Hello All. Again, i am in deed of some programming assistance. i am writing code to delete a bunch of components from an assembly based on certain criteria. the code is working but it takes a while. for example, 30 seconds to delete 60 parts. however, if i choose the same components/parts interactively by a window, they delete in less than 10 seconds. so i thought that maybe by making a collection set, like for a pattern for example, i could delete them all at once and it would be quicker... however, i am stumbling on deleting the collection.is this possible? i assume there must be some way to delete all at once but....
Dim DELETE_THESE As ObjectCollection = oTO.CreateObjectCollection Dim oObjects_R As ObjectCollection = oTO.CreateObjectCollection
If InStr(CLEAR_BOX_NAME, "FLAT-CH") Or InStr(CLEAR_BOX_NAME, "-RA-")Then 'DELETE CHANNELS FOR S02 Logger.Debug("CHANNEL" & CLEAR_BOX_NAME) DELETE_THESE.Add(oCc23.Name) End If If oCc23.ActiveModelState = "NO_HOLES" Then 'Logger.Debug("let's move..." & oOcc.Name) DELETE_THESE.Add(oCc23.Name) End If If InStr(CLEAR_BOX_NAME, "BC") >0 Then Logger.Debug ("let delete it") End If Next HOW_MANY = DELETE_THESE.Count Logger.Debug("WE ARE DELETEING..." & HOW_MANY) 'For Each occName In DELETE_THESE ' Components.Delete(occName) 'Next Components.Delete(DELETE_THESE)
as always, any help/suggestions are gladly appreciated!
Solved by WCrihfield. Go to Solution.
Hi @tmathieson. Although there are several methods for dealing with collections of components at one time, I do not believe there is a built-in method for deleting a collection of components at one time. However, there is still a pretty simple way to do it. You will want to 'clear' the assembly's SelectSet first. Then use SelectSet.SelectMultiple method to add your ObjectCollection to it. Then execute the "AppDeleteCmd" command.
Wesley Crihfield
(Not an Autodesk Employee)
Hey @WCrihfield , thanks ! this got me on the correct track. had looked at selectset but couldn't figure out how to declare/initialize it. with your guidance, and digging around some more, it is now performing! have included the updated code here in case it might be useful to other...
Dim DELETE_THESE As ObjectCollection = oTO.CreateObjectCollection Dim oObjects_R As ObjectCollection = oTO.CreateObjectCollection For Each oCc23 As ComponentOccurrence In oCD.Occurrences 'Dim doc As Document = oCc.Definition.Document CLEAR_BOX_NAME = oCc23.Name ' LOGGER.Debug(CLEAR_BOX_NAME) If InStr(CLEAR_BOX_NAME, PROJECT_NUMBER) >0 And InStr(CLEAR_BOX_NAME, "FLAT") Or InStr(CLEAR_BOX_NAME, "SPLICE") >0 Or _ InStr(CLEAR_BOX_NAME, "BC") >0 Then 'Or InStr(CLEAR_BOX_NAME, "-S") >0 Dim oPartdoc As ComponentOccurrence oPartdoc = oCc23 DELETE_THESE.Add(oPartdoc) Logger.Debug("OTHER..." & CLEAR_BOX_NAME) Continue For End If If InStr(CLEAR_BOX_NAME, "FLAT-CH") Or InStr(CLEAR_BOX_NAME, "-RA-")Then 'DELETE CHANNELS FOR S02 Logger.Debug("CHANNEL" & CLEAR_BOX_NAME) Dim oPartdoc As ComponentOccurrence oPartdoc = oCc23 DELETE_THESE.Add(oPartdoc) 'DELETE_THESE.Add(oCc23.Name) End If If oCc23.ActiveModelState = "NO_HOLES" Then Dim oPartdoc As ComponentOccurrence oPartdoc = oCc23 DELETE_THESE.Add(oPartdoc) End If Next HOW_MANY = DELETE_THESE.Count Logger.Debug("WE ARE DELETEING..." & HOW_MANY) Try AssyDoc.SelectSet.Clear Catch ex As Exception Logger.Debug("set not cleared") End Try AssyDoc.SelectSet.SelectMultiple(DELETE_THESE) ThisApplication.CommandManager.ControlDefinitions.Item("AppDeleteCmd").Execute DELETE_THESE.Clear AssyDoc.Save End Sub
again, thanks for your help! saved me from pulling more hair out :+) !
