Edit dimension constraints in Controur Flange sketch
Steffen_Hoerup
Steffen_Hoerup
I have an already created Contour Flange as shown below. I would like to verify if the sketch is Fully constraned, and perhaps update the two dimension constraints in the sketch.
I just can't figure out how to hind the sketch.
With the Face Feature in Sheet Metal I can find the sketch in this way:
    Private ReadOnly invApp As Inventor.Application = GetObject(, "Inventor.Application")
    Dim oDoc As Document = invApp.ActiveDocument
    Private Sub GetSketch()
        Dim oPartDef As PartComponentDefinition = oDoc.ComponentDefinition
        Dim oUserParams As UserParameters = oPartDef.Parameters.UserParameters
        Dim oSketch As Sketch = Nothing
        If oDoc.DocumentSubType.DocumentSubTypeID = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
            Dim oSMCompDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition
            If Not oSMCompDef.Thickness.Expression = "thickness" Then
                oUserParams.Item("thickness").Expression = oSMCompDef.Thickness.Expression
            End If
            Dim oSheetMetalFeatures As SheetMetalFeatures = oSMCompDef.Features
            Dim oFace As FaceFeature = oSheetMetalFeatures.FaceFeatures.Item(1)
            oSketch = oFace.Definition.Profile.Parent
        End If
    End Sub
For the Contour Flange I guessed the Path-object where similar the the Profile-object in Face/Extrude. So I tried this:
    Private Sub ContourFlangeSketch()
            End If
            Dim oContourFlange As ContourFlangeFeature = oSheetMetalFeatures.ContourFlangeFeatures.Item(1)
            'Below line does not work - It leads back to Contour Flange1:
            oSketch = oContourFlange.Definition.Path.Item(1).Parent
            'The following loop finds all the Model parameters by name, but not where they are used.
            For i = 1 To oContourFlange.Parameters.Count
                MsgBox(oContourFlange.Parameters.Item(i).Name) 'Feature parameters
            Next
        End If
    End Sub
I have tried modifying above sample to see if the sketch could be found in oCountourFlange."Something"."Sub-Something". But no Success.
To be able to use the same routine for Extrude, Face, Revolve etc. i need to define oSketch, so I can Call a subroutine:
Call UpdateDimensions(oSketch)
I am therefore not keen on using the oContourFlange.Parameters.Item("d0").Expression method
Anyone can give a clue of how to define oSketch for Contour flanges?
Ralf_Krieg
Hello
Try:
oSketch = oContourFlange.Definition.Path.Item(1).SketchEntity.Parent
R. Krieg
RKW Solutions
www.rkw-solutions.com
Steffen_Hoerup
That did the trick, thank you.
So Path is just a shape, that does not relate to the sketch - it just get the information from the lines (sketchEntity)?
It makes sense that the lines parents must be the sketch.
Path object:
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-D17A4244-B04F-42CD-9935-BA2B07FD903E
Sketch Entity:
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-DEAE805D-E81F-4F71-AD23-8486C335F5F3
Ralf_Krieg
Hello
I don't know how this works internal. But a path can also base on one or more Edges instead of SketchLines. Maybe the Path is just a "MetaObject" to present the ContourFlangeFeature always the same type object to create the shape.
R. Krieg
RKW Solutions
