I'm looking for a code what can generate an Flatpattern DXF automatically by saving the Sheet-Metal file.
the name of the DXF must contain the following Iproperties
- Partnumber (Iproperties, Project, Partnumber)
-SheetmetalDefaults Thickness
-SheetmetalDefaults Material
-Comments (Iproperties, Summary, Comments)
-Project (Iproperties, Project, Project)
-Vendor (Iproperties, Project, Vendor)
Hope something like this is possible. I'm not a programmer but hope someone here can help us 🙂
Justin
Justin
Solved by jwoutersJC4LN. Go to Solution.
Solved by WCrihfield. Go to Solution.
Hi @WCrihfield ,
What we only need are the "IV_OUTER_PROFILE" and "IV_INTERIOR_PROFILES" with line colors white.
All other layers can be invissible or do we not use.
I've tried to delete some layers in de Default but as i said, that's not working. The code do generate a DXF but is placing center points in a circle and bendlines are vissible. That's not working for us. Our machine will cut the part in a few pieces 🙂
hope to see your response!
Hi @WCrihfield ,
Hi @jwoutersJC4LN. I think I have the code prepared for those options now. It seemed to work OK in my tests too. There is a really long line of code in there though, which is for turning off all the other layers besides the two you want to see. Long code is not necessarily a bad thing though, as long as it works the way you want it to, and it can be read and understood later, if changes may be needed. Some of the oFormat stuff may not have been necessary, like setting Color, LineType, and LineWeight, but I included them anyways, just to be thorough. I think those layers would have already been White, and Continuous by default, but on my system it wanted to make the line weight .50 mm thick. After exporting using this code, those layers line weight were .05 mm, instead. And for me there was also a layer named "0" (zero), because it is present on my Inventor side as a Layer in my drawings, but I could easily get rid of that too by adding it to that last long line for oFormat.
Here is the updated code:
Sub Main
If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kPartDocumentObject Then
MsgBox("A Part Document must be active for this rule to work. Exiting.", vbCritical, "")
Exit Sub
End If
Dim oPDoc As PartDocument = ThisDoc.Document
If Not TypeOf oPDoc.ComponentDefinition Is SheetMetalComponentDefinition Then Return
Dim oSMDef As SheetMetalComponentDefinition = oPDoc.ComponentDefinition
Dim oPath As String = System.IO.Path.GetDirectoryName(oPDoc.FullFileName)
'gather values for use in DXF name
Dim oProjSet As PropertySet = oPDoc.PropertySets.Item("Design Tracking Properties")
Dim oPN As String = oProjSet.Item("Part Number").Value
'If oPN is greater than 4 characters, shorten to only last 4 characters
If oPN.Length > 4 Then
oPN = Right(oPN, 4)
End If
Dim oProject As String = oProjSet.Item("Project").Value
Dim oVendor As String = oProjSet.Item("Vendor").Value
Dim oComments As String = oPDoc.PropertySets.Item("Inventor Summary Information").Item("Comments").Value
oComments = oComments & "x"
Dim oMaterial As String = oPDoc.ActiveMaterial.DisplayName
'get Thickness in 'document' units, instead of 'database' units, if they are different units
Dim oThkParam As Inventor.Parameter = oSMDef.Thickness
Dim oUOM As UnitsOfMeasure = oPDoc.UnitsOfMeasure
Dim oThicknessVal As Double
If oThkParam.Units <> "cm" Then
oThicknessVal = oUOM.ConvertUnits(oThkParam.Value, "cm", oThkParam.Units)
Else
oThicknessVal = oThkParam.Value
End If
Dim oThickness As String = CStr(oThicknessVal) & "mm"
'assemble file name
Dim oDXFFileName As String = oPN & "-" & oThickness & "-" & oMaterial & "-" & _
oComments & "-" & oProject & "-" & oVendor
oDXFFileName = oPath & "\" & oDXFFileName & ".dxf"
MsgBox("oDXFFileName = " & oDXFFileName,,"")
Dim oFP As FlatPattern = Nothing
If oSMDef.HasFlatPattern Then
oFP = oSMDef.FlatPattern
Else
Try
oSMDef.Unfold
oSMDef.FlatPattern.ExitEdit
Catch oEx As Exception
MsgBox("Unfold Failed:" & vbCrLf & oEx.Message & vbCrLf & oEx.StackTrace, vbCritical, "UnFold Failed")
Logger.Error("Unfold Failed:" & vbCrLf & oEx.Message & vbCrLf & oEx.StackTrace)
Exit Sub
End Try
End If
ExportFlatPatternToDXF(oFP, oDXFFileName)
End Sub
Sub ExportFlatPatternToDXF(oFlatPattern As FlatPattern, oNewFullFileName As String)
If IsNothing(oFlatPattern) Or oNewFullFileName = "" Then Exit Sub
Dim oDataIO As DataIO = oFlatPattern.DataIO
'<<<< FILL IN FORMAT SETTINGS THE WAY YOU WANT THEM >>>>
Dim oFormat As String
oFormat = "FLAT PATTERN DXF?AcadVersion=2000"
oFormat = oFormat & "&OuterProfileLayerColor=255;255;255" 'White
oFormat = oFormat & "&OuterProfileLayerLineType=37633" 'Continuous
oFormat = oFormat & "&OuterProfileLayerLineWeight=0.00" 'specify value in Centimeters
oFormat = oFormat & "&InteriorProfilesLayerColor=255;255;255" 'White
oFormat = oFormat & "&InteriorProfilesLayerLineType=37633" 'Continuous
oFormat = oFormat & "&InteriorProfilesLayerLineWeight=0.00" 'specify value in Centimeters
oFormat = oFormat & "&InvisibleLayers=IV_TANGENT;IV_ARC_CENTERS;IV_BEND;IV_BEND_DOWN;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_DOWN;IV_ALTREP_FRONT;IV_ALTREP_BACK;IV_UNCONSUMED_SKETCHES;IV_ROLL_TANGENT;IV_ROLL"
Try
oDataIO.WriteDataToFile(oFormat, oNewFullFileName)
MsgBox("New DXF created at:" & vbCrLf & oNewFullFileName, vbInformation, "DXF Created")
Logger.Info("New DXF created at:" & vbCrLf & oNewFullFileName)
'get directory/folder where DXF was saved to
Dim oDirectory As String = System.IO.Path.GetDirectoryName(oNewFullFileName)
'try to open that Directory/Folder in a file browser window
ThisDoc.Launch(oDirectory)
MsgBox("Export Failed:" & vbCrLf & oEx.Message & vbCrLf & oEx.StackTrace, vbCritical, "DXF Export Failed")
Logger.Error("Export Failed:" & vbCrLf & oEx.Message & vbCrLf & oEx.StackTrace)
End Try
End Sub
Wesley Crihfield
(Not an Autodesk Employee)
Sub Main
Exit Sub
End If
oPN = Right(oPN, 4)
End If
Else
End If
'assemble file name
Else
Try
oSMDef.Unfold
Exit Sub
End Try
End If
End Sub
Try
End Try
End Sub
Wesley Crihfield
Hi @WCrihfield
This is exactly what we're looking for. It's working as far i can see!
Thanks a lot for all the work.
Regards, and have a nice day 🙂
Justin
Hi @WCrihfield
Justin
