Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Create Warehouse and insert columns using ilogic
2 REPLIES 2
murugasubi
365 Views, 2 Replies
Hi Dear, Please refer the attached inventor sketch which is a warehouse, and inside dots are columns. I am copying the sketch from AutoCAD and pasting it in inventor. Now, I want to create the warehouse after that I need columns as per the attached final image. Below is the ilogic code for creating a warehouse. I want to create the columns, Please help me with the balance code to create columns.  (if column creation is not possible, we can insert the columns in the points also ok)
'Creating warehouse without columns
Sub main
    Dim oPartDoc As PartDocument
    oPartDoc = ThisApplication.ActiveDocument
    ' Set a reference to the component definition.
    Dim oCompDef As PartComponentDefinition
    oCompDef = oPartDoc.ComponentDefinition
   'Dim oSketches As PlanarSketches = ThisApplication.ActiveEditDocument.ComponentDefinition.Sketches
	'oSketches("Sketch1").Edit
	Dim oSketches As PlanarSketches = oCompDef.Sketches
	'oSketches("WHBaseSketch").ExitEdit
	Try
	Catch
	End Try
	Dim oSketch1 As PlanarSketch
	oSketch1 = oSketches("WHBaseSketch")
	' Create a profile.
    Dim oProfile As Profile
    oProfile = oSketch1.Profiles.AddForSolid
    ' Create a base extrusion 1cm thick.
    Dim oExtrudeDef As ExtrudeDefinition
    oExtrudeDef = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kJoinOperation)
    Call oExtrudeDef.SetDistanceExtent(1, kNegativeExtentDirection)
    Dim oExtrude As ExtrudeFeature
    oExtrude = oCompDef.Features.ExtrudeFeatures.Add(oExtrudeDef)
	Dim oFrontFace As Face
    oFrontFace = oExtrude.StartFaces.Item(1)
	Dim oSketch2 As PlanarSketch
	If False Then
	    oSketch2 = oCompDef.Sketches.Add(oFrontFace)
	    Dim featEdge As Edge
	    For Each featEdge In oFrontFace.Edges
	        Call oSketch2.AddByProjectingEntity(featEdge)
	    Next
	Else
	    'Simpler version
	    oSketch2 = oCompDef.Sketches.Add(oFrontFace, True)
	End If
	Dim entitiesForOffset As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection()
	entitiesForOffset.Add(oSketch2.SketchLines(1))
	Dim offsetDistance As Double '= 12 '* 2.54
	offsetDistance = 12 * 2.54
	Dim offsetDirection As Boolean = True
	Dim offsetedEntities = oSketch2.OffsetSketchEntitiesUsingDistance(entitiesForOffset, offsetDistance, offsetDirection, True, True)
	Dim profile2 = oSketch2.Profiles.AddForSolid(True)
	Dim oExtrudeDef2 = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(profile2, PartFeatureOperationEnum.kJoinOperation)
	Call oExtrudeDef2.SetDistanceExtent(60*2.54, kPositiveExtentDirection)
	Dim oExtrude2 = oCompDef.Features.ExtrudeFeatures.Add(oExtrudeDef2)
	ThisApplication.CommandManager.ControlDefinitions("AppIsometricViewCmd").Execute
End Sub
'I need to insert / craete columns on the points
Murugan
2 REPLIES 2
aelqabbany
in reply to: murugasubi
Add this to the bottom of your code and let me know how it goes:
	ColumnsCounter = 0
	ColumnX = 20
	ColumnY = 40
	ColumnHeight = 500
	For Each oSPoint As SketchPoint In oSketch1.SketchPoints
		If oSPoint.AttachedEntities.Count = 0 Then
			ColumnsCounter += 1
			Dim ColumnSketch As PlanarSketch = oCompDef.Sketches.Add(oFrontFace)
			Dim InstanceSketchPoint As SketchPoint = ColumnSketch.AddByProjectingEntity(oSPoint)
			Dim RectanglePoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(InstanceSketchPoint.Geometry.X + ColumnX, InstanceSketchPoint.Geometry.Y + ColumnY)
			ColumnSketch.SketchLines.AddAsTwoPointCenteredRectangle(InstanceSketchPoint, RectanglePoint)
			Dim ColumnProfile As Profile = ColumnSketch.Profiles.AddForSolid
			Dim ColumnExtrudeDef As ExtrudeDefinition = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(ColumnProfile, kjoinoperation)
			ColumnExtrudeDef.SetDistanceExtent(ColumnHeight , kPositiveExtentDirection)
			Dim ColumnExtrude As ExtrudeFeature = oCompDef.Features.ExtrudeFeatures.Add(ColumnExtrudeDef)
			ColumnExtrude.Name = "Column" & Str(ColumnsCounter)
		End If
	Next
murugasubi
Thanks a lot, @aelqabbany
I have checked with many sketches, all are working excellent. I really appreciate your efforts and heartfelt thanks to you. You have saved a lot of time for us on sketch editing.
