Due to our manufacturing process, we need to ensure that all marks created on a part are on the A-side of the sheet metal flat pattern.
My concept was to detect the A-side face and the face where the mark was created.
If markFeatures.Count > 0 Then
If sheetMetalComp.FlatPattern IsNot Nothing Then
Dim flatPattern As FlatPattern = sheetMetalComp.FlatPattern
If flatPattern.ASideFace IsNot Nothing Then
Dim asideDef As ASideDefinition = flatPattern.ASideFace
Dim asideFace As Face = asideDef.ASideFace
Dim marksOnASide As Integer = 0
For Each markFeature As MarkFeature In markFeatures
' There so property in Markfeature i can Use
Dim markFace As Face = MarkFeature.
If asideFace.EntityName = markFace.EntityName Then
marksOnASide += 1
End If
Next
However, when reviewing MarkFeature properties, I do not see anything I can use to detect this:
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=GUID-MarkFeature
Could you advise if there is any possible approach to overcome this issue?
Hi @jzarczynski,
Have you looked at the FindUsingRay method? You should be able to get the face that the Mark Feature is on this way and determine if that's the A Side face.
FYI, I haven't worked this out in code yet..... but the FindUsingRay method works well.
Hi, maybe you can try this I do check on the TransientKey.
Dim oDoc As Document = ThisApplication.ActiveDocument Dim oAsideFaces As New List(Of Long) Dim oMarkFaces As New List(Of Long) If oDoc IsNot Nothing Then If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then Dim oPartDoc As PartDocument = oDoc If oPartDoc.ComponentDefinition.Type = ObjectTypeEnum.kSheetMetalComponentDefinitionObject Then Dim oSheetMetalCompDef As SheetMetalComponentDefinition = oPartDoc.ComponentDefinition Dim oFlattPatternExist As Boolean = oSheetMetalCompDef.HasFlatPattern If oFlattPatternExist = True Then Dim oFlatPattern As FlatPattern = oSheetMetalCompDef.FlatPattern Dim oAsideFace As ASideDefinition = oFlatPattern.ASideFace Dim oFace As Face = Nothing For Each oFace In oAsideFace.Faces oAsideFaces.Add(oFace.TransientKey) Next Dim oFeatures As SheetMetalFeatures = oSheetMetalCompDef.Features Dim oMarkFeature As MarkFeature = Nothing For Each oMarkFeature In oSheetMetalCompDef.Features.MarkFeatures For Each oFace In oMarkFeature.Faces oMarkFaces.Add(oFace.TransientKey) Dim commonNames = oAsideFaces.Intersect(oMarkFaces).ToArray() If commonNames.Length = 0 Then MsgBox("Ckeck your part") exit sub End If Next Next End If End If End If End If
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
I ended up solving this exact problem a couple months ago.
Below is a snippet of a much larger, complex laser checker code. You'll have to ignore some of the custom stuff going on, but this functions well. I haven't heard of any false positives or negatives since this was implemented.
We have two styles, a "etch" and a "through" cut, so we need to check for that. (through cuts can be on either side without a problem) You will need to check both the folded and flat patterns to be thorough, as designers can screw that up separately.
'check if etch is on wrong side in folded model
Try
If tPart.Def.features.markfeatures.count > 0 Then 'if mark exists
For Each tfeature In tPart.Def.features.markfeatures 'for each mark feature in folded model
TDef = Tfeature.Definition 'get details of the mark feature
Tstyle = TDef.markgeometrysetitem(1).style 'find which style its using
If Tstyle.name = "Mark Surface" 'we only care if its a mark surface - etch
Tgeom = TDef.markgeometrysetitem(1).geometries 'get geometry that generates it
MarkSketch = tgeom(1).parent 'get sketch that creates geometry
Try
MarkFace = MarkSketch.planarentity 'get the face the mark works on
flattenFace = oFP.getflatpatternentity(MarkFace) 'convert it to the flat pattern equivelent
If flattenFace Is oFP.bottomface Then 'if the flat pattern equivelent is the bottom face of the flat pattern
If ErrorAndOpen(tPart.Path,"has etches on the wrong side!") Then
LaserChecker = True
Exit Function
End If
End If
Catch
If ErrorAndOpen(tPart.Path,"has etches that aren't on the part!") Then
LaserChecker = True
Exit Function
End If
End Try
End If
Next
End If
'check if etch is on wrong side in flat pattern
If oFP.FEATURES.markfeatures.COUNT > 0 Then
For Each Tfeature In oFP.FEATURES.markfeatures
flattenface = MarkSketch.planarentity 'same as above, but skip the flat pattern equivelent step
If errorandopen(tPart.Path,"has etches On the wrong side!") Then
LaserChecker = True
Exit Function
End If
End If
End If
Next
End If
