Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Creating a DWF of a model from its IDW
2 REPLIES 2
361 Views, 2 Replies
I am fairly new to iLogic and am running into an issue I am hoping someone can help me with.  Currently we are using the code shown below to create DXF and PDF versions of a completed IDW  and them to specific locations to a specific location.  It has now been requested that we also save a DWF of the model that the drawing is based on. I can do that seperately from the model but, would like to consolidate the creation of all three into one operation and have been unsuccessful so far. I always end up with a DWF of the IDW.  Is there a way to reference either the IPT or IAM that the IDW is based on and create a DWF of it from the IDW?  Any help would be greatly appreciated.
'Gets the Workspace Path
WorkspacePath= ThisDoc.WorkspacePath()
'Gets the Length of the WorkspacePath String
WorkspacePathLength = Len(WorkspacePath)
'Gets just the Path of the file
PathOnly = ThisDoc.Path
'Removes the Workspace Path from FullPath
PDFName = ThisDoc.FileName(False)
'document name without extension)
DirectoryPath = Strings.Left(PDFName, 5)
'Sets the Dirctory that the PDF should be saved in
PDFPath = "X:\PDF\" & DirectoryPath
'Checks to see if that directory exists, if not, it is created
If(Not System.IO.Directory.Exists(PDFPath)) Then
 System.IO.Directory.CreateDirectory(PDFPath)
End If
'Saves the PDF in the desired location
ThisDoc.Document.SaveAs(PDFPath & "\" & ThisDoc.FileName(False) &
".pdf" , True)
DXFName = ThisDoc.FileName(False)
DirectoryPath = Strings.Left(DXFName, 5)
'Sets the Dirctory that the DXF should be saved in
DXFPath = "X:\DXF\" & DirectoryPath
If(Not System.IO.Directory.Exists(DXFPath)) Then
 System.IO.Directory.CreateDirectory(DXFPath)
End If
'Saves the DXF in the desired location
ThisDoc.Document.SaveAs(DXFPath & "\" & ThisDoc.FileName(False) &
".dxf" , True)
 Thank you.
2 REPLIES 2
marcin_otręba
use:
ThisDoc.Document.ReferencedDocuments.Item(1).SaveAs(DWFPath & "\" & ThisDoc.FileName(False) &
".dwf", True)
in reply to: marcin_otręba
This works perfectly!  Thank you for your help!
