Determining Content Center Family and Nodes from a Content Center Part
1 REPLY 1
danmorick
283 Views, 1 Reply
I am interested in using the ilogic interface to find out the Content Center path that was used to create a Content Center part.  For example, I have a steel tube, 2"x2"x1/4", 6" long that came from Content Center.  How do I find out (using code) the path that led to it ("Structural Shapes: Square/Rectangular Tubes: ..." etc.?  I would think that this information is held somewhere within that part, since I can perform "Change Size" on it in an assembly and it brings up the correct Content Center destination.
Also, when placing a structural shape using code, how does one indicate how long that member should be?
Any guidance or suggestions related to this would be appreciated.
1 REPLY 1
in reply to: danmorick
Dim InvDoc As Inventor.ApprenticeServerDocument
Dim InvApr As New Inventor.ApprenticeServerComponent
Dim FPath As String
InvDoc = InvApr.Open(FullPathtoFile)
InvDoc.ReferencedDocuments.Item(i).FullFileName     'To find the path of children of an assembly
FPath = InvDoc.FullFileName            'For a single component
This is based on .net and using apprentice so that Inventor does not need to be opened.
I believe you can do the same with
Dim InvDoc As Inventor.Document
Dim InvApr As New Inventor.InventorServer
but will open Inventor
ilogic looks like it will be similar, but I have never used it.
