Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Delete unresolved files
9 REPLIES 9
Message 1 of 10
GeorgK
8369 Views, 9 Replies
Hello together,
I have a phantom "unresolved reference" in an assembly. I could not see it in the assembly. When I open the assembly I get an error message that a file is missing. In the assembly I could find it with this code:
https://forums.autodesk.com/autodesk/attachments/autodesk/78/546430/1/UnresolvedFiles.txt
Is it possible to delete it with a peace of code?
Thank you very much
Georg
9 REPLIES 9
Message 2 of 10
Balaji_Ram
in reply to: GeorgK
Hi Georg,
Sorry, the FileDescriptor does not permit removing the file reference.
But, you can replace the reference if you do have an backup or a old file that shares its heritage.
http://adndevblog.typepad.com/manufacturing/2012/08/replace-the-file-reference-by-inventor-api.html
Does the file descriptor "FullFileName" return a file path that you recognise ?
That should return the last known path for a file reference that is missing.
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
Message 3 of 10
GeorgK
in reply to: Balaji_Ram
Hello Balaji,
I found the old post and did replaced the file now. It would be gread to delete files.
Georg
Message 4 of 10
Balaji_Ram
in reply to: GeorgK
Hi Georg,
Glad that you replaced the file reference.
I think, providing the delete on the File reference can cause more issues that it solves.
File references are best managed internally by Inventor since it would be quite easy to get things wrong with file references.
Also, I think it is for this reason that Inventor API does not let us delete it manually.
Balaji
Balaji
Message 5 of 10
rossano_praderi
in reply to: GeorgK
Hi Georg,
if I've understood your question...this is my answer...
I don't think you need more explanations about the follow code, if you need I'm there
Public Sub DelOccurrence()
    Dim oAsmCompDef As AssemblyComponentDefinition
    Set oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
    Dim ref As ComponentOccurrence
For Each ref In oAsmCompDef.Occurrences
    If ref.ReferencedDocumentDescriptor.ReferenceMissing = True Then
        ref.Delete
Next
End Sub
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
Message 6 of 10
GeorgK
in reply to: rossano_praderi
Hello Rossano,
thank you very much. Thats exactly what I am looking for 🙂
Georg
Message 7 of 10
Balaji_Ram
in reply to: GeorgK
Sorry if my reply was misleading.
I had interpreted your query as that of directly deleting the file references.
Balaji
Balaji
Message 8 of 10
maximeURGVK
Message 9 of 10
If you doesn't use anything else than this subroutine ("DelOccurence") the simple solution is to replace "Public Sub DelOccurence" with "sub Main" and remove the "Set" statement.
Bregs
Rossano Praderi
Message 10 of 10
in reply to: maximeURGVK
Hi, hope this answer works besides the long time you've been posted.
You are working in the wrong environment. This code it's supposed to work very fine in VBA, not in iLogic.
iLogic runs pretty similar VBA but with limitations.
Give the chance to work combining both solutions and you will see how easy those codes works for your intentions.
Cheers.
Tags (1)
