Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Custom iProperties add to selected parts
7 REPLIES 7
Message 1 of 8
kresh.bell
367 Views, 7 Replies
I have this iLogic which works great for me. I add a description in the assembly environment by selecting the parts. When I'm done click escape.
Dim oOccurrence As ComponentOccurrence
msg = "Select a component (press ESC to exit)"
While True
	oOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, msg)
	' If nothing gets selected then we're done
	If IsNothing(oOccurrence) Then Exit While
	oName = oOccurrence.Name
	ThisApplication.ActiveDocument.selectset.select(oOccurrence)
	oDesc = iProperties.Value(oName, "Project", "Description")
	oDesc = InputBox(oName & " Description", "iLogic", oDesc)
	If Not oDesc = Nothing Then iProperties.Value(oName, "Project", "Description") = oDesc
End While
I am interested in whether it is possible to first create a custom iproperty (in case it does not exist) and then add a value to it in the same way in the assembly environment. The name custom iLogic does not need to be created through the toolbox, through iLogic is perfectly fine.
If it is possible to use the same iLogic also in a part environment, that would be really great
7 REPLIES 7
Message 2 of 8
Michael.Navara
in reply to: kresh.bell
You need just to wrap property value obtaining to Try-Catch.
While True
	ThisApplication.ActiveDocument.SelectSet.Select(oOccurrence)
	'Custom description
	Dim customDesc As String
	Try
		customDesc = iProperties.Value(oName, "Custom", "CustomDescription")
	Catch
		customDesc = ""
	End Try
	customDesc = InputBox(oName & " Custom Description", "iLogic", customDesc)
	If Not customDesc = Nothing Then iProperties.Value(oName, "Custom", "CustomDescription") = customDesc
End While
Message 3 of 8
kresh.bell
thanks, realy nice
Message 4 of 8
kresh.bell
in reply to: Michael.Navara
one more thing.
Is it possible to make a rule for part envirovment that, when runing, checks if there is a custom property name eg "Sample"? If it does not exist, it will be created. In both cases (exist or no), after that, a small window will open with the possibility to add or change value for that custom property.
Message 5 of 8
Michael.Navara
This is the same code (lines 17 - 26) without argument oName
Message 6 of 8
kresh.bell
Uncordiality,
it's not possible select part in part environment
Message 7 of 8
Michael.Navara
OK 😀
Try this code in part. If you want to change iProperties of the document where you run the rule, you don't need to select anything.
'Custom description
Try
	customDesc = iProperties.Value("Custom", "CustomDescription")
Catch
	customDesc = ""
End Try
customDesc = InputBox("Custom Description", "iLogic", customDesc)
If Not customDesc = Nothing Then iProperties.Value("Custom", "CustomDescription") = customDesc
Message 8 of 8
kresh.bell
thanks, it works
