Cycle Driven Dimension based on Parameter
 I need to be able to cycle between dim1 and dim2 based on the model range. So if the model= 1 or 2, then use Gauge_dim1 but if the model= 2 or 3, then disable Gauge_dim1 and use Gauge_dim2. What would the code look like to accomplish this?
*edit corrected model range
 I need to be able to cycle between dim1 and dim2 based on the model range. So if the model= 1 or 2, then use Gauge_dim1 but if the model= 3 or 4, then disable Gauge_dim1 and use Gauge_dim2. What would the code look like to accomplish this?
