Does anyone know, if it is possible with iLogic to copy the content/properties of welding symbols from one symbol to another?
I read in the forum that welding symbols are not accessible with API, is that still the case?
Background:
We deal sometimes with huge drawings with many welding symbols. In case a plate thicknesses is changed (for what ever reason) the weld symbol has to be adapted, and sometimes it affects many symbols. So I hope there might be a way to not change all welding symbols manually but more elegant similar to the "copy properties" command for dimensions (from the context menu)
Background:
Solved by Michael.Navara. Go to Solution.
In Inventor 2024 was introduced object DrawingWeldingSymbol. And some API support was added.
Thank you.
(Now I hope that I will have Inventor 2024 soon)
Thank you.
