This one is really giving me trouble. I've noticed that there's solutions on the forums for creating new model states in an .ipt from an assembly level. But is there a way to turn a normal part file (.ipt) into a model state and add new model states all from within the .ipt?
Thank you for your time!
Solved by yan.gauthier. Go to Solution.
you can just add a new model state from within the part:
Sub newModelState()
Dim partDoc As PartDocument
Set partDoc = ThisApplication.ActiveEditDocument
Dim newModelState As ModelState
Set newModelState = partDoc.ComponentDefinition.ModelStates.add("newModelState")
End Sub
