Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Create .ipt file from .dwg
8 REPLIES 8
Message 1 of 9
george1985
814 Views, 8 Replies
I have a 3D .dwg file. I would like to create an Inventor part file (.ipt) from it with the use of Inventor API. Any language would help (VBA, VB.NET, C#...).
The 3D .dwg file contains only a single autocad solid, not lines or curves.
Is there such an API example?
I would be grateful for any kind of help.
8 REPLIES 8
Message 2 of 9
A.Acheson
in reply to: george1985
Hi @george1985
This sounds like a difficult task to do with API especially working with geometry not created in inventor. Any reason why your not doing this manually? Can you attach a sample file to work with and an image of the part in question?
Regards
Alan
Message 3 of 9
george1985
in reply to: A.Acheson
Hi @A.Acheson
Thank you for replying.
I have tens and tens of .dwg 3D models created in Autocad by external party. I have to "import" all of them to particular Inventor assemblies as single parts. What I am doing right now is opening each .dwg file in Inventor, and saving it as an .ipt. And then inserting it into appropriate assembly.
It would save me hours of work, if I could run a VBA/VB.NET/C# code, which will create .ipt files from all those .dwg files. Then I can easily open particular assembly file and just "Place" the needed .ipt.
I attached a 3D model of one such .dwg file.
Message 4 of 9
Michael.Navara
I try to import DWG model, but with controversial result.
Here is my code for import single DWG model
Sub ImportSingleDwg()
    Dim dwgFile = "C:\DWG\autocad_3D.dwg"
    Dim dwgTranslatorId = "{C24E3AC2-122E-11D5-8E91-0010B541CD80}"
    Dim dwgTranslator As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById(dwgTranslatorId)
    Dim dataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium()
    dataMedium.FileName = dwgFile
    Dim context As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext()
    context.Type = IOMechanismEnum.kDataDropIOMechanism
    Dim options As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap()
    '*** NOTES / WARNINGS ***
    '1) HasOpenOptions returns always FALSE
    '2) Without this call the export doesn't work for me
    '3) Variable 'options' contains one value named 'Import_Acad_IniFile' but when I try to change them, export doesn't work
    Dim hasOpenOptions As Boolean = dwgTranslator.HasOpenOptions(dataMedium, context, options)
    Logger.Debug("OpenOpts: {0}", hasOpenOptions)
    Logger.Debug(options.Count)
    Logger.Debug(options.Name(1))
    Logger.Debug(options.Item(1))
    Dim targetObject As Object
    dwgTranslator.Open(dataMedium, context, options, targetObject)
    Logger.Debug("Done")
End Sub
  • I try to enclose this code to loop for multiple files. It works, but I'm not able to get 3D parts during import process.
  • I'm not able to set INI file for import. When I try it, import doesn't work. Parts is not imported.
  • There is one strange call on line 21. False is always returned, but without this call the export doesn't work.
Tested on Win 10 CZ + Inventor 2024 CZ
I hope it helps.
Message 5 of 9
george1985
in reply to: Michael.Navara
Thank you very much @Michael.Navara !
I have Inventor 2022. The translator addin id should be the same as on your Iventor 2024?
Message 6 of 9
Michael.Navara
Yes, this is constant value for Addin
Here is fixed code to import multiple DWG model, but with previously mentioned obscurities.
Sub ImportMultipleDwgModels()
    Dim iniFileName As String = "C:\DWG\importDwg.ini"
    Dim dwgFileNames As String() = {
"C:\DWG\autocad_3D_1.dwg",
"C:\DWG\autocad_3D_2.dwg",
"C:\DWG\autocad_3D_3.dwg",
"C:\DWG\autocad_3D_4.dwg"
    For Each dwgFileName As String In dwgFileNames
        Dim partDocument As PartDocument = ImportDwgModel(dwgFileName, iniFileName)
        If partDocument Is Nothing Then Continue For
        Dim iptFileName = System.IO.Path.ChangeExtension(dwgFileName, ".ipt")
        'Dim iptFileName = dwgFileName & ".ipt"
        partDocument.SaveAs(iptFileName, False)
        partDocument.Close()
    Next
End Sub
Function ImportDwgModel(dwgFileName As String, iniFileName As String) As PartDocument
    'Get DWG Translator
    'Create DataMedium
    dataMedium.FileName = dwgFileName
    'Create translation context
    'Create options
    'options.Value("Import_Acad_IniFile") = iniFileName
    'Import DWG
    '3D model is imported as side effect not as primary output
    Dim primaryOutputDoc = TryCast(targetObject, Document)
    If Not primaryOutputDoc Is Nothing Then primaryOutputDoc.Close(True)
    'Get imported model document from opened documents by it's DisplayName
    Dim displayName As String = System.IO.Path.GetFileNameWithoutExtension(dwgFileName)
    Dim dwg3dPart As PartDocument = Nothing
    For Each document As Document In ThisApplication.Documents
        If document.DisplayName.StartsWith(displayName) Then
            dwg3dPart = TryCast(document, PartDocument)
            If not dwg3dPart Is Nothing Then Exit For
        End If
    Next
    If Not dwg3dPart Is Nothing Then Return dwg3dPart
    Logger.Error("Import failed: {0}", dwgFileName)
    Return Nothing
End Function
Message 7 of 9
george1985
@Michael.Navara Thank you very much for the new version as well!
Would you mind if I ask how to run this VBA code?
So in Inventor: Tools->VBA Editor.
Then once VBA Editor window appears, I should choose: File->New Project. Then inside the 'Module' of that new project, I should paste your VBA code.
I commented out the 'Dim iniFileName' and adapted the 'dwgFileNames' paths to my PC.
Then I hit 'Run' button.
When I do this, I get message:
"Compile error:
Syntax error"
I apologize for disturbing you with such trivialities, even though you made the programming code I needed.
Message 8 of 9
Michael.Navara
This is not a VBA code but iLogic code. You need to create new external iLogic rule, copy code into and you need to add
Sub Main()
End Sub
at the top of the rule
Message 9 of 9
george1985
Thank you very much for the invaluable help @Michael.Navara .
I owe you a beer for this. If you have some online Patreon-like account, please let me know.
Can I try to be annoying with only one more question?
In the mean time, I tried to call your code externally from SharpDevelop (Visual Studio-like editor).
On the line:
the following error is raised:
"Message: Catastrophic failure (Exception from HRESULT: 0x8000FFFF (E_UNEXPECTED))
Do you have suggestion what could be the issue?
Some Inventor.Interop methods can only be called internally through iRule or VBA Editor, but not "outside" from Inventor with the use of Autodesk.Inventor.Interop.dll?
EDIT: I didn't have one line included:
This cause the error message. Now that included it, it works.
Thank you very much for the help Michael!
