Thanks again Krieg!
I'm so free to ask you another question about an earlier topic we discussed, the renaming of the sketches.
Basically it works until a sketch number appears that already exist, despite this not apparent from the recursive search of all sketches based on the browser tree. In my head I can reason the solution, but converting it into the correct code is still a thing. I understand that I have to take another variable that has to be incremented every time the renaming was successful and I need a boolean that indicates whether or not the rename was successful. Specific this I struggle with.
Please see the code, 1ste the part I struggle with, starting by 'Rename temp', 2nd some corresponding variables and the cursive function and 3th the complete code.
Thanks in advance.
Greetings!
' Rename Sketches
' Iterate BrowserNodes and collect all Sketches
Dim oPane As BrowserPane
' Get the BrowserPane that support the search box.
If oPartDoc.DocumentType = kPartDocumentObject Then
oPane = oPartDoc.BrowserPanes("PmDefault")
ElseIf oPartDoc.DocumentType = kAssemblyDocumentObject Then
oPane = oPartDoc.BrowserPanes("AmBrowserArrangement")
ElseIf oPartDoc.DocumentType = kDrawingDocumentObject Then
oPane = oPartDoc.BrowserPanes("DlHierarchy")
ElseIf oPartDoc.DocumentType = kPresentationDocumentObject Then
oPane = oPartDoc.BrowserPanes("DxHierarchy")
End If
Dim items As String
items = GetBrowserNodes(oPane.TopNode.BrowserNodes)
' Reset PassedOrigin
PassedOrigin = False
' MessageBox.Show(items)
' oWrite.WriteLine("items as String:")
' oWrite.WriteLine(items)
' oWrite.WriteLine("")
'For Each element In ListWithSketches
' oWrite.WriteLine(element)
'Next
'ListWithSketches.sort
' Overview
For i = 0 To ListWithSketches.count - 1
oWrite.WriteLine(i+1 & ": " & ListWithSketches(i) & " (ListWithSketches)")
Next
For i = 1 To oPartDoc.ComponentDefinition.Sketches.Count
oWrite.WriteLine(i & ": " & oPartDoc.ComponentDefinition.Sketches(i).Name & " (oPartDoc.ComponentDefinition.Sketches)")
Next
' Sketch nummer uit ListWithSketches(i) obv inhoud
oWrite.WriteLine(Replace(ListWithSketches(i),"Sketch",""))
Next
' Rename temp
oWrite.WriteLine("Rename: ")
' Doorloop alle gevonden Sketches
Dim j As Integer
Dim l As Integer
oWrite.WriteLine("ListWithSketches " & i+1 & ": " & ListWithSketches(i))
'Zoek de gevonden Sketch in de 'Inventor volgorde lijst' en hernoem deze plaats vzv Temp
For j = 1 To oPartDoc.ComponentDefinition.Sketches.Count
'oWrite.WriteLine(PartDoc.ComponentDefinition.Sketches(i).Name & " (oPartDoc.ComponentDefinition.Sketches)")
If oPartDoc.ComponentDefinition.Sketches(j).Name = ListWithSketches(i) Then
'Dim Bool As Boolean
'If Not oPartDoc.ComponentDefinition.Sketches(j).Name = "Sketch" & i + 1 & " Temp" Then Bool = False
'oWrite.WriteLine("Rename Sketch result: " & Bool)
On Error Resume Next
If bool(oPartDoc.ComponentDefinition.Sketches(j).Name = "Sketch" & i + 1 & " Temp") Then
End If
End If
'oWrite.WriteLine(i & ": " & oPartDoc.ComponentDefinition.Sketches(i).Name & " (oPartDoc.ComponentDefinition.Sketches)")
Next
Next
' Rename final
'If oPartDoc.ComponentDefinition.Sketches(j).Name = ListWithSketches(i) Then
oPartDoc.ComponentDefinition.Sketches(j).Name = Replace(oPartDoc.ComponentDefinition.Sketches(j).Name," Temp","")
'End If
Next
' List to collect all Sketches from BrowserNodes
Public ListWithSketches As New List(Of String)
'Public ListWithSketches As New SortedList(Of String, Integer)
'Public C As Integer = 1
' Om de Sketches 'zuiver' te krijgen gaan we ze pas verzamelen nadat we de 'Origin' zijn gepasseerd
' Anders krijgen we ook de Sketches onder 'Solid' waarbij de volgorde niet overeen komt wanneer er oa Shared Sketches voorkomen
Public PassedOrigin As Boolean
Function GetBrowserNodes(nodes As BrowserNodesEnumerator) As String
Dim node As BrowserNode
For Each node In nodes
If node.BrowserNodeDefinition.Label.ToString Like "*Origin*" Then PassedOrigin = True
If node.BrowserNodeDefinition.Label.ToString Like "*Sketch*" And PassedOrigin = True Then
'If IsNumeric(Right(node.BrowserNodeDefinition.Label.ToString,1)) Then
'If node.Selected Then
If ListWithSketches.Contains(node.BrowserNodeDefinition.Label.ToString) = False Then
'If ListWithSketches.Containsvalue(node.BrowserNodeDefinition.Label.ToString) = False Then
ListWithSketches.Add(node.BrowserNodeDefinition.Label.ToString)
'ListWithSketches.Add(C, node.BrowserNodeDefinition.Label.ToString)
'C= C + 1
End If
'End If
'End If
End If
' For Debugging, check items as String in Sub Main
GetBrowserNodes = GetBrowserNodes + vbCrLf + node.BrowserNodeDefinition.Label.ToString
GetBrowserNodes = GetBrowserNodes + GetBrowserNodes(node.BrowserNodes)
Next
Return ListWithSketches.ToString
End Function
Sub Main()
' Write to textfile
Dim strDateAndTime As String
strDateAndTime = DateTime.Now.ToString(("yyyy-MM-dd HHmmss"))
Dim LogFileName As String
LogFileName = "C:\temp\iLogic_Log_" & strDateAndTime & ".txt"
oWrite = System.IO.File.CreateText(LogFileName)
'oWrite = System.IO.File.CreateText(ThisDoc.PathAndFileName(False) & ".txt")
' Calculate elapsed time
Dim oWatch As New Stopwatch
oWatch.Start
' Features
Dim iAliasFreeform As Integer
Dim iBend As Integer
Dim iBoss As Integer
Dim iBoundaryPatch As Integer
Dim iChamfer As Integer
Dim iCircularpattern As Integer
Dim iClient As Integer
Dim iCoil As Integer
Dim iCombine As Integer
Dim iCoreCavity As Integer
Dim iCornerChamferFeatureObject As Integer
Dim iCornerRoundFeatureObject As Integer
Dim iContourFlangeFeatureObject As Integer
Dim iCutFeatureObject As Integer
Dim iDecal As Integer
Dim iDeleteFace As Integer
Dim iDirectEdit As Integer
Dim iEmboss As Integer
Dim iExtend As Integer
Dim iExtrude As Integer
Dim iFaceDraft As Integer
Dim iFace As Integer
Dim iFaceOffset As Integer
Dim iFillet As Integer
Dim iFlangeFeatureObject As Integer
Dim iFreeform As Integer
Dim iGrill As Integer
Dim iHole As Integer
Dim iKnit As Integer
Dim iLip As Integer
Dim iLoft As Integer
Dim iMidsurface As Integer
Dim iMirror As Integer
Dim iMoveFace As Integer
Dim iMove As Integer
Dim iNonParametricBaseFeatureObject As Integer
'NonParametricBaseFeature
'NonParametricBaseFeatures
Dim kPunchToolFeatureObject As Integer
Dim iRectangularPattern As Integer
'Reference
Dim iReplaceFace As Integer
Dim iRest As Integer
Dim iRevolve As Integer
Dim iReferenceFeatureObject As Integer
Dim iRib As Integer
Dim iRuledSurface As Integer
Dim iRuleFillet As Integer
Dim iSculpt As Integer
Dim iShell As Integer
Dim iSketchDrivenPattern As Integer
Dim iSnapFit As Integer
Dim iSplit As Integer
Dim kSurfaceBodyObject As Integer
Dim iSweep As Integer
Dim iThicken As Integer
Dim iThread As Integer
Dim iTrim As Integer
Dim iUnwrap As Integer
Dim i As Integer
Dim oPartDoc As PartDocument = ThisDoc.Document
Dim oFeatures As PartFeatures = oPartDoc.ComponentDefinition.Features
Dim oDef As PartComponentDefinition = oPartDoc.ComponentDefinition
' Rebuild All
ThisDoc.Document.Rebuild()
'' For Debugging
'oWrite.WriteLine("")
'For Each oFeature In oFeatures
' oWrite.WriteLine("Before actions: " & oFeature.name)
'Next
' Undo Wrapper
Dim trans As Transaction = ThisApplication.TransactionManager.StartTransaction(oPartDoc, "Do your thing...")
' Rename Solid Bodies
Dim iSolidCount As Integer
Dim oSolid As SurfaceBody
For Each oSolid In oDef.SurfaceBodies
iSolidCount = iSolidCount + 1
oSolid.Name = "Solid" & iSolidCount.ToString & " " & strDateAndTime
Next
iSolidsCount = 0
iSolidsCount = iSolidCount + 1
Next
' Work Features
Dim iWorkPlane As Integer
Dim iWorkPoint As Integer
Dim iWorkAxis As Integer
Dim iWorkSurface As Integer
' Rename Work Features:
' Rename Work Planes
For Each oWorkPlane In oDef.WorkPlanes
If oWorkPlane.Name <> "Start plane" And oWorkPlane.Name <> "End plane" Then
If oWorkPlane.IsCoordinateSystemElement = False Then
iWorkPlane = iWorkPlane + 1
oWorkPlane.Name = "Work Plane" & iWorkPlane.ToString & " " & strDateAndTime
End If
End If
Next
iWorkPlane = 0
End If
End If
Next
' Rename Work Points
For Each oWorkPoint In oDef.WorkPoints
If oWorkPoint.IsCoordinateSystemElement = False Then
iWorkPoint = iWorkPoint + 1
oWorkPoint.Name = "Work Point" & iWorkPoint.ToString & " " & strDateAndTime
End If
Next
iWorkPoint = 0
End If
Next
' Rename Work Axis
For Each oWorkAxis In oDef.WorkAxes
If oWorkAxis.IsCoordinateSystemElement = False Then
iWorkAxis = iWorkAxis + 1
oWorkAxis.Name = "Work Axis" & iWorkAxis.ToString & " " & strDateAndTime
End If
Next
iWorkAxis = 0
End If
Next
' Rename Work Surface
For Each oWorkSurface In oDef.WorkSurfaces
iWorkSurface = iWorkSurface + 1
oWorkSurface.Name = "Work Surface" & iWorkSurface.ToString & " " & strDateAndTime
Next
iWorkSurface = 0
Next
'Rename Features
For i = 1 To oFeatures.Count
If oFeatures(i).Name <> "Body" And _
oFeatures(i).Name <> "Driven Length" And _
oFeatures(i).Type <> ObjectTypeEnum.kReferenceFeatureObject Then
oFeatures(i).Name = i & " " & strDateAndTime
end if
Next
'MessageBox.Show("Wait...")
Select Case oFeatures(i).Type
Case ObjectTypeEnum.kAliasFreeformFeatureObject:
iAliasFreeform = iAliasFreeform + 1
oFeatures(i).Name = "Alias Freeform" & CStr(iAliasFreeform)
Case ObjectTypeEnum.kBendFeatureObject:
iBend = iBend + 1
oFeatures(i).Name = "Bend" & CStr(iBend)
Case ObjectTypeEnum.kBossFeatureObject:
iBoss = iBoss + 1
oFeatures(i).Name = "Boss" & CStr(iBoss)
Case ObjectTypeEnum.kBoundaryPatchFeatureObject:
iBoundaryPatch = iBoundaryPatch + 1
oFeatures(i).Name = "Boundary Patch" & CStr(iBoundaryPatch)
Case ObjectTypeEnum.kChamferFeatureObject:
iChamfer = iChamfer + 1
oFeatures(i).Name = "Chamfer" & CStr(iChamfer)
Case ObjectTypeEnum.kCircularPatternFeatureObject:
iCircularpattern = iCircularpattern + 1
oFeatures(i).Name = "Circular Pattern" & CStr(iCircularpattern)
Case ObjectTypeEnum.kClientFeatureObject:
If oFeatures(i).Name <> "Driven Length"
iClient = iClient + 1
oFeatures(i).Name = "Client" & CStr(iClient)
End If
Case ObjectTypeEnum.kCoilFeatureObject :
iCoil = iCoil + 1
oFeatures(i).Name = "Coil" & CStr(iCoil)
Case ObjectTypeEnum.kCombineFeatureObject:
iCombine = iCombine + 1
oFeatures(i).Name = "Combine" & CStr(iCombine)
Case ObjectTypeEnum.kCoreCavityFeatureObject:
iCoreCavity = iCoreCavity + 1
oFeatures(i).Name = "Core Cavity" & CStr(iCoreCavity)
Case ObjectTypeEnum.kCornerChamferFeatureObject:
iCornerChamferFeatureObject = iCornerChamferFeatureObject + 1
oFeatures(i).Name = "Corner Chamfer" & CStr(iCornerChamferFeatureObject)
Case ObjectTypeEnum.kCornerRoundFeatureObject:
iCornerRound = iCornerRound + 1
oFeatures(i).Name = "Corner Round" & CStr(iCornerRound)
Case ObjectTypeEnum.kContourFlangeFeatureObject:
iContourFlangeFeatureObject = iContourFlangeFeatureObject + 1
oFeatures(i).Name = "Contour Flange" & CStr(iContourFlangeFeatureObject)
Case ObjectTypeEnum.kCutFeatureObject:
iCut = iCut + 1
oFeatures(i).Name = "Cut" & CStr(iCut)
Case ObjectTypeEnum.kDecalFeatureObject :
iDecal = iDecal + 1
oFeatures(i).Name = "Decal" & CStr(iDecal)
Case ObjectTypeEnum.kDeleteFaceFeatureObject:
iDeleteFace = iDeleteFace + 1
oFeatures(i).Name = "Delete Face" & CStr(iDeleteFace)
Case ObjectTypeEnum.kDirectEditFeatureObject:
iDirectEdit = iDirectEdit + 1
oFeatures(i).Name = "Direct Edit" & CStr(iDirectEdit)
Case ObjectTypeEnum.kEmbossFeatureObject:
iEmboss = iEmboss + 1
oFeatures(i).Name = "Emboss" & CStr(iEmboss)
Case ObjectTypeEnum.kExtendFeatureObject:
iExtend = iExtend + 1
oFeatures(i).Name = "Extend" & CStr(iExtend)
Case ObjectTypeEnum.kExtrudeFeatureObject :
'messagebox.Show(oFeatures(i).Name)
If oFeatures(i).Name <> "Body" Then
iExtrude = iExtrude + 1
''MessageBox.Show(iExtrude & " - i =" & i & " - CStr: " & CStr(iExtrude))
oFeatures(i).Name = "Extrusion" & CStr(iExtrude)
End If
Case ObjectTypeEnum.kFaceDraftFeatureObject :
iFaceDraft = iFaceDraft + 1
oFeatures(i).Name = "Face Draft" & CStr(iFaceDraft)
Case ObjectTypeEnum.kFaceFeatureObject:
iFace = iFace + 1
oFeatures(i).Name = "Face" & CStr(iFace)
Case ObjectTypeEnum.kFaceOffsetFeatureObject :
iFaceOffset = iFaceOffset + 1
oFeatures(i).Name = "Face Offset" & CStr(iFaceOffset)
Case ObjectTypeEnum.kFilletFeatureObject:
iFillet = iFillet + 1
oFeatures(i).Name = "Fillet" & CStr(iFillet)
Case ObjectTypeEnum.kFlangeFeatureObject:
iFlangeFeatureObject = iFlangeFeatureObject + 1
oFeatures(i).Name = "Flange" & CStr(iFlangeFeatureObject)
Case ObjectTypeEnum.kFreeformFeatureObject :
iFreeform = iFreeform + 1
oFeatures(i).Name = "Freeform" & CStr(iFreeform)
Case ObjectTypeEnum.kGrillFeatureObject:
iGrill = iGrill + 1
oFeatures(i).Name = "Grill" & CStr(iGrill)
Case ObjectTypeEnum.kHoleFeatureObject:
iHole = iHole + 1
oFeatures(i).Name = "Hole" & CStr(iHole)
Case ObjectTypeEnum.kKnitFeatureObject:
iKnit = iKnit + 1
oFeatures(i).Name = "Knit" & CStr(iKnit)
Case ObjectTypeEnum.kLipFeatureObject:
iLip = iLip + 1
oFeatures(i).Name = "Lip" & CStr(iLip)
Case ObjectTypeEnum.kLoftFeatureObject:
iLoft = iLoft + 1
oFeatures(i).Name = "Loft" & CStr(iLoft)
Case ObjectTypeEnum.kMidSurfaceFeatureObject:
iMidsurface = iMidsurface + 1
oFeatures(i).Name = "Midsurface" & CStr(iMidsurface)
Case ObjectTypeEnum.kMirrorFeatureObject:
iMirror = iMirror + 1
oFeatures(i).Name = "Mirror" & CStr(iMirror)
Case ObjectTypeEnum.kMoveFaceFeatureObject:
iMoveFace = iMoveFace + 1
oFeatures(i).Name = "MoveFace" & CStr(iMoveFace)
Case ObjectTypeEnum.kNonParametricBaseFeatureObject:
iNonParametricBaseFeatureObject = iNonParametricBaseFeatureObject + 1
oFeatures(i).Name = "Solid Body" & CStr(iNonParametricBaseFeatureObject)
Case ObjectTypeEnum.kMoveFeatureObject :
iMove = iMove + 1
oFeatures(i).Name = "Move" & CStr(iMove)
Case ObjectTypeEnum.kPunchToolFeatureObject:
iPunchToolFeature = iPunchToolFeature + 1
oFeatures(i).Name = "Punch Tool Feature" & CStr(iPunchToolFeature)
Case ObjectTypeEnum.kRectangularPatternFeatureObject:
iRectangularPattern = iRectangularPattern + 1
oFeatures(i).Name = "Rectangular Pattern" & CStr(iRectangularPattern)
Case ObjectTypeEnum.kReferenceFeatureObject:
' Do nothing waarschijnlijk een mirrorpart
'iReferenceFeatureObject = iReferenceFeatureObject + 1
'oFeatures(i).Name = "Rectangular Pattern" & CStr(iReferenceFeatureObject)
Case ObjectTypeEnum.kReplaceFaceFeatureObject:
iReplaceFace = iReplaceFace + 1
oFeatures(i).Name = "ReplaceFace" & CStr(iReplaceFace)
Case ObjectTypeEnum.kRestFeatureObject:
iRest = iRest + 1
oFeatures(i).Name = "Rest" & CStr(iRest)
Case ObjectTypeEnum.kRevolveFeatureObject:
iRevolve = iRevolve + 1
oFeatures(i).Name = "Revolve" & CStr(iRevolve)
Case ObjectTypeEnum.kRibFeatureObject:
iRib = iRib + 1
oFeatures(i).Name = "Rib" & CStr(iRib)
Case ObjectTypeEnum.kRuledSurfaceFeatureObject:
iRuledSurface = iRuledSurface + 1
oFeatures(i).Name = "Ruled Surface" & CStr(iRuledSurface)
Case ObjectTypeEnum.kRuleFilletFeatureObject:
iRuleFillet = iRuleFillet + 1
oFeatures(i).Name = "Rule Fillet" & CStr(iRuleFillet)
Case ObjectTypeEnum.kSculptFeatureObject:
iSculpt = iSculpt + 1
oFeatures(i).Name = "Sculpt" & CStr(iSculpt)
Case ObjectTypeEnum.kShellFeatureObject:
iShell = iShell + 1
oFeatures(i).Name = "Shell" & CStr(iShell)
Case ObjectTypeEnum.kSketchDrivenPatternFeatureObject:
iSketchDrivenPattern = iSketchDrivenPattern + 1
oFeatures(i).Name = "Sketch Driven Pattern" & CStr(iSketchDrivenPattern)
Case ObjectTypeEnum.kSnapFitFeatureObject:
iSnapFit = iSnapFit + 1
oFeatures(i).Name = "SnapFit" & CStr(iSnapFit)
Case ObjectTypeEnum.kSplitFeatureObject:
iSplit = iSplit + 1
oFeatures(i).Name = "Split" & CStr(iSplit)
Case ObjectTypeEnum.kSurfaceBodyObject:
ikSurfaceBodyObject = ikSurfaceBodyObject + 1
oFeatures(i).Name = "Solid" & CStr(ikSurfaceBodyObject)
Case ObjectTypeEnum.kSweepFeatureObject:
iSweep = iSweep + 1
oFeatures(i).Name = "Sweep" & CStr(iSweep)
Case ObjectTypeEnum.kThickenFeatureObject:
iThicken = iThicken + 1
oFeatures(i).Name = "Thicken" & CStr(iThicken)
Case ObjectTypeEnum.kThreadFeatureObject:
iThread = iThread + 1
oFeatures(i).Name = "Thread" & CStr(iThread)
Case ObjectTypeEnum.kTrimFeatureObject:
iTrim = iTrim + 1
oFeatures(i).Name = "Trim" & CStr(iTrim)
' Not for IV2019
' Case ObjectTypeEnum.kUnwrapFeatureObject:
' iUnwrap = iUnwrap + 1
' oFeatures(i).Name = "Unwrap" & CStr(iUnwrap)
Case Else:
MsgBox ("Unknown feature detected: " & CStr(oFeatures(i).Type))
End Select
Next
' Rename Sketches
End If
Dim items As String
'Next
' Overview
Next
Next
Next
' Rename temp
Dim j As Integer
Dim l As Integer
End If
End If
Next
Next
' Rename final
'End If
Next
' For i = 1 To oPartDoc.ComponentDefinition.Sketches.Count
' oPartDoc.ComponentDefinition.Sketches(i).Name = "Sketch" & Replace(ListWithSketches(i-1),"Sketch","") & " Temp"
' Next
' ' Rename
' oPartDoc.ComponentDefinition.Sketches(i).Name = Replace(oPartDoc.ComponentDefinition.Sketches(i).Name, "Temp", "")
' oPartDoc.ComponentDefinition.Sketches(i).Name = Replace(oPartDoc.ComponentDefinition.Sketches(i).Name," ","")
' Next
' Result
Next
' Refill List
ListWithSketches.clear
Dim items2 As String
items2 = GetBrowserNodes(oPane.TopNode.BrowserNodes)
' Overview
Next
' MessageBox.Show(items2)
'Dim oSketch As Sketch
'For i = 1 To oPartDoc.ComponentDefinition.Sketches.Count
' oWrite.WriteLine(oPartDoc.ComponentDefinition.Sketches(i).Name & " - " & ListWithSketches(i-1))
'Next
' oPartDoc.ComponentDefinition.Sketches(i).Name = ListWithSketches(i-1) & strDateAndTime
'Next
'Next
'oWrite.WriteLine("----------------------------------------------------------------------------------------------------")
'Next
' Undo Wrapper
trans.End()
' ' Test
' For i = 1 To oPartDoc.ComponentDefinition.Features.ReferenceFeatures.Count
' oWrite.WriteLine(oPartDoc.ComponentDefinition.Features.ReferenceFeatures(i).Name)
' Next
' For Each oSolid In oDef.SurfaceBodies
' For Each oSolid1 In oSolid.Faces
' For Each osolid3 In oSolid1.ed..iSolidCount = iSolidCount + 1
' Next
' Next
' Next
'MsgBox("Done",,"iLogic")
' Rebuild All
'' For Debugging
' oWrite.WriteLine("After actions: " & oFeature.name)
'Next
'Calculate elapsed time.
oWatch.Stop()
oWrite.WriteLine(vbNewLine & "Done!" & vbNewLine & ("Elapsed Time: " & oWatch.ElapsedMilliseconds.ToString & " Milliseconds"))
'MsgBox (vbNewLine & "Done!" & vbNewLine & ("Elapsed Time: " & oWatch.ElapsedMilliseconds.ToString & " Milliseconds"))
oWrite.Close()
'Dim p As System.Diagnostics.Process = Process.Start(LogFileName)
ThisDoc.Launch(LogFileName)
'ThisDoc.Launch(ThisDoc.PathAndFileName(False) & ".txt")
'Set focus back the Inventor application
Dim App As Process() = Process.GetProcessesByName("Inventor")
If App.Length > 0 Then
AppActivate(App(0).Id)
End If
End Sub
'C= C + 1
End If
'End If
'End If
End If
Next
End Function
