Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Easiest Way to Replace Lost Rules to Parts in Assembly
11 REPLIES 11
Message 1 of 12
Cadderman
740 Views, 11 Replies
Cadderman
Hi all,
We've had a model that has been bouncing back and forth (Pack n Go) between remote users.  At some point there was an error or corrupt file that caused many dialog boxes to occur.  Once dealt with, the result was that all iLogic rules had been removed from every single part.
These iLogic rules are essential for processing our CAD data for material allocation and procurement, so we need them back in.
Is it easy enough to do this?  Ideally I could have it in a form where, in assembly mode I click the part, then click the button on the form for the iLogic rule I want to write to the part.
Can someone please help me write these codes back to the parts?  Unfortunately it's not the same code(s) for every part.  It will differ depending on how the part is fabricated and how many details it has.  Deciding the code will have to be human input.
Thanks in advance.
Hi all,
Thanks in advance.
11 REPLIES 11
Message 2 of 12
WCrihfield
in reply to: Cadderman
WCrihfield
Hi @Cadderman.  I'm not 100% sure, but it sounds like this one specific Autodesk published Inventor Add-In may be able to help you out quite a bit with that task.  It is called "iLogic Rule Batch Tool", and it is essentially free to download and use too.  It can help you re-populate your Inventor documents with local/internal rules, as well as provide a lot of other similar/related functionality.
Wesley Crihfield
(Not an Autodesk Employee)
Wesley Crihfield
Message 3 of 12
WCrihfield
WCrihfield
If using that add-in is not going to be an option, or does not meet your needs, here are some links to some of my contribution posts that you might find useful, or at least informational/interesting.
Copy All Rules From One Document To Another Using An Exteral iLogic Rule
Copy All iLogic Rules & Event Triggers From One Document To Another Using An External iLogic Rule
External iLogic Rule (or VBA Macro) To Create Local iLogic Rule
and here is one for pushing iProperties to all certain type files in a folder, if that may be of use too
Push (Create/Update) iProperty To All Docs (of Selected Type) Within Specified Folder - iLogic
Wesley Crihfield
Wesley Crihfield
Message 4 of 12
Cadderman
Cadderman
Thanks @WCrihfield for responding so quickly! Unfortunately it looks like I can't use any of the contribution posts as the part numbering system is not descriptive.  Picking parts to copy from and to in a windows explorer setting would be difficult this way.
Is there a way to copy ilogic from one part in an assembly to the rest of the parts?  I can copy all similar parts and group them into assemblies for the purpose of this exercise if required.
Message 5 of 12
WCrihfield
WCrihfield
Hi @Cadderman.  I did not have a solution like that already made, so I just created this code for that situation.  I have not tested it yet myself, so you may want to be careful and test it out on some test files first, just to be sure.  Let me know how this works out for you.  I included some lines of comments in there to help guide you about what's going on.  I'm using the Pick method to allow you to manually select which component will be the source of the rules to be copied.  If that is not what you had in mind, we can probably change that part, if necessary.
Sub Main
	If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
		MsgBox("An Assembly Document must be active for this rule to work. Exiting.", vbCritical, "")
		Exit Sub
	Dim oADoc As AssemblyDocument = ThisDoc.Document
	'pick source component with rules to be copied
	oObj = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select Source Component.")
	If IsNothing(oObj) OrElse (TypeOf oObj Is ComponentOccurrence = False) Then Exit Sub
	Dim oSourceOcc As ComponentOccurrence = oObj
	'get the document that the component represents
	Dim oSourceDoc As Document = oSourceOcc.ReferencedDocumentDescriptor.ReferencedDocument
	Dim oAuto As IiLogicAutomation = iLogicVb.Automation
	'get the internal/local rules within that source document
	Dim oSourceRules = oAuto.Rules(oSourceDoc)
	Dim oSourceRule As iLogicRule = Nothing
	'loop through all the assembly's referenced documents
	'AllReferencedDocuments - looks at all levels of the assembly
	'ReferencedDocuments - just looks at top level of assembly
	For Each oRefDoc As Document In oADoc.AllReferencedDocuments
		'skip the source document, so we don't try to overwrite its rules
		If oRefDoc Is oSourceDoc Then Continue For
		'if it is not a Part, then skip to next referenced document
		If oRefDoc.DocumentType <> DocumentTypeEnum.kPartDocumentObject Then Continue For
		'loop through the source rules (if any)
		For Each oSourceRule In oSourceRules
			Dim oTargetRule As iLogicRule = Nothing
			'check if the internal rule already exists in part first
			'if not found, this will NOT throw an error, it will just not set a value
			oTargetRule = oAuto.GetRule(oRefDoc, oSourceRule.Name)
			'if not found, create it
			If IsNothing(oTargetRule) Then
				oTargetRule = oAuto.AddRule(oRefDoc, oSourceRule.Name, "")
				'set text (contents) here so the rule won't immediately run
				oTargetRule.Text = oSourceRule.Text
			Else 'the rule was found, so make sure its text (contents) is up to date
				If oTargetRule.Text <> oSourceRule.Text Then
		Next 'oSourceRule
		'save the referenced document that we copied the rules to
		oRefDoc.Save2(False) 'False = skip saving dependent documents
	Next 'oRefDoc
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS :bulb: or you can Explore My CONTRIBUTIONS
Wesley Crihfield
Sub Main
		Exit Sub
		Next 'oSourceRule
	Next 'oRefDoc
End Sub
Wesley Crihfield
Message 6 of 12
Cadderman
in reply to: WCrihfield
Cadderman
I think this is the solution! I ran it in a test assembly and it copied the code from the source part and wrote it to all the other parts within the assembly.
I can work with this.  I will copy all the similar parts into an assembly and then place a template in the assembly to copy from.
This is much easier than copying and pasting the standard way.  Thank you so much!!!!
Message 7 of 12
Cadderman
Cadderman
Is there a way to run all the rules once they are written?
Message 8 of 12
WCrihfield
WCrihfield
In a way, yes.  I just wasn't sure that was what you wanted, so I set it up in a way that would prevent the rules from immediately running when they were copied over.  At the point in the code where I am using the 'AddRule' method, if I had put the Text or contents of the rule in place, instead of an empty String, it would have immediately ran the new rule it was creating.  So, I just used an empty String in that location, then set the Rule.Text on the next line of code, which does not trigger the rule to run.  I don't know if that is what you had in mind, of if you want a secondary rule to go back through all the components and run the rules after the copy process.  Which scenario did you have in mind?
Keep in mind that when running rules in components while the main assembly is open/active, if those rules are not setup properly, they may be trying to target the main assembly, because it will most likely remain the 'active' document while those rules are running.  So if those rules use the term 'ThisApplication.ActiveDocument' to specify which document they are to act upon, that will most likely be getting the main assembly.  The term 'ThisDoc.Document' is almost always better for use within internal/local rules, because it will default to the 'local' document (the document that the rule is saved within).
Wesley Crihfield
Wesley Crihfield
Message 9 of 12
Cadderman
Cadderman
Edit: Delete
Edit: Delete
Message 10 of 12
Cadderman
Cadderman
@WCrihfield Unfortunately I'm not familiar enough with iLogic to be able to modify the code to include copying event Triggers but you're right - that's what I'm trying to achieve.  If the codes can be copied along with their triggers, they will run when all parts are saved.
I have managed to isolate the area you referred to for "AddRule" and "Rule.Text".  I have read your response multiple times but it's really not sinking in with me unfortunately 😣 I'll keep trying though.  If I don't read from you, thank you for all your assistance so far.  That code is brilliant.
Message 11 of 12
WCrihfield
WCrihfield
Hi @Cadderman.  I have created an alternate version of the code I posted above, and this time I moved these two main processes out into their own Sub routines, which can be called to run from within the main routine.  The one routine copies the rules from the source document to the target document, and the other routine copies the Event Triggers properties from the source document to the target document.
Sub Main
		Exit Sub
		'run our custom routines below
		CopyAllRules(oSourceDoc, oRefDoc)
		CopyAllEventTriggers(oSourceDoc, oRefDoc)
		If oRefDoc.Dirty Then
	Next 'oRefDoc
End Sub
Sub CopyAllRules(oSourceDocument As Document, oTargetDocument As Document)
	If IsNothing(oSourceDocument) Or IsNothing(oTargetDocument) Then Exit Sub
	Dim oSourceRules As IEnumerable = oAuto.Rules(oSourceDocument)
		'check if oTargetRule already exists first
		oTargetRule = oAuto.GetRule(oTargetDocument, oSourceRule.Name)
			oTargetRule = oAuto.AddRule(oTargetDocument, oSourceRule.Name, "")
	Next 'oSourceRule
End Sub
Sub CopyAllEventTriggers(oSourceDocument As Document, oTargetDocument As Document)
	Dim oInternalName As String = "{2C540830-0723-455E-A8E2-891722EB4C3E}"
	'get Event Triggers PropertySet from source document
	Dim oSourceSet As PropertySet = Nothing
	If Not oSourceDocument.PropertySets.PropertySetExists(oInternalName, oSourceSet) Then
		Exit Sub 'the Event Triggers PropertySet was not found in source document, so exit Sub
	If oSourceSet.Count = 0 Then Exit Sub 'it contains zero properties, so exit Sub
	'get or create Event Triggers PropertySet within target document
	Dim oTargetSet As PropertySet = Nothing
	If Not oTargetDocument.PropertySets.PropertySetExists(oInternalName, oTargetSet) Then
		'the Event Triggers PropertySet was not found in source document, so create it
		oTargetSet = oTargetDocument.PropertySets.Add("_iLogicEventsRules", oInternalName)
	'<<<< Could delete target Event Triggers set if found, then create a new one >>>>
	For Each oSourceProp As Inventor.Property In oSourceSet
		'<<< this is not checking if the property may already exist in the target set >>>
		Try
			oTargetSet.Add(oSourceProp.Value, oSourceProp.Name, oSourceProp.PropId)
		Catch
			Logger.Error("Failed to copy property named: " & oSourceProp.Name & vbCrLf & _
			"With value:  " & oSourceProp.Value & vbCrLf & _
			"From source document:  " & oSourceDocument.FullFileName & vbCrLf & _
			"To target document:  " & oTargetDocument.FullFileName)
		End Try
	Next
End Sub
I'm not sure about the part where you want to run all the rules once all the components are saved, but right now I'm thinking about making that a separate rule that would get ran after this one.
Wesley Crihfield
Sub Main
		Exit Sub
	Next 'oRefDoc
End Sub
	Next 'oSourceRule
End Sub
		Try
		Catch
		End Try
	Next
End Sub
Wesley Crihfield
Message 12 of 12
Cadderman
Cadderman
Thank you so much! This is perfect!!
