Test an input value for number
I have a macro which takes an input from a user form text box and stores it as a Double.  I need a way to test the input to make sure it is numerical before storing it, as it crashes the macro if the user enters a non-numerical input.  Is there a simple way to test for numerical input?  Thanx.
Curtis_Waguespack
Hi LonesomeJoe,
You can use IsNumeric for this.
I hope this helps.
Curtis
Here's an iLogic example.
oInput = InputBox("Enter a number", "iLogic", "")
numericCheck = IsNumeric(oInput)
If numericCheck = True Then
MessageBox.Show("Input is numeric", "iLogic")
Else
MessageBox.Show("Input is NOT numeric.", "iLogic")
VBA example:
Public Sub NumericCheck()
Dim NumericCheck As Boolean
NumericCheck = IsNumeric(oInput)
If NumericCheck = True Then
MsgBox ("Input is numeric")
Else
MsgBox ("Input is NOT numeric.")
End Sub
Thanx, Curtis!  I knew there was a way to do this but I could not remember WHAT it was!  Thanx.
estringer
Is there a way to get the numeric value from the InputBox and start PartsListNumber from that or add it to the PartsListNumber? I found some code that takes all of the parts lists from a DWG and creates a new tab in Excel for each instance but I would like to have some control over the numbering of the tabs so that the tabs align with the actual location/floor level on our project. See the code below.
		oInput = InputBox("Input the first floor level number below", "First Floor Level", "")
		Else
        'specify the start cell
        oOptions.Value("StartingCell") = "A" & startRow
        'specify the XLS tab name
        'here the file name is used
        oOptions.Value("TableName") = "Embeds For Level-" & PartsListNumber 'without extension
        'choose to include the parts list title row
        'in this example "Ye Old List of Parts" is written to the StartingCell
        oOptions.Value("IncludeTitle") = False
        'choose to autofit the column width in the xls file
        oOptions.Value("AutoFitColumnWidth") = True
        ' export the Partslist to Excel with options
        oPartslist.Export(fileName, PartsListFileFormatEnum.kMicrosoftExcel, oOptions)
        PartsListNumber = PartsListNumber + 1
WCrihfield
Have you tried Val("StringNumericalValue"), or CDblAny("StringNumericalValue").  Both of those are in the 'System' iLogic snippets, under Strings.  But both are for returning Double (not Integer) data type from a String.  You could then attempt to convert the Double to an Integer using something like CInt() or Int(), also both in the System snippets under Math.
Wesley Crihfield
(Not an Autodesk Employee)
