Drawing sheet iLogic Question
- Mute
- Permalink
- Report
Ok I have 2 questions
1.) If you look at the attached screenshot in the Edit Sheet form there is a sheet "Revision" input field is it possible to fill this out via iLogic?
2.) We have some custom E size sheets (height always 34in width varies 5ft, 6ft, and 8ft) when we select on of these sheet sizes that we created it will display "Custom Size (inch)" when using the sheet property <sheet size> in the title block not the name of that we gave these sheets (Which creatively enough is "E-5ft", "E-6ft", and "E-8ft"). I thought I had this solved by doing this:
Dim oSheetSize As String
oSheetSize = ActiveSheet.Size
If oSheetSize = "Custom" Then
iProperties.Value("Custom", "SheetSize") = "E"
Else iProperties.Value("Custom", "SheetSize") = oSheetSize
End If
then change the titleblock sheet size field from sheet property <sheet size> to custom drawing properties <SheetSize>
this all works great if there is only 1 sheet in the IDW where it fails is if there is more then one sheet. Any ideas on how to fix this?
Thank you
Windows 7 (64 Bit) Pro. SP1, Inventor 2014 Pro, 3D Connexion SpaceNavigator (Driver 3.15.2)
Motherboard: ASUS Rampage IV Extreme x79 Socket 2011
Processor: Intel Core i7 Six Core Sandy Bridge-E 3.2GHz OCed to 4.7GHz (Under Water)
RAM: G.Skill Ripjaw Z-Series 32 gig quad channel of RAM 1800MHz OCed to 2133MHz
Video Card: 2x Nvidia Geforce GTX 770 (Running Six (6) Monitors)
Monitors: [Primary = 2x 24in HD WS][Secondary = 2x 22in HD WS][Tertiary = 2x 19in FS]
Primary Hard Drive: OCZ Vertex IV 256 GB Solid State Drive
Secondary Hard Drive: OCZ Vertex III 120 GB Solid State Drive
