Hi everybody,
I have created a form in iLogic environment. When from Form one option of the “Cabintype” is selected, the last line must be disabled (photo 13).
How can I do it?
Solved by JelteDeJong. Go to Solution.
hi,
you can do this by adding a "True/False" parameter (for example A2CabinSetter)
and creating a iLogirule to set that parameter.
if (CabineType = "Type A") then A2CabinSetter= False else A2CabinSetter= True end if
when that is setup edit your forum and edit the "Enabeling parameter name" field. set this to the "True/False" parameter. (in my example "A2CabinSetter"). Then it should work.
Jelte de Jong
Blog: hjalte.nl - github.com
if you check the photo, the parameter (for example A2CabinSetter) has been defined as Numeric.
Imagine I have 2 choices in the Form for Cabintype: A and B.
there is a Parameter C (this is a Numeric value).
When I choose A, it must be possible to enter a number for C. But when I choose B, the C must be disabled and I can not enter a number in the box.
It is not possible to define Numeric and True/False for C AT THE SAME TIME.
thanks
i did not want to suggest that you made a parameter "Numeric" and "True/False". I tryed to show that you can make an extra parameter "D" that is of the type "True/False". That parameter can be used to disable and enable the text box of parameter "C" (the "Numeric" parameter)
I have a added an example. (it has been created with inventor 2018)
Jelte de Jong
