Creating Instances and 3D Annotation in an Assembly
1 REPLY 1
kwarrenH4ZT3
228 Views, 1 Reply
I'm in the process of creating an iLogic that would allow a user to select parts in an assembly then run the rule to select from a radio button to either add or remove a customer supplied part this would then add a Instance Property called CSP and add an X for the value. Then I have it set up to change the color of the part to red so the user sees its different (Not sure if there is a way to do this for all representations but that would be helpful) but I would also like to add a 3D annotation leader text to the part. When the user selects the remove CSP it would undo all of these changes. I need a little help on creating the instances and the 3D annotations. Below is the current code I have that is definitely a work in progress.
Sub Main
	oDoc = ThisAssembly.Document
	oADef = oDoc.ComponentDefinition
	oOccs = oADef.Occurrences
	oTrans = ThisApplication.TransactionManager.StartTransaction(oDoc, "Rename Components W/ SN")
	Dim oSelectSet As SelectSet = ThisDoc.Document.SelectSet
	CSPSelection = InputRadioBox("Select what process.", "Add Customer Supplied Part", "Remove Customer Supplied Part", booleanParam, Title := "Select a Option")
	If CSPSelection = True Then
		''Add Customer Supplied Part
		If oSelectSet.Count = 0 Then 'nothing was pre-selected
			oSelectedView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartDefaultFilter, "Select Part")
		Else
			Dim oPreSelectedParts As New List(Of DrawingView)
			For Each oObj In oSelectSet
				If TypeOf oObj Is DrawingView Then
					Dim oSelView As DrawingView = oObj
					oPreSelectedParts.Add(oSelView)
				End If
			Next
			If oPreSelectedParts.Count = 0 Then Exit Sub 'none of pre-selected was view
			For Each oView As DrawingView In oPreSelectedViews
				'do what you need to do to each view here
			Next
		End If
		ColorChangePart(oOccs)
	Else If CSPSelection = False Then
	''Remove Customer Supplied Part
		Else
				End If
			Next
			Next
		End If
	ColorRemovePart(oOccs)
	End If
	oTrans.End
End Sub
Sub ColorChangePart(oComps As ComponentOccurrences)
	If IsNothing(oComps) OrElse oComps.Count = 0 Then Exit Sub
	For Each oComp As ComponentOccurrence In oComps
		Try
			If oComp.OccurrencePropertySetsEnabled Then
				Dim oInstPSet As PropertySet = oComp.OccurrencePropertySets.Item(1)
				Dim oInstP As Inventor.Property = oInstPSet.Item("CSP")
				Dim oSN As String = oInstP.Value.ToString
				If oSN = "X" Then
					Dim topAsm As AssemblyDocument = ThisDoc.Document
					Dim uAppearance As Asset = topAsm.Assets.Add(AssetTypeEnum.kAssetTypeAppearance, "Generic", "CUSTOMER SUPPLIED")
					Dim uColor As ColorAssetValue = uAppearance.Item("generic_diffuse")
					'		 Dim RNG = Math.Round(Rnd() * 255)
					'        Dim RNG1 = Math.Round(Rnd() * 255)
					'        Dim RNG2 = Math.Round(Rnd() * 255)
					uColor.Value = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
					'Random Color
					'uColor.Value = ThisApplication.TransientObjects.CreateColor(RNG,RNG1,RNG2)
					oComp.Appearance = uAppearance
				Else If oSN = "" Then
			End If
			End If
		Catch
		End Try
		If oComp.SubOccurrences.Count > 0 Then
			ColorChangePart(oComp.SubOccurrences)
		End If
	Next
End Sub
Sub ColorRemovePart(oComps As ComponentOccurrences)
		Try
				If oSN = "" Then
					'Dim topAsm As AssemblyDocument = ThisDoc.Document
					'Dim uAppearance As Asset = topAsm.Assets.Add(AssetTypeEnum.kAssetTypeAppearance, "Generic", "CUSTOMER SUPPLIED")
					'Dim uColor As ColorAssetValue = uAppearance.Item("generic_diffuse")
					'uColor.Value = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
					'Random Color
					'oComp.PartComponentDefinition.ClearAppearanceOverrides
					oComp.AppearanceSourceType = kPartAppearance
				Else If oSN <> "" Then
			End If
			End If
		Catch
		End Try
		End If
	Next
End Sub
Labels (3)
1 REPLY 1
A.Acheson
in reply to: kwarrenH4ZT3
Hi @kwarrenH4ZT3
Your code is accessing drawing views which is for the drawing document views was that your intention?
For design view reps in the assembly here is the API help for RepresentationsManager
Syntax
AssemblyComponentDefinition.RepresentationsManager() As RepresentationsManager
Syntax
RepresentationsManager.DesignViewRepresentations() As DesignViewRepresentations
Regards
Alan
Technology Administrators
