I am using Inventor 2024.1.1 and I have the following iLogic code, in which I am trying to delete certain images from a drawing border. I have confirmed that the loop is finding the correct images that I am trying to delete (I did this by adding msgbox(sketchImg.Name) inside the If statement in the For loop, and it does show the correct names of the images I want to delete). However, the images are not actually getting deleted. The program is also not erroring out. It seems as if the "sketchImg.Delete()" line simply isn't actually doing anything.
I am wondering if anybody could give me any insight into this. Perhaps I am just missing something simple? Any thoughts are very much appreciated!
'Get the drawing document and its first sheet Dim doc As DrawingDocument = ThisApplication.ActiveDocument Dim sht As Sheet = doc.Sheets(1) 'Get the sheet's border Dim border As Border = sht.Border 'Get the border's definition, sketch, and sketch images Dim borderDef As BorderDefinition = border.Definition Dim borderSketch As DrawingSketch = borderDef.Sketch Dim sketchImages As SketchImages = borderSketch.SketchImages 'Edit the border by deleting the barcodes borderDef.Edit(borderSketch) For Each sketchImg As SketchImage In sketchImages If sketchImg.Name.ToUpper().Contains("MYIMAGE") sketchImg.Delete() End If Next borderDef.ExitEdit(True)
It took me a few tries but just one simple thing incorrect. The Drawing sketch being edit was incorrectly set. It should be picked up as a variable when the definition is edited. Looking at the border sketch object the tool tip indicates a read only status.
The manual object selection using pick command was a starting point to diagnose as the object was being deleted correctly using that method.
'Dim selectedObj As SketchImage = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllEntitiesFilter, "Select a drawing view")
'selectedObj.Delete
'Get the doc's definition it is the same as getting the sheets border definition as they are linked.
'Dim borderDef As BorderDefinition = doc.BorderDefinitions.Item("image border")
'Declare object as a Drawing Sketch otherwise cannot access the objects.
For Each sketchImg As SketchImage In borderSketch.SketchImages
Try
sketchImg.Delete
Catch
Logger.Info("Error deleting.")
End Try
Next
