Choose file location
11:25 AM
I have a macro/Ilogic combination that creates a drawing of a sheet metal part and it saves the new drawing in the same location as the part its being run on. I want to make a box pop up that lets you select the location of the new drawing, but can't seem to figure it out.
To use the code run the macro on a sheet metal part with either the Vendor or Category marked as Laser. The macro then runs the CreateDrawingSingle rule after adding a couple Iproperties. RuleForDrawingSingle is then set up to run on open on the template.
