Create Ilogic To Delete All Rule In Assembly, Subassembly And Part
haphanthanhtam.work
haphanthanhtam.work
I want have a Ilogic to delete all rule in assembly, subassembly and part
Andrii_Humeniuk
Hi @haphanthanhtam.work . This rule removes all internal rules in all documents of the assembly. Use it as an external rule.
Sub Main
	Dim oDoc As Document = ThisDoc.Document
	Dim oAuto As IiLogicAutomation = iLogicVb.Automation
	If Not TypeOf oDoc Is AssemblyDocument Then Exit Sub
	Dim oAsmDoc As AssemblyDocument = oDoc
	oAuto.DeleteAllRules(oAsmDoc)
	Dim oRefDocs As DocumentsEnumerator = oAsmDoc.AllReferencedDocuments
	Dim oOccs As ComponentOccurrences = oAsmDoc.ComponentDefinition.Occurrences
	Dim oPBar As Inventor.ProgressBar = ThisApplication.CreateProgressBar(False, oRefDocs.Count, "Copy ryles...")
	Dim i As Integer = 1
	oPBar.Message = "Loading..."
	Dim oTM As Transaction = ThisApplication.TransactionManager.StartTransaction(oAsmDoc, "RemoveRulesInAllDocs")
	For Each oRefDoc As Document In oRefDocs
		oPBar.Message = "Remove rules in docs. Progress " & i & " of " & oRefDocs.Count & "."
		If oOccs.AllReferencedOccurrences(oRefDoc).Count > 0 Then
			If Not oRefDoc.IsModifiable Then Continue For
			oAuto.DeleteAllRules(oRefDoc)
			oRefDoc.Save()
		End If
		oPBar.UpdateProgress
		i += 1
	Next
	oPBar.Close()
	oTM.End()
End Sub
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
WCrihfield
Have you tried just that one line of code yet.  There are two built-in methods for deleting all internal iLogic rules.  One is limited to just the input document, and will go no deeper.
iLogicVb.Automation.DeleteAllRulesInDocument(oDoc)
The other says essentially the same thing as the button in the ribbon (works on the input document, and if its an assembly, all referenced documents).
iLogicVb.Automation.DeleteAllRules(oDoc)
Wesley Crihfield
(Not an Autodesk Employee)
gilhoej_teknik
Observer
Observer
Thx you're a life saver. Michael
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
