Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Creation of Balloon set using Ilogic
10 REPLIES 10
Message 1 of 11
nvmierlo
1951 Views, 10 Replies
nvmierlo
Dear All,
I have successfully (with much help from this forum) created a Ilogic code that puts 3 balloons on my drawing (first picture)  however, I want to attach all three balloons to one leader (second picture). I am using named geometry to define the start points of the balloons leaders.
I have found the following code string in the Inventor API help: BalloonValueSets.Add( Component As Object ) As BalloonValueSet . But I cannot get it to work in my code. Any help is appreciated, thank you in advance! Below is my original code.
Kind regards,
Niek
Dim oDoc As DrawingDocument = ThisDrawing.Document
Dim oSheet As Inventor.Sheet = oDoc.ActiveSheet
Dim oTO As TransientObjects = ThisApplication.TransientObjects
Dim oBalloons As Balloons = oSheet.Balloons
Dim oBalloon As Balloon
Dim oView As DrawingView = ActiveSheet.View("ISO").View
Dim Sheet_1 = ThisDrawing.Sheets.ItemByName("Ondersteuning:1")
Dim view_ISO = Sheet_1.DrawingViews.ItemByName("ISO")
'Definition of number of values in array
Dim numImportIntents As Integer = 2 ' Aantal named geometries te importeren uit assembly, begint bij 0. één extra oInten(x) betekend numImportIntents +1
'Creation of different arrays
Dim oTG(numImportIntents) As TransientGeometry
Dim oLeaderPoints(numImportIntents) As ObjectCollection
Dim oIntent(numImportIntents) As Inventor.GeometryIntent
'Refrencing of named geometry in each compontent.
oIntent(0) = view_ISO.GetIntent("Staander links", "Balloon", PointIntentEnum.kMidPointIntent)
oIntent(1) = view_ISO.GetIntent("Bovenligger", "Balloon", PointIntentEnum.kMidPointIntent)
oIntent(2) = view_ISO.GetIntent("Eindkap links", "Balloon", PointIntentEnum.kMidPointIntent)
For i = LBound(oTG) To UBound(oTG)
	oTG(i) = ThisApplication.TransientGeometry
Next
For i = LBound(oLeaderPoints) To UBound(oLeaderPoints)
	oLeaderPoints(i) = ThisApplication.TransientObjects.CreateObjectCollection
Next
'Definition of location of balloon 1
oLeaderPoints(0).Add(oTG(0).CreatePoint2d(oView.Left - 2, oView.Top + 1.5))
oLeaderPoints(0).Add(oIntent(0))
'Creation of balloon
oBalloon = oBalloons.Add(oLeaderPoints(0))
'2nd balloon
oLeaderPoints(1).Add(oTG(1).CreatePoint2d(oView.Left -2 , oView.Top ))
oLeaderPoints(1).Add(oIntent(1))
oBalloon = oBalloons.Add(oLeaderPoints(1))
'3rd ballon
oLeaderPoints(2).Add(oTG(2).CreatePoint2d(oView.Left -2 , oView.Top - 1.5))
oLeaderPoints(2).Add(oIntent(2))
oBalloon = oBalloons.Add(oLeaderPoints(2))
Dear All,
Kind regards,
Niek
Next
Next
'2nd balloon
'3rd ballon
10 REPLIES 10
Message 2 of 11
Ralf_Krieg
in reply to: nvmierlo
Ralf_Krieg
Hello
Without your drawing file and the referenced model, it's hard to replay. No one wants to create a similar model from scratch. I assume the NamedEntites are Edges and the components are not in any subassembly.
A straight and possible unstable way could be:
Next
Next
'#### added begin
Dim oBVSets As BalloonValueSets = oBalloon.BalloonValueSets
'the straight way
oBVSets.Add(ointent(1).Geometry.modelgeometry.containingoccurrence)
oBVSets.Add(ointent(2).Geometry.modelgeometry.containingoccurrence)
'#### added end
''2nd balloon
'oLeaderPoints(1).Add(oTG(1).CreatePoint2d(oView.Left -2 , oView.Top ))
'oLeaderPoints(1).Add(oIntent(1))
'oBalloon = oBalloons.Add(oLeaderPoints(1))
''3rd ballon
'oLeaderPoints(2).Add(oTG(2).CreatePoint2d(oView.Left -2 , oView.Top - 1.5))
'oLeaderPoints(2).Add(oIntent(2))
'oBalloon = oBalloons.Add(oLeaderPoints(2))
R. Krieg
RKW Solutions GmbH
www.rkw-solutions.com
Hello
Next
Next
'#### added begin
'the straight way
'#### added end
''2nd balloon
''3rd ballon
R. Krieg
RKW Solutions GmbH
Message 3 of 11
nvmierlo
in reply to: Ralf_Krieg
nvmierlo
Dear R. Krieg,
Thank you very much your solution works flawlessly!
Dear R. Krieg,
Message 4 of 11
nvmierlo
nvmierlo
 @Ralf_Krieg
Dear R. Krieg,
One small addition, would it also be possible to refer to the components of the extra balloons by their name in the model tree? So, that it is not necessary to create named geometry for those files
Once again, thank you in advance!
 @Ralf_Krieg
Dear R. Krieg,
Message 5 of 11
Ralf_Krieg
Ralf_Krieg
Hello
yes, for instance with the ComponentOccurrecnce names:
'#### added begin
'the straight way
'oBVSets.Add(ointent(1).Geometry.modelgeometry.containingoccurrence)
'oBVSets.Add(ointent(2).Geometry.modelgeometry.containingoccurrence)
'alternative way using ComponentOccurrence names
Dim oModelDoc As AssemblyDocument = oView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oOcc As ComponentOccurrence
For Each oocc In oModelDoc.ComponentDefinition.Occurrences
	If oOcc.Name="Bovenligger" Or oOcc.Name="Eindkap links"
		oBVSets.Add(oOcc)
	End If
Next
'#### added end
R. Krieg
RKW Solutions GmbH
Hello
'#### added begin
'the straight way
		oBVSets.Add(oOcc)
	End If
Next
'#### added end
R. Krieg
RKW Solutions GmbH
Message 6 of 11
nvmierlo
nvmierlo
that works great aswell. Thanks a lot!
Message 7 of 11
nvmierlo
nvmierlo
Dear R.Krieg,
Here I am once more with another problem I am running into, is it also possible to refer tot components in sub assembly when using the method with component occurences? for example, I want to add a balloon for the component "DIN125 M6" that is part of the sub assembly "Type 1" (The sub assembly is structered Phantom in the main assembly). Thank you in advance once more.
Kind regards,
Niek
Dear R.Krieg,
Kind regards,
Niek
Message 8 of 11
Ralf_Krieg
Ralf_Krieg
Hello
You can try using the AllLeafOccurrences which returns all Occurrences with no child occurrences. This could be afaik parts or empty assemblies.
Not sure it'll work, can't test right now.
'#### added begin
'the straight way
For Each oOcc In oModelDoc.ComponentDefinition.Occurrences.AllLeafOccurrences
		oBVSets.Add(oOcc)
	End If
Next
'#### added end
R. Krieg
RKW Solutions GmbH
Hello
'#### added begin
'the straight way
		oBVSets.Add(oOcc)
	End If
Next
'#### added end
R. Krieg
RKW Solutions GmbH
Message 9 of 11
nvmierlo
nvmierlo
Dear R. Krieg,
This works until a subassembly is present more than once in the main assembly, the rule then adds the sub component balloons to the orginal balloons for the amount of times the sub assembly occurs.
Kind regards,
Niek
Dear R. Krieg,
Kind regards,
Niek
Message 10 of 11
Ralf_Krieg
Ralf_Krieg
Hello
We can simply try to write every Occurrence name added to the BalloonValueSet in a list and skip the next occurence with same name.
'#### added begin
Dim oBVSetList As New List (Of String)
'the straight way
		If Not oBVSetList.Contains(oOcc.Name)
			oBVSets.Add(oOcc)
			oBVSetList.Add(oOcc.Name)
		End If
	End If
Next
'#### added end
R. Krieg
RKW Solutions GmbH
Hello
'#### added begin
'the straight way
			oBVSets.Add(oOcc)
		End If
	End If
Next
'#### added end
R. Krieg
RKW Solutions GmbH
Message 11 of 11
nvmierlo
nvmierlo
That once again worked, thank you!
