Download files from vault using iLogic
Koekepeerke
Koekepeerke
Hello everyone,
i'm working on an external rule that gets files from the vault to workspace based on only the filename (no path) so they can then be applied for replacement in configurators for example. My knowledge on Vault's API is still very very limited so i basically just started to paste bits and pieces of code from the forums/internet together and to my disbelief i actually got it working. the only problem is it's very slow! I think most time is spent getting the vault path from the filename, acquiring the file is quite fast.
Does anybody know if i'm maybe not using the most efficient method? or maybe my code is just very messy and it needs some proper cleaning/reconstructing to operate better. Any advice or help would be appreciated! I would like for it to run smoothly so we aren't dependent on external add-ins, libraries or .dlls to acces our vault files through iLogic. This way we have a standalone function.
My current rule:
AddReference "Autodesk.Connectivity.WebServices.dll"
Imports AWS = Autodesk.Connectivity.WebServices
AddReference "Autodesk.DataManagement.Client.Framework.Vault.dll"
AddReference "Autodesk.DataManagement.Client.Framework.dll"
Imports VDF = Autodesk.DataManagement.Client.Framework
AddReference "Connectivity.Application.VaultBase.dll"
Imports VB = Connectivity.Application.VaultBase
Dim results1 As VDF.Vault.Results.LogInResult = VDF.Vault.Library.ConnectionManager.LogIn("vault2301", "NXTdimVault", "Administrator", "", VDF.Vault.Currency.Connections.AuthenticationFlags.WindowsAuthentication, Nothing)
If Not results1.Success Then
    MsgBox("Error1")
Dim connection As VDF.Vault.Currency.Connections.Connection = Nothing
connection = results1.Connection
Dim conditions As Autodesk.Connectivity.WebServices.SrchCond()
ReDim conditions(0)
Dim nameOfFile As String = "AE0110931.ipt" '< For now i just inserted the filename but i will do this through rule arguments when i have it running properly.
Dim Defs As Autodesk.Connectivity.WebServices.PropDef() = connection.WebServiceManager.PropertyService.GetPropertyDefinitionsByEntityClassId("FILE")
Dim Prop As Autodesk.Connectivity.WebServices.PropDef = Nothing
For Each def As Autodesk.Connectivity.WebServices.PropDef In Defs
	If def.DispName = "File Name" Then
		Prop = def
		Exit For
Next def
Dim searchCondition As Autodesk.Connectivity.WebServices.SrchCond = New Autodesk.Connectivity.WebServices.SrchCond With { _
   .PropDefId = Prop.Id, _
   .PropTyp = Autodesk.Connectivity.WebServices.PropertySearchType.SingleProperty, _
   .SrchOper = 5, _
   .SrchTxt = nameOfFile _
Dim FileList As List(Of Autodesk.Connectivity.WebServices.File) = New List(Of Autodesk.Connectivity.WebServices.File)()
Dim sBookmark As String = String.Empty
Dim Status As Autodesk.Connectivity.WebServices.SrchStatus = Nothing
conditions(0) = searchCondition
While (Status Is Nothing OrElse FileList.Count < Status.TotalHits)
	Dim files As Autodesk.Connectivity.WebServices.File() = connection.WebServiceManager.DocumentService.FindFilesBySearchConditions(conditions, Nothing, Nothing, True, True, sBookmark, Status)
	If (Not files Is Nothing) Then
		FileList.AddRange(files)
End While
For i = 0 To FileList.Count - 1
	If FileList.Item(i).Name = nameOfFile Then
		iIndex = i
		bItemFound = True
		Exit For
Next
Dim fileke As Autodesk.Connectivity.WebServices.File = FileList.Item(iIndex)
Dim filepaths As Autodesk.Connectivity.WebServices.FilePath() = connection.WebServiceManager.DocumentService.FindFilePathsByNameAndChecksum(fileke.Name, fileke.Cksum)
Dim pad As String = filepaths(0).Path
'MsgBox(pad)
Dim VaultPath As String = pad
Dim folderpath As String
folderpath = VaultPath.Replace("$/", "C:\Workspace\NXTdimVault\")
folderpath = folderpath.Replace("/", "\")
Dim workspacePad As String = folderpath
SplitPath = folderpath.Split("\")
folderpath = SplitPath(0) & "\"
For i = 1 To SplitPath.Length - 2
	folderpath = folderpath & SplitPath(i) & "\"
Next
Dim VaultPaths() As String = New String() {VaultPath }
Dim wsFiels() As AWS.File = connection.WebServiceManager.DocumentService.FindLatestFilesByPaths(VaultPaths)
Dim mFileIt As VDF.Vault.Currency.Entities.FileIteration = New VDF.Vault.Currency.Entities.FileIteration(connection,wsFiels(0))
Dim oSettings As New VDF.Vault.Settings.AcquireFilesSettings(connection)
'oSettings.LocalPath = New VDF.Currency.FolderPathAbsolute(folderpath)
oSettings.LocalPath = New Autodesk.DataManagement.Client.Framework.Currency.FolderPathAbsolute(folderpath)
'Autodesk.DataManagement.Client.Framework.Vault.Currency.FolderPathAbsolute
oSettings.AddFileToAcquire(mFileIt, VDF.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Download)
Dim oResults As VDF.Vault.Results.AcquireFilesResults = connection.FileManager.AcquireFiles(oSettings)
'oResults.FileResults
ThisApplication.Documents.Open(workspacePad)
Jeremy
jani_karjalainenJFQAG
I'm currently working on something same like you were in this post. How long does it take to open the file with this code? If I try it takes over 5 minutes and it still has not opened
