Create sketch array iLogic using ObjectCollection
Hello, I am wondering if there is a good way to create a sketch array using an ObjectCollection. I have a for loop that uses a new sketch every iteration. However I have not had any luck declaring a sketch as an object collection, and I can't simply reuse the same sketch variable every iteration, because declaring a new sketch with the same object name throws an error after it has already been consumed by a feature. Any thoughts?
Correction:
I mistakenly thought you could not get away with declaring a new sketch though every iteration under the same variable name. This is not the case. It still would cleaner if it could be an array somehow, but it is not necessary.
JelteDeJong
did you try to make the sketch shared. shared sketches can be consumed by multiple features.
code snippet from help file.
Public Sub MakeSketchShared()
   ' Set a reference to the part component definition.
   ' This assumes that a part document is active.
   Dim oCompDef As PartComponentDefinition
   Set oCompDef = ThisApplication.ActiveDocument.ComponentDefinition
   ' Get the first extrusion feature in the part.
   ' This assumes that an extrusion feature exists in the part.
   Dim oExtrudeFeature As ExtrudeFeature
   Set oExtrudeFeature = oCompDef.Features.ExtrudeFeatures.Item(1)
   ' Set a reference to the sketch of the feature.
   Dim oSketch As PlanarSketch
   Set oSketch = oExtrudeFeature.Definition.Profile.Parent
   ' Share the sketch of the feature.
   oSketch.Shared = True
End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
