sheet: "Sheet1"
Do I need to declare the spreadsheet somehow, or is there something else I missing?
This is the only code I have in the rule...
i = GoExcel.FindRow("3rd Party:Embedding 1", "Sheet1", "ID", "=", 1)
Mike Eck
Master Drafter/ CAD Programmer
Using Inventor 2018
15 REPLIES 15
Message 2 of 16
in reply to: meck
Hi
No need to declare the embedded spreadsheet, i use embedded spreadsheets  and the goexcel code frequently with no problems
Your code looks okay
Did you rename the embedded worksheet in the model browser?
What are the versions of Inventor and Excel you are using? GoExcel does not work with certain combinations (eg INV 2010 and Excel 2000)
Message 3 of 16
meck
in reply to: meck
Thanks for the response!
I did not rename the spreadsheet or the worksheet. I'm using Inventor 2011 and Excel 2003.
Where is it listed what combinations work and which ones do not? I did not see that in the help file. This will be an major benefit to me if I can get this working.
Mike Eck
Using Inventor 2018
Message 4 of 16
MjDeck
in reply to: meck
How did you embed the spreadsheet?  iLogic cannot find it if you use the Insert Object command.  You have to embed it by using the Link button on the Parameters dialog.
Mike Deck
Software Developer
Message 5 of 16
in reply to: meck
Inventor 2010 and beyond needs Excel2003 or Excel2007 so it would seem that is not the problem in your case
Message 6 of 16
meck
in reply to: meck
I'm embedding the spreadsheet using insert because I do not want to have to supply a spreadsheet file along with the part file. Inserting the spreadsheet as an object has the spreadsheet as part of the .ipt and I can just give that file to whomever needs the file.
If there is another way to link a spreadsheet without the external file having to travel with the part I don't know how to do it.
Mike Eck
Using Inventor 2018
Message 7 of 16
MjDeck
in reply to: meck
Remove your existing link.  Then start the Parameters command and hit the Link button.  This gives you the option to Embed instead of Link.  Set the Start Cell to a blank cell that is below your data in the spreadsheet (for instance A50).
After you embed the file this way, it will show up under 3rd Party in the browser.
Mike Deck
Software Developer
Message 8 of 16
meck
in reply to: meck
Excellent!
Worked great!
Thank you!
Mike Eck
Using Inventor 2018
Message 9 of 16
in reply to: meck
I am trying to accomplish something similar to what yu are doing. I want to use an embedded spreadsheet that contains rows with detailed finishing instructions. Each line item is for a different finish and may contain 10 words describing the finish in the cell. I would like to use a custom iProperty multi-value 1-24 so that the designer can choose a finish; lets say Finish "5" from the iProperties tab. Then on file save the iLogic rule would look for line item '5' and return the text in the cell next to it to a user parameter 'item_finish'. Then this 'item_finish' parameter can be used in a drawing sketched symbol to display the text. I don't seem to be able to get the text data from the speadsheet  into the user parameter.
Thank you for any advice....
Mark
Message 10 of 16
meck
Below is an example of how I get values from a embedded spreadsheet to a parameter.
The "C", "D", "B" ... in the code is the spreadsheet's column letter.
I hope this helps.
i = GoExcel.FindRow("3rd Party:Embedding 1", "Sheet1", "PartNo", "=", PartNumber)
Width=GoExcel.CellValue("3rd Party:Embedding 1", "Sheet1", "C" & i)
Length=GoExcel.CellValue("3rd Party:Embedding 1", "Sheet1", "D" & i)
Thickness=GoExcel.CellValue("3rd Party:Embedding 1", "Sheet1", "B" & i)
Angle=GoExcel.CellValue("3rd Party:Embedding 1", "Sheet1", "E" & i)
iProperties.Value("Project", "Part Number")=PartNumber
iProperties.Value("Project", "Description")="SUPPORT BAR " & RoundToFraction(Thickness, 1/16, RoundingMethod.Round) & " X " & RoundToFraction(Width, 1/16, RoundingMethod.Round) & " X " & RoundToFraction(Length, 1/16, RoundingMethod.Round)
Mike Eck
Using Inventor 2018
Message 11 of 16
in reply to: meck
I have similar coding but work with no embedded Excel Sheet.
I have no Idea why the return value is always "-1"  !
The excel file, sheet and column is found . The error only appears when using i to fill the parameters.
Format:HTML Format
Version:1.0
StartHTML: 165
EndHTML: 17041
StartFragment: 314
EndFragment: 17009
StartSelection: 314
EndSelection: 314
MultiValue.List("Bohrbild_Oben")=GoExcel.CellValues("SSH_rev00.xls", "Tabelle1", "W25", "W35")
i=GoExcel.FindRow("SSH_rev00.xls", "Tabelle1", "Ausf2","=",Bohrbild_Oben)
MessageBox.Show(i, Bohrbild_Oben)
' obere Platte
B1=GoExcel.CellValue("SSH_rev00.xls", "Tabelle1", "L"&i)
IfPlattenanzahl=1ThenB2=B6+2*B5ElseB2=GoExcel.CellValue("SSH_rev00.xls", "Tabelle1", "M"&i)
B3=GoExcel.CellValue("SSH_rev00.xls", "Tabelle1", "N"&i)
B4=GoExcel.CellValue("SSH_rev00.xls", "Tabelle1", "O"&i)
B5=GoExcel.CellValue("SSH_rev00.xls", "Tabelle1", "P"&i)
B6=GoExcel.CellValue("SSH_rev00.xls", "Tabelle1", "Q"&i)
B7=GoExcel.CellValue("SSH_rev00.xls", "Tabelle1", "R"&i)
B10=GoExcel.CellValue("SSH_rev00.xls", "Tabelle1", "S"&i)
Zeichnung=GoExcel.CellValue("SSH_rev00.xls", "Tabelle1", "A"&i)
'Unter Platte zum Aufschrauben auf Grundplatte
F6=120mm
F7=150mm
F8=150mm
F9=14.5mm
F10=120mm
'Extrusion
HT=LängeHT-UPlatteDick
Can you help me , please ?
Regards / Thank you
Timo
Message 12 of 16
meck
I get that all the time. It is usually from the "look-up: value not matching the format of the cell it is searching. Try adding CStr() to the value you are searching. For example...
i=GoExcel.FindRow("SSH_rev00.xls", "Tabelle1", "Ausf2","=",CStr(Bohrbild_Oben))
Mike Eck
Using Inventor 2018
Message 13 of 16
in reply to: meck
Thank you meck , However I already tired this . I also copied the row in Excel to another row and put it to TEXT format.
Format:
DimEXLTABAsString="SSH_rev01.xls"
MultiValue.List("Bohrbild_Oben")=GoExcel.CellValues(EXLTAB, "Tabelle1", "W25", "W35")
'MultiValue.SetList("Bohrbild_Oben", "B10130B6250", "B1086B60", "B10180B675", "B1075B6180")
Bohrbild_Oben = "B10180B675"
'i = GoExcel.FindRow("3rd Party:Embedding 2", "Tabelle1", "Ausf2","=",Bohrbild_Oben)
i=GoExcel.FindRow(EXLTAB, "Tabelle1", "Auswahl","=",CStr(Bohrbild_Oben))
' obere Platte
B1=GoExcel.CellValue(EXLTAB, "Tabelle1", "L"&i)
IfPlattenanzahl=1ThenB2=B6+2*B5ElseB2=GoExcel.CellValue(EXLTAB, "Tabelle1", "M"&i)
B3=GoExcel.CellValue(EXLTAB, "Tabelle1", "N"&i)
B4=GoExcel.CellValue(EXLTAB, "Tabelle1", "O"&i)
B5=GoExcel.CellValue(EXLTAB, "Tabelle1", "P"&i)
B6=GoExcel.CellValue(EXLTAB, "Tabelle1", "Q"&i)
B7=GoExcel.CellValue(EXLTAB, "Tabelle1", "R"&i)
B10=GoExcel.CellValue(EXLTAB, "Tabelle1", "S"&i)
Zeichnung=GoExcel.CellValue(EXLTAB, "Tabelle1", "A"&i)
F6=120mm
F7=150mm
F8=150mm
F9=14.5mm
F10=120mm
'Extrusion
 F1F2F3F4F5F6F7F8F9F10B1B2B3B4B5B6B7B10BDHerstellerTypeAusf2Ausf1Auswahl
204605705205          230401010202505013012JC B10130B6250 B10130B6250
104093560XXX          140801210250278612Borg Warner B1086B60 B1086B60
104093560XXX          210100101013751518015EB WED20  B10180B675 B10180B675
104093560XXX          10045121015180137512EB WED20/A100 B1075B6180 B1075B6180
I also try to have the excel list embedded, but error was the same. Is there a bug because Office 2010 and INvento 2011 do not work together ? But then why does the multilist fill function work ?
Regards / Thank you
Timo
Message 14 of 16
meck
I've had this same problem where nothing works. I wrote this code which has not failed, but is a bit slower...
I hope this helps!
Public FunctionGetExcelRow(ExcelPathAsString, SheetNameAsString, ColumnLetterAsString, MatchValueAsString)AsInteger
CellVal="Test"
i=1
DoUntilCellVal=""
CellVal=CStr(GoExcel.CellValue(ExcelPath, SheetName, ColumnLetter&i))
IfMatchValue=CellValThen
GetExcelRow=i
Exit Function
EndIf
i=i+1
Loop
End Function
Mike Eck
Using Inventor 2018
Message 15 of 16
in reply to: meck
Works great meck - Thank you ! Smiley Very Happy
Message 16 of 16
serpennica
in reply to: MjDeck
Excel Embedded, Link thru Fx worked for me. I was using the Manage (tab)/ Insert (panel) / Insert Object (button).
Insert Object does not work for iLogic.
The file came in as "Embedding 3" so excel file name is not carried forward.
When linking you can select to have file "linked" or "embed". That is the check box at bottom of screen. don't miss that.
No i can proceed to write to excel file. still working on that.
