- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello. I have problem defining model for views in my code. It works for parts, but not for assemblies. I have code that will save the part up, then make drawing from it and places views. For some reason, it have problem just with assemblies.
Code:
Dim oDrawingDoc As DrawingDocument oDrawingDoc = ThisApplication.ActiveDocument Dim oSheet As Sheet oSheet = oDrawingDoc.Sheets.Item(1) Dim doc = ThisDoc.Document If doc.DocumentType = kPartDocumentObject Then oWrite = System.IO.File.CreateText("C:\Users\ondra\OneDrive\Dokumenty\Inventor\Trans-technik\Nemazat3-iLogic.txt") oWrite.WriteLine(oFilePather & iProperties.Value("Project", "Part Number") & ".ipt") oWrite.Close() End If If doc.DocumentType = kAssemblyDocumentObject Then oWrite = System.IO.File.CreateText("C:\Users\ondra\OneDrive\Dokumenty\Inventor\Trans-technik\Nemazat4-iLogic.txt") oWrite.WriteLine(oFilePather & iProperties.Value("Project", "Part Number") & ".iam" ) oWrite.Close() End If If doc.DocumentType = kPartDocumentObject Then oRead = System.IO.File.OpenText("C:\Users\ondra\OneDrive\Dokumenty\Inventor\Trans-technik\Nemazat3-iLogic.txt") EntireFile1 = oRead.ReadLine() oRead.Close() oPartName = EntireFile1 End If If doc.DocumentType = kAssemblyDocumentObject Then oRead = System.IO.File.OpenText("C:\Users\ondra\OneDrive\Dokumenty\Inventor\Trans-technik\Nemazat4-iLogic.txt") EntireFile2 = oRead.ReadLine() oRead.Close() oPartName = EntireFile2 End if Dim oModel As PartDocument = ThisApplication.Documents.Open("C:\Users\ondra\OneDrive\Dokumenty\Inventor\TransTechnik\" & oPartName, False) '***Base View*** Dim oPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Height / 2-5, oSheet.Width / 2) Dim oView As DrawingView = oSheet.DrawingViews.AddBaseView(oModel, oPoint, 1#, ViewOrientationTypeEnum.kDefaultViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle) '***ProjectedViews*** Dim oPoint2 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oView.Center.X + 10, oView.Center.Y) Dim oPoint3 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oView.Center.X, oView.Center.Y - 10) Dim oPoint4 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oView.Center.X +20, oView.Center.Y) Dim oView2 As DrawingView = oSheet.DrawingViews.AddProjectedView(oView, oPoint2, DrawingViewStyleEnum.kFromBaseDrawingViewStyle) Dim oView3 As DrawingView = oSheet.DrawingViews.AddProjectedView(oView, oPoint3, DrawingViewStyleEnum.kFromBaseDrawingViewStyle) Dim oView4 As DrawingView = oSheet.DrawingViews.AddBaseView(oModel, oPoint4, 1#, ViewOrientationTypeEnum.kIsoTopRightViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle) oView.Name = "POHLED1" oView2.Name = "POHLED2" oView3.Name = "POHLED3" oView4.Name = "POHLED4"
