I have a rule that changes part material assignments from the assembly level (handy). I works by creating an object collection based on manual selections by the user, Ive added in a highlight set as well for usability. My only issue is that I would like something to be removed from the object collection and highlight set if it selected again (i.e. typical way you would un-select something).
Anyone got any hints? Ive attached my code below as well.
Dim oAsset As Asset
Dim oHighlight As Inventor.HighlightSet
oHighlight = ThisDoc.Document.CreateHighlightSet
oHighLight.Color = ThisApplication.TransientObjects.CreateColor(255,105,180)
Dim oAsset_Array As New ArrayList
For Each oAsset_Array_X In ThisApplication.ActiveMaterialLibrary.MaterialAssets
oAsset_Array.Add(oAsset_Array_X.DisplayName)
oAsset_Array.Sort()
Next
'present the user with the list to choose from
oAsset_Array_Selected = InputListBox("CHOOSE MATERIAL FROM ABOVE LIST", oAsset_Array, oAsset_Array.Item(1), "MATERIAL SELECTION", "LIST OF MATERIALS",600,0)
If oAsset_Array_Selected = "" Then
Return
End if
Dim comps As ObjectCollection
Dim comp As Object
comps = ThisApplication.TransientObjects.CreateObjectCollection
While True
comp = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select a component. Press ESC to end selection")
' If nothing gets selected then we're done
If IsNothing(comp) Then Exit While
comps.Add(comp)
Call oHighlight.AddItem(comp)
End While
' If there are selected components we can do something
For Each comp In comps
Dim oDef As PartDocument
oDef = comp.Definition.Document
Dim oRenderStyle As String
oRenderStyle = oAsset_Array_Selected
oDef.ActiveMaterial.DisplayName = oRenderStyle
iLogicVb.UpdateWhenDone = True
Next
oHighlight.Clear
Solved by youann21700. Go to Solution.
Solved by Michael.Navara. Go to Solution.
Hi @youann21700. That 'deselect' process, when using HighlightSet can be tricky to get right. The HighlightSet is also a bit odd to work with in certain situations (stuff can remain highlighted after done with code, when you do not want them to stay highlighted, and can be odd getting them back to normal). You must either use its Clear or its Remove methods to remove stuff that is already in it, but sometimes you may need to update the View to see the results. If working with an ObjectCollection, you can use that with its AddMultipleItems method for faster processing. Below is a link to another similar forum post you may find helpful.
And is another that might be slightly helpful:
Wesley Crihfield
(Not an Autodesk Employee)
I recommend you to use selection API instead of simple Pick and highlight set. There is a full support for select, unselect and so on. Highlighting is included and you have much better control on selection process.
This was a good suggestion, I was trying to avoid doing this since my programming skills are lacking but manged to get it working with some copy/pasting. I've attached my code below for anyone who comes across this in the future. Essentially it just allows you to select parts within an assembly and change their material at the part level, useful for complex assemblies.
Sub Main
oAsset_Array.Sort()
Next
oAsset_Array_Selected = InputListBox("CHOOSE MATERIAL FROM ABOVE LIST", oAsset_Array, oAsset_Array.Item(48), "MATERIAL SELECTION", "LIST OF MATERIALS",600,0)
Return
End If
Dim oSelect As New clsSelect
oSelect.WindowSelect(ThisApplication)
comps = oSelect
For Each comp As ComponentOccurrence In oSelect.SelectedObjects
Next
End Sub
Class clsSelect
Private WithEvents oInteractEvents As InteractionEvents
Private WithEvents oSelectEvents As SelectEvents
Private bTooltipEnabled As Boolean
Private ThisApplication As Inventor.Application
Public SelectedObjects As ObjectsEnumerator
Private stillSelecting As Boolean = True
Public Sub WindowSelect(oApp As Inventor.Application)
ThisApplication = oApp
oInteractEvents = ThisApplication.CommandManager.CreateInteractionEvents
oInteractEvents.InteractionDisabled = False
oSelectEvents = oInteractEvents.SelectEvents
oSelectEvents.AddSelectionFilter(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter)
oSelectEvents.WindowSelectEnabled = True
bTooltipEnabled = ThisApplication.GeneralOptions.ShowCommandPromptTooltips
ThisApplication.GeneralOptions.ShowCommandPromptTooltips = True
oInteractEvents.StatusBarText = "Select components. Shift+Click to unselect. Esc to finish."
oInteractEvents.Start()
While stillSelecting
ThisApplication.UserInterfaceManager.DoEvents()
End While
End Sub
Private Sub oInteractEvents_OnTerminate() Handles oInteractEvents.OnTerminate
ThisApplication.GeneralOptions.ShowCommandPromptTooltips = bTooltipEnabled
oSelectEvents = Nothing
oInteractEvents = Nothing
stillSelecting = False
End Sub
Private Sub oSelectEvents_OnSelect(ByVal JustSelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As View) Handles oSelectEvents.OnSelect
SelectedObjects = oSelectEvents.SelectedEntities
End Sub
Private Sub oSelectEvents_OnUnSelect(UnSelectedEntities As ObjectsEnumerator, SelectionDevice As SelectionDeviceEnum, ModelPosition As Point, ViewPosition As Point2d, View As View) Handles oSelectEvents.OnUnSelect
End Sub
End Class
This is the example I had on hand for this, in case it's of interest.
I hope this helps.
Curtis
Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument Dim oList As New ArrayList Dim oObj As New Object Dim oCollection As ObjectCollection oCollection = ThisApplication.TransientObjects.CreateObjectCollection Dim oHLSet as HighlightSet = oADoc.CreateHighlightSet While True oMsg = "Select parts (press ESC to continue) Count: " & oCollection.Count Dim oOcc As ComponentOccurrence oOcc = ThisApplication.CommandManager.Pick( SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, oMsg) ' If nothing gets selected then we're done If IsNothing(oOcc) Then Exit While 'set occurrence as object so it can be "removed by object" oObj = oOcc 'check against list to prevent 'selecting same component twice If oList.Contains(oOcc.Name) = False Then oList.Add(oOcc.Name) oCollection.Add(oOcc) oHLSet.AddItem(oOcc) Else oList.Remove(oOcc.Name) oCollection.RemoveByObject(oObj) oHLSet.Clear oHLSet.AddMultipleItems(oCollection) End If End While 'do stuff with collection here ' ' 'eventually clear HL set oHLSet.Clear
