I have tried to write a code for getting the part Dimension which get placed in Inventor , I have used Inventor API to retrieve the dimension
The problem is when I use this API , I get all the dimension including Sketch dimension and Part Dimension, but I want that my Drawing sheet should only contain Part dimension not Sketch dimension.
I have tried many ways to get rid of this problem but fail to do so
I also thought to delete the dimension once appear on drawing sheet but unable to do so
This is my code snippet
foreach (DrawingView view in drawingSheet.DrawingViews)
DrawingView view1 = drawingDoc.ActiveSheet.DrawingViews[1];
drawingDoc.ActiveSheet.DrawingDimensions.GeneralDimensions.Retrieve(view1);
for (int i = drawingDoc.ActiveSheet.DrawingDimensions.GeneralDimensions.Count; i > 0; i--)
GeneralDimension dimension = drawingDoc.ActiveSheet.DrawingDimensions.GeneralDimensions[i];
if (dimension.Type == ObjectTypeEnum.) //Don't know what to right after .
dimension.Delete();
I don't know is my method wrong or write , I am not sure what to write in this line
After ObjectTypeEnum such that I can get rid of sketch dimension from Drawing sheet
Also if someone suggest some different and better way for viewing dimension will be a great pleasure
Thankyou in Advance
Solved by Michael.Navara. Go to Solution.
It can be much easier to retrieve only wanted dimensions. You can try this code which retrieves only FeatureDimensions from model
private GeneralDimensionsEnumerator RetrieveModelDimensions(DrawingView drawingView)
var sheet = drawingView.Parent;
var app = sheet.Application as Inventor.Application;
var generalDimensions = sheet.DrawingDimensions.GeneralDimensions;
var dimensionsToRetrieve = app.TransientObjects.CreateObjectCollection();
var retrievableDimensions = generalDimensions.GetRetrievableDimensions(drawingView, null);
foreach (dynamic dimension in retrievableDimensions)
var type = dimension.Type;
//var name = Enum.GetName(typeof(ObjectTypeEnum), type);
if (type == (int)ObjectTypeEnum.kFeatureDimensionObject ||
type == (int)ObjectTypeEnum.kFeatureDimensionProxyObject)
dimensionsToRetrieve.Add(dimension);
var retrievedDimensions = generalDimensions.Retrieve(drawingView, dimensionsToRetrieve);
return retrievedDimensions;
