Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Creating Composite iMates
2 REPLIES 2
Q_Visser
211 Views, 2 Replies
Q_Visser
Hi Folks,
I'm attempting to create a bunch of composite iMates in an assembly, but I keep running into errors as I try to create them. I can create standard iMates no problem, but then using the created iMates to create a composite iMate is proving problematic.
To try trouble shoot, I manually created 3 iMates (test1, test2, test3) and then tried to use these to create the composite to no avail.
My test code is below:
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oCompDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
Dim o_iMateDefinitions As iMateDefinitions = oCompDef.iMateDefinitions
Dim o_iMateDefinition1 As iMateDefinition
Dim o_iMateDefinition2 As iMateDefinition
Dim o_iMateDefinition3 As iMateDefinition
Dim iMateCollection As ObjectCollection
For index = 1 To o_iMateDefinitions.Count
	If o_iMateDefinitions.Item(index).Name = "test1" Then
		o_iMateDefinition1 = o_iMateDefinitions.Item(index)
	ElseIf o_iMateDefinitions.Item(index).Name = "test2" Then
	ElseIf o_iMateDefinitions.Item(index).Name = "test3" Then
	End If
Next
iMateCollection.Add(o_iMateDefinition1)
iMateCollection.Add(o_iMateDefinition2)
iMateCollection.Add(o_iMateDefinition3)
Dim oCompImate As CompositeiMateDefinition = o_iMateDefinitions.AddCompositeiMateDefinition(iMateCollection, "CompositeTest")
Any help would be greatly appreciated!
Cheers,
Q Visser
Current Software:
Inventor Professional 2024.2 & Vault Professional 2024.2
Hi Folks,
	End If
Next
Cheers,
Q Visser
Current Software:
2 REPLIES 2
A.Acheson
in reply to: Q_Visser
A.Acheson
Hi @Q_Visser
You were missing two things. To create and  set the  Object collection
iMateCollection = ThisApplication.TransientObjects.CreateObjectCollection
and also  this variable was used in each if statement instead of as they are declared.as individual.
o_iMateDefinition1
Here is another way to write this a little shorter
Dim o_iMatesDefs As iMateDefinitions = oCompDef.iMateDefinitions
Dim iMateCollection As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
Dim imateList As String() = {"test1","test2","test3"}
For Each  o_imateDef As iMateDefinition In o_iMatesDefs
	If imateList.Contains(o_imateDef.Name)
		iMateCollection.Add(o_imateDef)
	End If
Next
Dim oCompImate As CompositeiMateDefinition = o_iMatesDefs.AddCompositeiMateDefinition(iMateCollection, "CompositeTest")
and another way if you like or statements.
	If o_imateDef.Name = "test1" _
	Or o_imateDef.Name = "test2" _
	Or o_imateDef.Name = "test3" Then
	End If
Next
Regards
Alan
Hi @Q_Visser
o_iMateDefinition1
	End If
Next
	End If
Next
Regards
Alan
Q_Visser
in reply to: A.Acheson
Q_Visser
Ahh, the setting of the object collection was absolutely my issue.
The duplicate "o_iMateDefinition1" was absolutely a typo in my test code, I didn't have that in my original code but that definitely didn't help with the test.
The short code with the array is a great way to add the required iMates to the collection - big fan of efficient code here.
Thank you so much @A.Acheson
Cheers,
Q Visser
Current Software:
Cheers,
Q Visser
Current Software:
