We have loads of imported files that have the translation report in the model browser under the 3rd Party browser node. I'd like to delete it while doing some other housekeeping tasks but so far i cant figure out how this is done. Trying to delete the browser nodes results in an error. Any clues?
Cheers
Craig
Solved by Vladimir.Ananyev. Go to Solution.
References to the embedded translation reports are stored in the ReferencedOLEFileDescriptors collection and could be deleted using ReferencedOLEFileDescriptor.Delete method:
Sub Test() Dim oDoc As PartDocument Set oDoc = ThisApplication.ActiveDocument Dim oDescr As ReferencedOLEFileDescriptor Set oDescr = oDoc.ReferencedOLEFileDescriptors.Item(1) Debug.Print "Display name: " & oDescr.DisplayName oDescr.Delete End Sub
So it could be easily included into your workflow.
Best regards,
Vladimir thank you. Works perfect.
Hey,
This iLogc rule is exactly what i need.
I get the following error
Errror on line 3: Set instructions arren't longer supported
Errror on line 6: Set instructions arren't longer supported
Errror on line 8: Method argument must be in parentheses
I couldn't discover why the set instruction isn't longer supported.
Anybody suggestions?
