Download files from vault using iLogic
- Mute
- Permalink
- Report
Hello everyone,
i'm working on an external rule that gets files from the vault to workspace based on only the filename (no path) so they can then be applied for replacement in configurators for example. My knowledge on Vault's API is still very very limited so i basically just started to paste bits and pieces of code from the forums/internet together and to my disbelief i actually got it working. the only problem is it's very slow! I think most time is spent getting the vault path from the filename, acquiring the file is quite fast.
Does anybody know if i'm maybe not using the most efficient method? or maybe my code is just very messy and it needs some proper cleaning/reconstructing to operate better. Any advice or help would be appreciated! I would like for it to run smoothly so we aren't dependent on external add-ins, libraries or .dlls to acces our vault files through iLogic. This way we have a standalone function.
My current rule:
AddReference "Autodesk.Connectivity.WebServices.dll" Imports AWS = Autodesk.Connectivity.WebServices AddReference "Autodesk.DataManagement.Client.Framework.Vault.dll" AddReference "Autodesk.DataManagement.Client.Framework.dll" Imports VDF = Autodesk.DataManagement.Client.Framework AddReference "Connectivity.Application.VaultBase.dll" Imports VB = Connectivity.Application.VaultBase
Dim results1 As VDF.Vault.Results.LogInResult = VDF.Vault.Library.ConnectionManager.LogIn("vault2301", "NXTdimVault", "Administrator", "", VDF.Vault.Currency.Connections.AuthenticationFlags.WindowsAuthentication, Nothing) If Not results1.Success Then MsgBox("Error1") End If Dim connection As VDF.Vault.Currency.Connections.Connection = Nothing connection = results1.Connection Dim conditions As Autodesk.Connectivity.WebServices.SrchCond() ReDim conditions(0) Dim nameOfFile As String = "AE0110931.ipt" '< For now i just inserted the filename but i will do this through rule arguments when i have it running properly. Dim Defs As Autodesk.Connectivity.WebServices.PropDef() = connection.WebServiceManager.PropertyService.GetPropertyDefinitionsByEntityClassId("FILE") Dim Prop As Autodesk.Connectivity.WebServices.PropDef = Nothing For Each def As Autodesk.Connectivity.WebServices.PropDef In Defs If def.DispName = "File Name" Then Prop = def Exit For End If Next def Dim searchCondition As Autodesk.Connectivity.WebServices.SrchCond = New Autodesk.Connectivity.WebServices.SrchCond With { _ .PropDefId = Prop.Id, _ .PropTyp = Autodesk.Connectivity.WebServices.PropertySearchType.SingleProperty, _ .SrchOper = 5, _ .SrchTxt = nameOfFile _ } Dim FileList As List(Of Autodesk.Connectivity.WebServices.File) = New List(Of Autodesk.Connectivity.WebServices.File)() Dim sBookmark As String = String.Empty Dim Status As Autodesk.Connectivity.WebServices.SrchStatus = Nothing conditions(0) = searchCondition While (Status Is Nothing OrElse FileList.Count < Status.TotalHits) Dim files As Autodesk.Connectivity.WebServices.File() = connection.WebServiceManager.DocumentService.FindFilesBySearchConditions(conditions, Nothing, Nothing, True, True, sBookmark, Status) If (Not files Is Nothing) Then FileList.AddRange(files) End If End While For i = 0 To FileList.Count - 1 If FileList.Item(i).Name = nameOfFile Then iIndex = i bItemFound = True Exit For End If Next Dim fileke As Autodesk.Connectivity.WebServices.File = FileList.Item(iIndex) Dim filepaths As Autodesk.Connectivity.WebServices.FilePath() = connection.WebServiceManager.DocumentService.FindFilePathsByNameAndChecksum(fileke.Name, fileke.Cksum) Dim pad As String = filepaths(0).Path 'MsgBox(pad) Dim VaultPath As String = pad Dim folderpath As String folderpath = VaultPath.Replace("$/", "C:\Workspace\NXTdimVault\") folderpath = folderpath.Replace("/", "\") Dim workspacePad As String = folderpath SplitPath = folderpath.Split("\") folderpath = SplitPath(0) & "\" For i = 1 To SplitPath.Length - 2 folderpath = folderpath & SplitPath(i) & "\" Next Dim VaultPaths() As String = New String() {VaultPath } Dim wsFiels() As AWS.File = connection.WebServiceManager.DocumentService.FindLatestFilesByPaths(VaultPaths) Dim mFileIt As VDF.Vault.Currency.Entities.FileIteration = New VDF.Vault.Currency.Entities.FileIteration(connection,wsFiels(0)) Dim oSettings As New VDF.Vault.Settings.AcquireFilesSettings(connection) 'oSettings.LocalPath = New VDF.Currency.FolderPathAbsolute(folderpath) oSettings.LocalPath = New Autodesk.DataManagement.Client.Framework.Currency.FolderPathAbsolute(folderpath) 'Autodesk.DataManagement.Client.Framework.Vault.Currency.FolderPathAbsolute oSettings.AddFileToAcquire(mFileIt, VDF.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Download) Dim oResults As VDF.Vault.Results.AcquireFilesResults = connection.FileManager.AcquireFiles(oSettings) 'oResults.FileResults ThisApplication.Documents.Open(workspacePad)
Jeremy
